Brake ducts..
TarmacTerrorist
Post by TarmacTerrorist » Mon Oct 10, 2005 3:50 pm
Cool, I have no splash gaurds so cant fit mine atm...
They are only £20 from the vw dealer, bargain. And like Dave says better than nothing.
One word of caution though.
I would not wholy recommend these for cars with starndard solid discs on (grooved, drilled fine). The splash guards are there for a reason, which is to try and stop a layer of water building on the surface of the discs causing momemtary loss of brakes on the first contact with the pedal, e.g emergency braking on a wet motorway. By fitting these ducts to the standrad disc set-up you may inadvertently make the problem worse.
Some modern cars actaully apply the brakes themselves in order to dry the discs off without the driver even knowing.
Too much is bad.
Plenty is better.
RS4ever
Post by RS4ever » Mon Oct 10, 2005 4:04 pm
TarmacTerrorist wrote:Cool, I have no splash gaurds so cant fit mine atm...
The VW splash guards are £8.75 each.
TarmacTerrorist
Post by TarmacTerrorist » Mon Oct 10, 2005 5:54 pm
Another bargain!
Thinking about it, for those with solid rotors. If the splash guards are only held on with 2 bolts then you could have 2 sets one modified with the ducts. Then on track days switch them over, should take no more than 5 mins each side.
Too much is bad.
Plenty is better.
RS4ever
Post by RS4ever » Tue Oct 11, 2005 6:15 pm
Good idea. But a bit more than 5mins. You have to remove the pads, remove the disks and onlky then unbolt the splash guards.
Quick job with Movit or AP, but standard calipers are so fiddly to remove pads.
derdle
Post by derdle » Wed Dec 14, 2005 10:46 am
Since this posting back in October ... has anyone else fitted these? And DaveP - any further feedback/problems etc?
Nige_RS4
Post by Nige_RS4 » Wed Dec 14, 2005 10:58 am
I fitted them to my S4 prior to Donnington - they went straight on (obviously needed to cut the splash guards slightly).
PhilT
RS246.com
Post by PhilT » Wed Dec 14, 2005 1:30 pm
Had mine on for a while, highly recommended upgrade :thumbs:
Nige_RS4
Post by Nige_RS4 » Wed Dec 14, 2005 2:09 pm
Forgot to say that they do rub on the inner (plastic) arches slightly when on full lock, but they are only plastic and bend quite easily.
Nige_RS4
Post by Nige_RS4 » Mon Jan 23, 2006 1:11 pm
A possible alternative if you can find a route for the ducting from the front of the car ... http://www.purems.com/products/description.php?II=929
Nige.
dodgydave
Re: Brake ducts..
Post by dodgydave » Mon Jan 30, 2006 8:29 am
DaveP wrote:Finally got around to installing the Phaeton ducts today...bit of modifying required, but a pretty easy job...
Pretty happy, with the Movits it looks like the air is being directed into the correct place...
Just done mine the weekends. I drive drilled 365x34 with 8 Pot RS6 Callipers. I didn't need to cut the top bit though. Looks much more original this way. Did a few brake tests from 290km/h to 80 km/h and could immediately feel a huge difference. Also the brakes seem much more responsive too. But that might be also partly down to me cleaning those drill holes. ;-)
But all in all highly recommended upgrade! :D
RED_ROCKET
Post by RED_ROCKET » Tue Jan 31, 2006 2:54 pm
Brilliant! Thankx :biggrin3:
993 Gt2 - Mid life crisis
RS4 B5 -(Disappeared)
Q7 - Family wagon (RIP)
s4woody
Post by s4woody » Tue Jan 31, 2006 6:14 pm
well i,ve just ordered a set for my S4..there,ll be here by next week and i,ll fit them asap..i,ll take sum pix and post em with a brief description of any probs i mite encounter... :thumbs: :redrs4:
GARTH ROAD MOT CENTRE LTD
020 83353032
derdle
Post by derdle » Thu Feb 02, 2006 2:29 pm
Had mine done yesterday. Kim at QST fitted them while other work was being done. He noticed that the cut backing plate is quite flimsy and on full lock the metal touches the disc* (might cause scoring?). The cause of the deflection was a bolt at the bottom of a suspension arm/link - Kim pulled the bolt out and put it back the other way so that the bolt head was towards the front of the car - this stopped the fouling and stopped the backing plate touching the disc.
(*Movits380x32's).
Paul
s4woody
Post by s4woody » Wed Feb 15, 2006 2:49 pm
how much did u cut nige..as much as dave p did in his picture..doin mine this sat and wanna be prepared.. :thumbs: :redrs4:
020 83353032
Nige_RS4
Post by Nige_RS4 » Wed Feb 15, 2006 2:58 pm
I will try and get a picture of them - not much according to my garage.
Nige.
