Hmmmm is it just me??!!!
hmmm...may get the dealer to look at mine then just in case.....will wait till I've got 1k miles on the clock then try again.....have found that it's not jerky if i reapply the throttle more gently on gearchange....but i'm trying to drive it like it should be driven, quick shifts and straight back on the throttle which works fine in the higher gears but gives me a kangaroo hop in 1st/2nd!!
Audijohn....if you've not taken the car to 6k revs in 1st/2nd then it probably won't be as noticeable......
Did my run in sort of by the book with a couple of indiscretions.djcevo wrote:It is definately the ESP kicking in very slightly, turn it off and this will not happen. If im taking someone out for a spin in my car I put S button on and take ESP off!!
Run mine in very hard and on the rolling road it produced the highest standard power out of a dozen the a tuner out on the rollers!!!! (this topic is a very individual thing - not critising anyone for their opinion by the way)!!
the issue with the stutter is solely down to the ESP. Turn it off and it goes away. Apparently its to save the transmission. The gearing in third and fourth + are long enough not to rip the diff apart on a full bore upchange.
berry100 wrote:hmmm...may get the dealer to look at mine then just in case.....will wait till I've got 1k miles on the clock then try again.....have found that it's not jerky if i reapply the throttle more gently on gearchange....but i'm trying to drive it like it should be driven, quick shifts and straight back on the throttle which works fine in the higher gears but gives me a kangaroo hop in 1st/2nd!!
Good point, but I will NOT in all probability use Ist gear much anyway, if on a hill or incline I use it, If not I don't use it at all, once away in 2nd, then I boot it with no probs.
Hmm fair point.....don't gun 1st that often myself but was just seeing how effective it was......audijohn wrote:berry100 wrote:hmmm...may get the dealer to look at mine then just in case.....will wait till I've got 1k miles on the clock then try again.....have found that it's not jerky if i reapply the throttle more gently on gearchange....but i'm trying to drive it like it should be driven, quick shifts and straight back on the throttle which works fine in the higher gears but gives me a kangaroo hop in 1st/2nd!!
Audijohn....if you've not taken the car to 6k revs in 1st/2nd then it probably won't be as noticeable......![]()
Jesus!berry100 wrote:I'll wait till i've put about 1800 miles on it then I'll give it a go with the ESP off......but not too often mind you if I'm in danger of buggering up the transmission!!
Drive it like you want to drive it, if the transmission cant handle the power then take it straight back to the dealer. What was this car built for again?
_______________________
07 Model Year RS4
04 996 Turbo SOLD
Agree........I don't hold back too much though......but am taking a 50/50 approach with it at the moment between gunning it and being sensibleisht_urbo wrote:Jesus!berry100 wrote:I'll wait till i've put about 1800 miles on it then I'll give it a go with the ESP off......but not too often mind you if I'm in danger of buggering up the transmission!!
07 Model Year RS4
04 996 Turbo SOLD
- alex_123_fra
True to an extent, however a degree of mechanical sympathy is required. This isn't in reference to this thread, but it does rather annoy me when people post along the lines of "I've been launching at 5,000+ rpm (or done lots of track days) and the clutch/gearbox went...I expect the dealer to sort it on warranty". It is a series of mechanical components and if you drive the tits off it all the time, it will break...as do race cars which are designed to take the abuse.t_urbo wrote:Jesus!berry100 wrote:I'll wait till i've put about 1800 miles on it then I'll give it a go with the ESP off......but not too often mind you if I'm in danger of buggering up the transmission!!
07 Model Year RS4
04 996 Turbo SOLD
Having said the above, on a production car the clutch will be the weak link, especially in a 4WD car. It will break far sooner than one might start damaging their gearbox. It is better to have cars back at the dealers with broken clutches rather than transmission failures. Saves the manufacturer a lot in terms of warranty claims for geaboxes.
Current: C7 RS6 - Black, VW Passat CC R36 - Black, Freelander 2 - Black
Sold: 911 C4S (991) - Black, Panamera Turbo ('11) - Carrera White, Nissan GT-R - DMG, B8 S4 - Phantom Black, B7 RS4 - Daytona grey saloon, Noble M400, Golf R32, Evo VIII MR, M3, Cooper S, Civic Type-R, BMW 120D (black), Mazda 6 MPS
07 Model Year RS4
04 996 Turbo SOLD
Manufacturers organise track days themselves, if the cars (in particular High performance cars like the RS4) could not handle a few laps of a track then they would not arrange such events.alex_123_fra wrote:True to an extent, however a degree of mechanical sympathy is required. This isn't in reference to this thread, but it does rather annoy me when people post along the lines of "I've been launching at 5,000+ rpm (or done lots of track days) and the clutch/gearbox went...I expect the dealer to sort it on warranty". It is a series of mechanical components and if you drive the tits off it all the time, it will break...as do race cars which are designed to take the abuse.t_urbo wrote:Jesus!berry100 wrote:I'll wait till i've put about 1800 miles on it then I'll give it a go with the ESP off......but not too often mind you if I'm in danger of buggering up the transmission!!
07 Model Year RS4
04 996 Turbo SOLD
When i purchased my 996 tt i got a free 1/2 a day at Bedford with a Porsche instructor to show you how to drive it.
Obviously general abuse is another matter.
07 Model Year RS4
04 996 Turbo SOLD
Exactlyaudijohn wrote:t_urbo wrote:Jesus!berry100 wrote:I'll wait till i've put about 1800 miles on it then I'll give it a go with the ESP off......but not too often mind you if I'm in danger of buggering up the transmission!!
07 Model Year RS4
04 996 Turbo SOLDYea if it blows it goes............................................. Straight back
07 Model Year RS4
04 996 Turbo SOLD
- alex_123_fra
Not disputing the fact that manufacturers arrange track days...I've been to events like these myself. As you say, general abuse and repeated track days are a different matter and if one's car breaks as a result of such inappropriate use, they should be responsible for the repair costs, not the manufacturer/dealer.t_urbo wrote:Manufacturers organise track days themselves, if the cars (in particular High performance cars like the RS4) could not handle a few laps of a track then they would not arrange such events.alex_123_fra wrote:True to an extent, however a degree of mechanical sympathy is required. This isn't in reference to this thread, but it does rather annoy me when people post along the lines of "I've been launching at 5,000+ rpm (or done lots of track days) and the clutch/gearbox went...I expect the dealer to sort it on warranty". It is a series of mechanical components and if you drive the tits off it all the time, it will break...as do race cars which are designed to take the abuse.t_urbo wrote: Jesus!
07 Model Year RS4
04 996 Turbo SOLD
07 Model Year RS4
04 996 Turbo SOLD
Users browsing this forum: Squadr0n_ and 314 guests
