Drive Train Shock!!
RE: DTS or snub mount?
I am thinking the DTS then at a later date getting the snub mount replaced - when the front end comes off for an IC upgrade etc
There were some concerns on AW with the DTS solution in the event of an accident - this was around the gearbox being designed to be pushed downwards in a frontal impact - clearly, the DTS would prevent this to some extent. I thought I'd share this, what what it's worth.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
The standard car has a bar under the gearbox anyway... I think the changes would be minor surely?
but the bar under the gearbox aint fitted to the gearbox..and minor is an understatement..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
Re: RE: DTS or snub mount?
i guess there aren't any real world tests that have been done, good thing to keep in mind though thanks for thatNige_S4 wrote:There were some concerns on AW with the DTS solution in the event of an accident - this was around the gearbox being designed to be pushed downwards in a frontal impact - clearly, the DTS would prevent this to some extent. I thought I'd share this, what what it's worth.
RE: Re: RE: DTS or snub mount?
Ha! With all those horses under the bonnet, I can't believe you guys worrying about "in the event of an accident will my engine/gearbox not slide under the car because of my DTS"!
2001 Silver S4 Avant
Re: RE: Re: RE: DTS or snub mount?
what do you mean Dippy? engine/gearbox is a component of the car crumple mechanism so i thought that was a valid pointDippy wrote:Ha! With all those horses under the bonnet, I can't believe you guys worrying about "in the event of an accident will my engine/gearbox not slide under the car because of my DTS"!
RE: Re: RE: Re: RE: DTS or snub mount?
I can't see how an AWE DTS can make much difference to engine/gearbox deflection in a head on accident. It connects to the gearbox with a rubber bush ?
As I understand it the DTS has a weak point deliberately designed into it just for this reason.
99 FL, Reflex Silver, H&R Coilovers and ARBs, AWE DTS, Miltek Duel Cat Back, Hyperboost DVs, Autometer Boost Guage, RS4 18" Reps, Tanoga SS, Lecky SR, Nappa, Bose, Cruise, Phatnoise, MRC Custom remap, RS246 Sticker.
Yes - audi safety system called "defon 10" isnt it ...? had it on earler cars with seat belt inertia tensioners....
personally Im keeping my ground clearance - its scarce enough as it goes......
also if I had another tit T-bone this car like the tit did my last one, about 55-60mph(combined speed) head on.... I wouldnt want the engine going anywhere except down, that impact ripped my engine and snapped my gearbox mounts ... both ... and stuffed both the flexis flat on my downpipe to the ground .... snub is good way for safety too ....
... just my 2p on it all ..
