Short Shifter fitted! very short!
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
mikeyquattro
Post by mikeyquattro » Thu Apr 13, 2006 6:50 pm
Fitted my ss in about an hour.
LUSH!!
Put it on the shortest setting, bit notchy, but well happy for minimal ££
Tomorrow is another day
tricky
Post by tricky » Thu Apr 13, 2006 8:10 pm
mikeyquattro wrote:Fitted my ss in about an hour.
LUSH!!
Yeah I think I am going to stick with the shortest setting for the moment
s4-99 wrote: Thanks Rich, i've sent you a PM
No PM received??
s4-99
Post by s4-99 » Thu Apr 13, 2006 9:30 pm
I must have done something wrong before :oops: PM now sent, thanks.
s4-99
Post by s4-99 » Sat Apr 15, 2006 6:15 pm
Well i fitted my short shifter yesterday which i bought from ebay. Thanks Rich(tricky) for the help :thumbs:. I set it on the shortest setting, it has made a big difference. It will take a few miles to get used to, i can live with that though :kissmyrings: The gear change is stiffer and feels very tight, 1st to 2nd gear is a little notchy nothing major though. Overall i'm very pleased with it. I was going to pay over £200 for one from AMD or the like, but for £46 delivered it's a bargain. It really is a good mod to do if you have'nt already done so 8)
tricky
Post by tricky » Sun Apr 16, 2006 7:40 pm
Glad to hear it all went together ok, not really that bad, instructions just don't look that clear - but are. Agreed 1st-2nd isn't the smoothest but after that it's fantastic
droberts
Post by droberts » Tue Apr 18, 2006 1:03 pm
LUSH!!
Blimey MikeyQuattro, very impressed you fitted in an hour... took me approx 4 times that!!! Fitted it yesterday... what a fiddle, lost count of the number of times I lost the change rod plate underneath the linkage when reassembling, I even managed to lose one of the bolts down the gap between the linkage housing and exhaust :oops: I had the linkage in and out about 4 times (the air was blue)!
A few notes
1. don't start this job if you've spent all weekend on DIY, and are already tired and brassed off - leave yourself plenty of time (and daylight!)
2. Front reverse pin is VERY tight (you'll need a rubber mallet), which is just as well as my kit didn't include the "nylon rivet" (probably a design change?)
3. The kit's metal push down pin was too tight, once "clicked" into position it didn't allow you to "push down". I used the OEM plastic push down pin instead - no problem.
Impressed with the short throw, bit notchy but OK :thumbs:
Milltek dual cat-back, gutted downpipes, ECS Tuning stage3 brakes, MRC custom map, H&R ARBs.
MarkB
Post by MarkB » Tue Apr 18, 2006 1:25 pm
Did you do for the shortest setting?
Mark
mikeyquattro
Post by mikeyquattro » Tue Apr 18, 2006 1:32 pm
Droberts. Careful use of clothes hanger to hold everything in place is the key. I also used the original plastic pin.
Mike
ZeroK66
Post by ZeroK66 » Tue Apr 18, 2006 3:17 pm
Many comments on notchy... :(
My gear change is already notchy at the best of times and often find myself cringing when driving with enthusiasm... did everyone have slightly notchy changes before the kit was fitted?
MarkB
Post by MarkB » Tue Apr 18, 2006 3:33 pm
I wouldn't call my standard shift notchy. Quite stiff when cold but soon loosens up. Still haven't got around to fitting my short shifter yet so can't comment on that!
Mark
mikeyquattro
Post by mikeyquattro » Tue Apr 18, 2006 4:02 pm
My shift was quite notchy before the clutch went!!
Then it was very easy to get gears, but sloppy
then after the shifter mod, it's notchy!
HTH
Mike
rolskii
Post by rolskii » Tue Apr 18, 2006 5:24 pm
Well as I said guys, I had issues with both i have fitted and driven on......
Lets hope your plastic bucket with nipple stay intact, otherwise you may get some rotation on the stick and bugger up the reverse gate or selector....
thats why I wrote about opening up the groove with a dremmel to allow use of more durable product in kit.... :roll:
Both were notchy, but loosened up in time, silicon grease is good to go on shifters... :assflash:
blue tack for selector bolts below access points .. and coat hangers...
just as david said... daylight - not tired or narked .... :lol:
tricky
Post by tricky » Tue Apr 18, 2006 7:28 pm
Have run mine for a month now on shortest setting, becomes natural and I wouldn't change it.
mikeyquattro
Post by mikeyquattro » Tue Apr 18, 2006 7:32 pm
tricky wrote:Have run mine for a month now on shortest setting, becomes natural and I wouldn't change it.
Same goes for me
droberts
Post by droberts » Tue Apr 18, 2006 8:23 pm
Yep, have mine on the shortest setting. As previously suggested, it took a day to get used to. I just need to adjust the stick a bit further back towards the driver to achieve perfection.
ZeroK66 wrote:Many comments on notchy... :(
My std linkage was a bit stiff selecting first, and my wife always had trouble getting reverse. In hindsight, notchy is probably not the right word... it's a positive change, slightly noisier, you have to be more assertive with the stick movement and you'll feel the change in the palm of your hand.
Overall, it's more rewarding to use than std, but not recommended for Sunday drivers 8)
(Rolski - had read your previous comments, but don't own a dremmel and by then the DIY stores were closed...)
Users browsing this forum: No registered users and 93 guests
