H&R ARBs or AWE DTS?
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Which should I fit...H&R ARBs or AWE DTS?
H&R ARBs
23
77%
AWE DTS
7
23%
Total votes: 30
MarkB
Post by MarkB » Wed Jan 24, 2007 8:57 pm
reserves wrote:What's the model number of the larger ones? How hard is it to fit / get these fitted. I'm in the alps for the season so MRC is out of the question...
They are easy to fit, but running on snow etc I would rather have a softer setup. Should give more grip.
Mark
GrimReaper
Post by GrimReaper » Wed Jan 24, 2007 9:00 pm
to save a new topic does anyone know the length of the rear drop links as sure its plastic so want to replace it incase it breaks when uprating the ARB's. What about the fronts are they prone to breaking or aree they stronger ( sure i read some where they were metal)
KO4's Full Bilstein suspension, MRC custom remap Dual milltek, de pre-catted & custom Decats Forge DV's H&R ARB's, 18" RS4 Reps
Cayenne calipers B5 RS4 discs PICS: http://s8.photobucket.com/albums/a4/sjy666/Audi%20pics/
reserves
Post by reserves » Wed Jan 24, 2007 9:04 pm
Ok, i'm confused. I won't be here forever so want them to work well when I'm back in the UK.
Are the larger ones stiffer? I thought they were both adjustable?
I was just looking at improving the ride, for what seems a reasonable amount of cash.
SLC Detailing
Post by SLC Detailing » Wed Jan 24, 2007 9:16 pm
http://cgi.ebay.co.uk/H-R-rollbars-Audi ... dZViewItem
Are these the ones? Are these the larger ones that u reccomended?
Doug_S2
Trader (Expired)
Post by Doug_S2 » Wed Jan 24, 2007 9:40 pm
the stock plastic droplinks are fine - I run them on the thick rear arb with adapters to to give you a 3rd or 4th stiffer setting.
I cannot reommend the stiff arbs - if you only do one mod to the handling of the car, get them on. SPend 10 minutes adjusting th esnub mount to stop some engine/box moevement.
http://www.MRCtuning.com
MarkB
Post by MarkB » Wed Jan 24, 2007 9:46 pm
Doug_S2 wrote:the stock plastic droplinks are fine - I run them on the thick rear arb with adapters to to give you a 3rd or 4th stiffer setting.
Snub mount adjustment! first time I've heard that. Please tell...
And I assume you can't recommend the ARB's 'enough'
Mark
SLC Detailing
Post by SLC Detailing » Wed Jan 24, 2007 10:04 pm
@Doug are they the same ones as the ebay link or different?
Are they relatively the same price as the ones u supply?
clubsport
Post by clubsport » Wed Jan 24, 2007 10:28 pm
Thanks guys, I am liking the idea of these...... :)
I feel comfortable with my car up to 7/10th's, after that the handling makes the whole thing less fun....these arbs seem to be the answer.....I was likely to do DTS anyhow. :)
2000 B5 S4 facelift, sadly missed...enjoying the 2005 A2 TDi Special Edition though!
droberts
Post by droberts » Wed Jan 24, 2007 10:50 pm
Can't remember exactly how bad body roll was pre-ARB's, but they transform the handling of the car, I've still got standard dampers fitted but the ARB's are enough to inspire confident cornering :)
...go for the thick bars on full-hard settings
Milltek dual cat-back, gutted downpipes, ECS Tuning stage3 brakes, MRC custom map, H&R ARBs.
philipwalker
Post by philipwalker » Wed Jan 24, 2007 10:51 pm
stevieyid wrote:http://cgi.ebay.co.uk/H-R-rollbars-Audi ... dZViewItem
These are the thicker of the two available S4 anti-rollbars kits. These are in stock for next day delivery. If you order directly I will throw in the carriage.
Give me a ring when you are ready
Philip
01437 563793
http://www.pwmotorsport.com
PW Motorsport
01437 563929
S4TAN
Post by S4TAN » Wed Jan 24, 2007 11:40 pm
Totally second that - when i got my ARBs put on it completely transformed the cornering handling of the car ... excellent mod.
Deus ex machina
SLC Detailing
Post by SLC Detailing » Thu Jan 25, 2007 12:05 am
So the thicker ARB's and the H+R coilovers and the car should have brilliant handling? Am i right? My s2 at the moment feels like a tank, but the UR which has Konis and HR's feels a lot crisper
S4TAN
Post by S4TAN » Thu Jan 25, 2007 12:11 am
Well I went for the 'poor mans' version of coilovers: I just got the H&R Sports springs and had them put on the stock dampers - had the H&R ARBs (thick, stiffest setting front and back) done at the same time ... the handling went from spongey and vague to hard, sharp and precise.
Deus ex machina
SLC Detailing
Post by SLC Detailing » Thu Jan 25, 2007 12:13 am
Sounds just want i am after. Hopefully with that and a good brake set up the car would just what i am after. Is there much handling difference between the avan t and the saloon?
S4TAN
Post by S4TAN » Thu Jan 25, 2007 12:21 am
don't know - i've got a saloon and i've never driven an avant - no doubt an avant owner will be along shortly to tell you ...
Deus ex machina
Users browsing this forum: No registered users and 36 guests
