Facelift Vs Pre-facelift
And the last of the S4's had the Hitachi MAF.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
OK, I had a mid-facelift S4 and it had all the external and internal facelift updates with the exception of the digital clock, which AFAIK means it didn't have the CAN-bus. Whilst this wasn't a problem for me, if you plan on installing a later RNS-D or E TFT screen, then it is a lot easier if you buy a car that already has the CAN-bus.
There are varying reports on whether it had the later oil lines (I think this was only post-2000 cars anyway) and updated manifolds (I believe it did).
ESP was an option on my car, but came as standard for later models.
I also have different dates for the mid-facelift - I thought they were from april to october/november 99??
HTH
HTH
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Surely the f-hose deletion was not done to all facelift cars?
Also I think the turbo improvement was ONLY to the oil lines, not the turbos themselves.
As well as the Hitachi MAF and the 4 lamda's, the whole engine is a revised version to meet newer EU emission rules.
2001 Silver S4 Avant
Nope, someone picked it up already, only the last of the S4's had it (or didn't have it)Surely the f-hose deletion was not done to all facelift cars?
AgreedAlso I think the turbo improvement was ONLY to the oil lines, not the turbos themselves.
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
- SimonS4MTM
- Top Gear
Hows this ???
Pre-Facelift
Flush fit door handles
Square side repeaters
Separate headlights and front indicators
Windscreen washers on bonnet
Analogue clock
Mid-Facelift
Once Piece Headlights and Indicators (not two separate units)
Rectangular side repeaters
Analogue clock
Air vent location lights
Double height symphony radio
Auto dip interior rear mirror
New interior light concept
Soft touch opening boot
New bootlid outline
Boot lock with cover
Reversing lights to the lower half of the rear cluster
Reshaped front and rear bumpers
Polished body-post trims
Curved door handles
Aluminum door-sill trim strips
Wider side protection moulding
Flush mounted headlight washers
New grille outline
Concealed windscreen washer jets (Not on bonnet)
New wiper arms
S4 badge moved from the top lip of the boot to next to the number plate
Bigger Turbo oil lines
Exhaust manifold was modified
Cover over battery compartment
Front & rear brake setups
Colour matched interior components
Heated seats switches move from high up to low down
AC controls different
Pushbuttons in dash are wide rather than tall
Audi ESP
Post-Facelist
High level brake light carpeted
Digital clock with date on the Dash
CAN-bus
2001
F-pipe was removed
Hitachi MAF
Different S4 badge on the back and dash
4 lambda Sensors
Pre-Facelift
Analogue clock
Mid-Facelift
Analogue clock
New bootlid outline
Curved door handles
New grille outline
New wiper arms
Audi ESP
Post-Facelist
CAN-bus
2001
F-pipe was removed
Hitachi MAF
4 lambda Sensors
- SimonS4MTM
- Top Gear
A few corrections
Pre-facelift
Plastic number plate suround
Solid rear discs
Mid-face lift
Symphony was an option, not standard
Auto dip mirror as an option on all models
Aluminum door-sill trim strips on all models
Only on RS4
New grille outline same on all models
Pre-facelift
Solid rear discs
Mid-face lift
Only on RS4
Few more ...
Heated seats was an option on all cars
Same for ESP, but don't think it was available on pre-facelift cars?
Also, front calipers/pads were different on some mid and post-facelift cars!
Recaros were an option for mid-facelift onwards AFAIK.
Typo on post facelist!
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
- SimonS4MTM
- Top Gear
I guess that you're only discussing UK cars? There were other options too, but only for personal imports:
Multifunction steering wheel
Rear acoustic parking sensors
