I now...
You're in good company Brooner!Brooner wrote: i'm a bit of a mechanicl <beep>
what a lovely peice of work. Well done.Brooner wrote:Never thought of that to be truthful this the way that jim said to go i don't know if there would be a problem removing the hub?? a asume that this was the easyest way to go but i'm a bit of a mechanicl <beep> so i was totaly in his hands. It hasant made any balance probs that i'm aware of we are talking 12mm out of the hub which is a very small peace of metal. thogh in retrospect the removingthe hub would be a more straght forward option.
On reflection from my experience of replacing the rear wheel bearing on my S4. The hub is pressed into the inner races of the wheel bearing and requires a significant force to remove it, typically a hydraulic puller. As there are two inner races to the wheel bearing I think if Jim had tried to remove the hub, the outward side of the inner race would probably have stayed stuck to the hub. If Jim didn't then remove the inner race from the hub he wouldn't know if the bearing seal had been reset correctly upon bolting the hub back together.shineydave wrote:couldn't you just undo the centre bolt in the hub and remove it to prevent having to grind the hub and risk throwing it out of balance?
How did you get on Patrick?Golich wrote:That's interesting. I'm going to try my mates RS6 tomorrow to see if this is a common feature.rs666 wrote:I get the soft start to the peddle on my RS6, bleed and refilled a couple of times with no change.
which sounds cheap considering cost of parts listed above doesn't it?From memory, when I had the B7 calipers & discs fitted by MRC, it was about £1200.
That's just the front's, but still good value compared to Movit, AP etc.neckarsulm wrote:which sounds cheap considering cost of parts listed above doesn't it?From memory, when I had the B7 calipers & discs fitted by MRC, it was about £1200.
