Remove front badge
theaxe
Post by theaxe » Wed May 16, 2007 7:23 pm
For future searchers the answer to my question is as follows:
1. Release the clips holding the left hand side of the badge by passing your fingers through the grille.
2. The right hand side is just a catch so if you move the badge to the right it'll come free.
Job done!
Phantom Black '06 RS4 Saloon
Recaros, loaded (except ceramics & bluetooth).
hugy
Post by hugy » Wed May 16, 2007 7:48 pm
Hanbury,what's the point in having the RS4 if you need to disguise it! Be proud of it.I understand about the colour,as I have a sprint blue car (and love it).I think most people would know its the RS4 and not a 2.0 tdi.
RS4 B7 saloon,
Sprint Blue,
Sunblinds,
I pod socket,In dash multi cd.
Supaglass smoked tinted glass
MTM Bimoto Polished titanium alloys.
hanbury
Post by hanbury » Wed May 16, 2007 10:23 pm
I'm not 'disguising' but I'm also not 'advertising' what it is for the reasons I stated. I am proud of the car but I don't have it (or anything else for that matter) for what anybody else might think. I have it becuase I like it and that's all.
On a practical issue of removing the grill badge.... my car was delivered today de-badged as requested but there is a plastic plate for the grill badge which remains and appears integral to the grill itself. Anybody know different or if it can be removed? If not I may have to either see if I can get a replacement grill or a different badge of some sort ('quattro' maybe).
hugy
Post by hugy » Thu May 17, 2007 2:01 pm
You could fit a DTM badge.
RS4 B7 saloon,
Sprint Blue,
Sunblinds,
hanbury
Post by hanbury » Thu May 17, 2007 2:05 pm
No idea what a DTM badge is, sorry. But I have sussed the problem with the plastic plate - dealer had just un-stuck RS4 Badge when they shoudl have unclipped teh whole thing (muppets!). I've done it myself now!
Dom81
Post by Dom81 » Thu May 17, 2007 2:06 pm
How about an S-Line badge (if they're the same size...)
That way, you might just convince somone that's it's a sheep in wolfs clothing?
2007 Daytona RS4 Avant
hanbury
Post by hanbury » Thu May 17, 2007 2:08 pm
Thanks Dom but our posts must have crossed. No need for any badge now that I sussed how to remove the plastic plate.
Tony
S4_SAT
Re: RE: Remove front badge
Post by S4_SAT » Thu May 17, 2007 2:52 pm
theaxe wrote:I'll give it a tug tomorrow...
Hmm, you'll need some tissues for that. :lol:
S4_SAT
Post by S4_SAT » Thu May 17, 2007 2:53 pm
theaxe
Post by theaxe » Thu May 17, 2007 3:30 pm
hanbury wrote:On a practical issue of removing the grill badge.... my car was delivered today de-badged as requested but there is a plastic plate for the grill badge which remains and appears integral to the grill itself.
If it's the same as mine you can release the left side by squeezing the retaining clip from behind with your fingers through the grill. The right hand side should then come away.
eureka
Post by eureka » Fri May 25, 2007 6:13 am
When my car arrives in a month or so I'm considering removing all of the badges too (for maximum stealth mode). However, a question for those who have already done this: when you removed the badges from the rear doors doesn't it leave a blank 'box' in the door strip?
i.e. in here...
http://www.rs246.com/modules.php?op=mod ... 203&pos=60
...have you just left this blank or put something else in there? Or maybe a standard A4 door strip doesn't have this blank and could be used instead?
theaxe
Post by theaxe » Fri May 25, 2007 7:05 am
It does leave a blank space but I think that the standard A4 has it too.
If you're debadging yourself here's the technique I used:
1. Heat the badge with a hairdryer for about a minute.
2. Use dental floss to saw through the glue, then remove the badge.
3. You're then left with the sticky stuff. Remove what you can by hand.
4. The smaller remainder can be removed with WD40 and a cloth.
5. Once all of the glue is removed use some T-cut to remove any residue.
6. Put on 2 layers of wax and polish.
Mine came up perfectly, you'd never know the badges were there.
eureka
Post by eureka » Fri May 25, 2007 7:28 am
Theaxe - thanks for the reply and the info on how to remove the badges - much appreciated.
If the standard A4 has these blanks then I could live with it - but can anyone confirm if this is 100% the case? ('normal' A4s are few and far between in my neck of the woods - so, I can't check it out unless I travel 40mins to my dealer).
binder
Post by binder » Fri May 25, 2007 7:28 am
Just seen a debadged sprint blue Avant with standard S Line badges on the side trims.
hanbury
Post by hanbury » Fri May 25, 2007 7:42 am
I had all of the RS4 badges removed from mine prior to delivery and you're right I do have a couple of blank boxes but I don't think they look too bad and I don't think the casual observer would even notice there is something missing. I might consider putting some other badge in there but I have yet to see anything I would like.
A couple of tips if you are going to get the car de-badged by the dealer prior to delivery. i) tell them you want the badges (just in case one of the mechanics thinks it would be a good idea to raise a few bob on e-bay); and ii) tell them that when they take the front grille badge off you would like it taken off complete with the clip-on backing plate rather than just unsticking the badge from the plate and leaving a rather unsightly piece of black plastic (sounds obvious but this is how mine was delivered).
Users browsing this forum: Bing [Bot], Google Adsense [Bot], Majestic-12 [Bot] and 137 guests
