Fitting spacers and wheel bolts. Advice needed plz
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
william64
Post by william64 » Wed May 02, 2007 7:08 am
You will need to ge the correct seat on the bolt
OE wheels are radius and aftermarket inc reps are generally 60 deg taper
P W Motorsport offers both spacers and bolts
S4TAN
Post by S4TAN » Wed May 02, 2007 11:20 am
Yep - secured some 40mm bolts (my original ones are 25mm) off ebay - 60deg tapered M14x1.5 - 20 bolts for £24! Which was nice ...
Deus ex machina
MarkB
Post by MarkB » Wed May 02, 2007 11:39 am
S4TAN wrote:Yep - secured some 40mm bolts (my original ones are 25mm) off ebay - 60deg tapered M14x1.5 - 20 bolts for £24! Which was nice ...
Make sure the wheel still turns freely with the longer bolts fitted!
Mark
S4TAN
Post by S4TAN » Wed May 02, 2007 11:44 am
I did some measuring Paul - theres enough depth to take a 50mm bolt but i settled for 40mm as a good compromise ... :thumbs:
Deus ex machina
MarkB
Post by MarkB » Wed May 02, 2007 11:53 am
S4TAN wrote:I did some measuring Paul - theres enough depth to take a 50mm bolt but i settled for 40mm as a good compromise ... :thumbs:
Thats OK then Bob
Mark
S4TAN
Post by S4TAN » Wed May 02, 2007 12:12 pm
Thats OK then Bob
ooops :oops: sorry Mark - haven't had enough coffee yet today ... still half asleep!
Deus ex machina
MarkB
Post by MarkB » Wed May 02, 2007 12:20 pm
Thats OK :lol:
Mark
MCB
Post by MCB » Wed May 02, 2007 12:27 pm
Julian just a thought make sure the bolts don’t protrude from the inside face of the hub as they will rust fairly quickly and this will make them a bugger to remove.
S4B5 Avant
saf
Post by saf » Wed May 02, 2007 12:33 pm
Damn. I cant seem to get the whees I want in reps.
Instead I need to go for the B6 OEM wheels and use some 10 mm hubcentric spacers. I take it I will need the same sized bolts.
Im not sure to use 235 or 225 tyres. Ill be weidening the track already with the 10mm spacers on both sides, Just wanted the 235 for wheel protection. Just worried that it will stick out too much as 10 mm is quite a bit.
S4TAN
Post by S4TAN » Wed May 02, 2007 12:52 pm
Thanks for the tip mate - i will check when i get the bolts delivered ...
Deus ex machina
philipwalker
Post by philipwalker » Wed May 02, 2007 5:50 pm
The front bolt length is very critical too long and the wheel will not turn when done up.
As suggested above you will need radius seat bolt with OE Audi wheels
http://www.pwmotorsport.com
PW Motorsport
01437 563929
Users browsing this forum: No registered users and 92 guests
