Boost Pressure
911TT_STEVO
- 2nd Gear
robobeastt
Hi zeke ... you just have to think of a column of air right above of your car ... and air also weights, specially when you have 2kms of it over your head
.... this column will be somewhat taller/thicker when you are at sea level than when you are above 2400 mts at Mexico´s City .. that is why .... also air is thicker at sea level so it´s easier for turbos to condense intaking charges.... hope you get the idea ....
I don´t know if your engines can have manual boost controllers on your engines (maybe twin controllers so as to connect each turbo) but i know that on 1.8T they work great
.... in that way you can push up your boost at Mexico City but then need to readjust the valves when going down to the coast ....
Cheers & see you around
