RNS-E Installation into a B5 RS4
reserves
RE: Re: RE: RNS-E Installation into a B5 RS4
Post by reserves » Mon Feb 12, 2007 2:09 pm
OK, found loads of pics and install stuff over at http://www.navplus.us/forum/viewtopic.p ... sc&start=0 :)
One I really need to know the answer to.
I know I have to get a double Din adaptor, BUT is the whole centre console specific to Double/Single DIN, or just the cage inside?
bobbler
Post by bobbler » Wed Mar 21, 2007 10:34 pm
Would this be the same on the S4 B5? I am looking at various audio/satnav/bluetooth options at the moment and havent bough the car yet :)
What are the alternatives for a smart finish that wouldn't look out of place in the dash area?
Most of the stuff like the Pioneer and Alpines are full of blue LED lights which would look a little odd IMO.
. S4 Nogaro Blue Avant . ECS IV . RS4 handling bits . 18" Ultraleggera . AWE Boost Gauge . MRC Custom Map . 315 BHP . 482 Nm .
reserves
Post by reserves » Wed Mar 21, 2007 10:40 pm
Search the electronic section for 'Becker'
The S4 & RS4 are almost identical in terms of interior, the stereo / sat nav options are exactly the same.
bobbler
Post by bobbler » Wed Mar 21, 2007 10:44 pm
Ah, many thanks. Beckers a name I have heard of before and they certainly produce good sounds thats for sure. Cheers muchly
reserves
Post by reserves » Sat Apr 14, 2007 5:32 pm
Just in case anyone stumbles here, the B5 single DIN center console IS different to the double DIN!
I think it might be possible to cut the single DIN one to fit, but it's only 65 pounds or so from Audi.
jb7_uk
Post by jb7_uk » Mon May 07, 2007 4:31 pm
Hi Guys, long time no see...
So, i take it no one has even attempted to try and shoehorn an RNS-D or E into a PRE-facelift dash? Too many obstacle sto overcome for it to be worthwhile / cost effective???
JB7.
FOR SALE :cry: :
B5 S4 - 1999 (Pre-Facelift) - Ebony Black Pearl - 18" RS4 (B5) Reps - 710n's - replaced N75 - After-run Pump mod - APR Bipipe.
See Classifieds ad (HERE) for more details.
ajsl
Post by ajsl » Thu May 17, 2007 11:47 am
About how much are we looking at to put RNS-E into a CAN Bus enabled RS4/S4?
reserves
Post by reserves » Thu May 17, 2007 12:12 pm
RNS-E A6 Unit with GPS Aerial and nav DVD £400-£500
canGate £70 (fixes clock issue)
Wire Harness £45
Access to VAG-COM full version
Some time and patience
This is if you have a Double Din setup already, otherwise
Double Din Centre console £80 (new)
Double Din Cage £150 (new)
Double Din Air Con unit £300 (new)
Double Din gearstick surround (depends on finish)
Double Din ashtray (£40 new ?)
R
The Nav unit is good including TMC and works flawlessly in my B5 S4.
ajsl
Post by ajsl » Thu May 17, 2007 1:08 pm
Ouch! The prices look good.. If you have a double DIN, which I don't. Ah well.
jb7_uk
Post by jb7_uk » Thu May 17, 2007 1:16 pm
D'Oh !! same here ajsl... kinda makes me wish i'd held on for a facelift S4 rather than falling head over heals for the one i ended up buying :P Not to worry though.
FOR SALE :cry: :
reserves
Post by reserves » Thu May 17, 2007 1:19 pm
To cut down on costs you can:
Modify single DIN center console
Modify Air con unit
Cut gearstick surround
I didn't do this, ended up picking up parts from Ebay over 6 months.
g60bv
Post by g60bv » Wed Feb 06, 2008 1:13 pm
i know this is an old thread. but hows it all looking in your cars. i want to update my onsole ith a 'desent' head unit. pref audi, but have no idea what a CAN is or the BUS connector is. all i have is the single tape player and a 6cd in the boot. 98' b5 stuff. help.
ian.
MRC TUNED 480BHP . -SOLD 1.9TDI AVANT 215HP. HYDBRID TURBO. SMOKING
TDiAvant
Post by TDiAvant » Wed Feb 06, 2008 1:36 pm
Question, do you have digital dash clock? If not you going to have to buy a wiring harness with a can-bus emulator. These can be purchased from Kufatec. If you do have the digital clocks then you can get the can-bus High & Low from the instrument cluster, but you will have a problem with the time being out on the Audi navigation if you fit one. To get around the time problem you can buy can-gate adaptor from a guy on navplus, or you you could just use the can emulator from kufatec, as this does not provide time information on the can-bus, so the navigation unit gets the time from GPS.
Also if you don't have a k-line (diagnostic wire) going into the radio like on my old b5, you will need to run that wire from the instrument cluster or the diagnostic port.
g60bv
Post by g60bv » Wed Feb 06, 2008 2:15 pm
i have the non digi clock. see pic.
is there any where or any one whos good with these to make it all work. i wanted to go the breakers and get a face lift console double dine and switch gear to swap. ( the ones with th e cup holders in)
is this poss.?
TDiAvant
Post by TDiAvant » Wed Feb 06, 2008 4:42 pm
So you will need the can-bus emulator, but trying to find the double din cage second hand is almost impossible, I've been looking for months. If you what this done quickly then your going to have to buy the bits new.
I also need the bits for my B5 A4 I could see if the dealer would be will to do a discount for 2 kits, I've also got a trade account with kufatec, so I should be able to get the can-bus emulator cheaper.
Return to “Electrical”
Users browsing this forum: No registered users and 52 guests
