What Power to expect
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
S2tuner
Trader (Expired)
RE: Re: RE: What Power to expect
Post by S2tuner » Fri Jan 21, 2005 8:58 pm
1781cc, yes. Apparently the last iteration that we've done revs up to 8500 RPM (solid lifters there) and runs like nutz.... dyno graph tomorrow I hope, I'm more than curious. I'll ask the guy to measure some 100-200km/h or quarter mile times to see if the figures make sense... the driveline losses sure don't look outrageously high or anything like that at least...
Mihnea
jeffw
Post by jeffw » Fri Jan 21, 2005 9:04 pm
Mihnea
What would you expect from a S4 with K04s and a full Milltek exhaust (with cats) running a remap and 98 Octane ?
S2tuner
Trader (Expired)
Post by S2tuner » Fri Jan 21, 2005 9:34 pm
Jeff: if it's just K04's, no IC mods, no fuel pump/fuel pressure regulator mods, I'd say around maybe 350? The limiting factor is the fuel pump and the ICs on the S4...
HTH,
Mihnea
S2tuner
Trader (Expired)
Post by S2tuner » Fri Jan 21, 2005 9:36 pm
Sorry for not replying earlier Nige,
The RS4 fuel pump or a Bosch Motorsport unit (flows even more) is good enough for 480-500HP IMHO/IME.
The 5 Bar FPR won't bring anything on a stock fuel pump, as it's the pump that can't provide the fuel flow at the top end, so by raising fuel pressure you'll be able to have more fuel in the mid-range, but at the top end the pump will be working even harder and fuel pump failure could be expected...
Either mods won't bring any benefits without a remap, especially if the remap is already running the fuel system at its limits...
HTH,
Mihnea
Nige_S4 wrote:Mihnea, what fuel pump would you recommend - the RS4 pump or 5bar FPR?? And are there any benefits of fitting one without a specific remap?
Nige.
Verruckt
Post by Verruckt » Fri Jan 21, 2005 9:52 pm
Yes Mihnea, it is generally accepted that the MAHA is a better dyno and shows lower figures.
And yes, we both know it's a great mystery when it's measured at the wheels. :)
-2001 Audi S4 biturbo (K16/K04 goodness @1.6 bar)
-2005 Golf V TDI PD
-1999 Jeep Cherokee Classic 4x4
www.NogaroBlue.com
S2tuner
Trader (Expired)
Post by S2tuner » Fri Jan 21, 2005 9:56 pm
@Chris: I've never experienced Maha/Bosch dynos to read lower. When I tuned an RS4 on a Bosch, it did 381 HP/445Nm stock (factory rated 380 HP/440Nm) at the flywheel.
Hey, still gotta get back to your email, will do that ASAP ;)
Mihnea
jeffw
Post by jeffw » Fri Jan 21, 2005 10:20 pm
Mihnea
I have a Maha dyno run in front of me for just that spec which is 351 BHP & 566Nm.....What would you expect if the Injectors and Fuel Pump where changed (assuming a remap)?
Dippy
Re: RE: Re: RE: What Power to expect
Post by Dippy » Mon Jan 24, 2005 3:18 pm
jeffw wrote:Mihnea
Don't you mean 97?
2001 Silver S4 Avant
jeffw
RE: Re: RE: Re: RE: What Power to expect
Post by jeffw » Mon Jan 24, 2005 4:21 pm
Optimax is 98 ....not really going to make that much difference though.
Dippy
Post by Dippy » Tue Jan 25, 2005 1:45 pm
Shell don't quote a RON for Optimax do they?
jeffw
Post by jeffw » Tue Jan 25, 2005 3:06 pm
Yes they do.....a RON of 98.
Nige_RS4
Post by Nige_RS4 » Tue Jan 25, 2005 3:57 pm
This should clear it up ....
http://www.shelloptimax.co.uk/jive3/thr ... 9&tstart=0
Edit - this is even more interesting - marketing hype?
http://www.millersoils.co.uk/pdf_downlo ... octane.pdf
Dippy
Post by Dippy » Wed Jan 26, 2005 1:57 pm
Thanks Nige, that settles the matter. If someone at Shell is prepared to state that Optimax is refined to between 98 and 98.5 RON then why don't they f***ing state it at the pump!
