croft and broken turbo
DaveP
Post by DaveP » Thu May 05, 2005 8:07 am
Hope it comes back fully sorted mate...I actually thought the replacement would be closer to 5k, it's actually got me thinking about warranty costs vs replacement turbo costs now !
DaveP...
Audi Allroad - Daily slogger
S1 Exige - Track beast
DavidT
Post by DavidT » Thu May 05, 2005 8:32 am
Steve,
How soon after the FMIC install did the turbo fail? and was the system pressure tested properly ?
Worth checking because if you had a leak it could have contributed to the turbo failure. The new ones may not last long either, if the issue still exists.
David
stevesmee
Post by stevesmee » Thu May 05, 2005 9:44 pm
turbo failure occurred at 750 miles after FMIC fitted! i will check with QST tommorrow about pressure test, i'm guessing that i will have some sort of warranty on the new turbo's, i will check that as well, am i correct in expecting a warranty?
steve
stevesmee
Post by stevesmee » Thu May 05, 2005 9:51 pm
DaveP wrote:Hope it comes back fully sorted mate...I actually thought the replacement would be closer to 5k, it's actually got me thinking about warranty costs vs replacement turbo costs now !
i was quoted £4800 + vat by audi garage after they told me i was not covered by warranty! i didn't expect them to really, considering i did not have current warranty (due to audi current warranty issues), they did recover me from croft to canterbury as goodwill, i can't knock them for that.
steve
DavidT
Post by DavidT » Thu May 05, 2005 10:03 pm
Boost leaks are a (the?) biggest factor in turbo failure. The Standard RS4 pipework is excellent, boost leaks are rare IMHO, I'd want to be assured by the supplier that this failure was not of their making and that all will be well with the new turbos.
bjacks
Post by bjacks » Fri May 06, 2005 9:13 am
Is that because the turbos are working harder to produce the same required boost due to the leak?
Is there any way a leak could be diagnosed via software? I know you can log requested/actual boost etc, but can you see how fast the turbos are spinning to see if they are working harder than they should be?
Cheers lads,
Ben
DavidT
Post by DavidT » Fri May 06, 2005 10:18 am
Yes, that's exactly why. If they work outside their operating tolerances too much for too long, they can be damaged.
Not sure to be honest, hopefully someone confirm.
Best way is a pressure test.
Dippy
Post by Dippy » Fri May 06, 2005 12:26 pm
MAF would be higher than normal. However unless you have already logged this or are very sure of what MAF to expect, it will be difficult to determine. You could get some figures from other members and compare to yours.
2001 Silver S4 Avant
stevesmee
517.5 bhp
Post by stevesmee » Fri May 20, 2005 8:33 pm
car now back from qst, new dyno done now producing 517.5 bhp!!!
well pleased. now looking for custom re-map, any suggestions?
DavidT
RE: 517.5 bhp
Post by DavidT » Fri May 20, 2005 9:12 pm
Steve,
Glad you have your motor back. Bhp figure is exceptional.
What did they say about the turbo failure ?
alastairg
Re: 517.5 bhp
Post by alastairg » Mon May 23, 2005 5:37 pm
stevesmee wrote:car now back from qst, new dyno done now producing 517.5 bhp!!!
MRC tuning
