Milltek cats & downpipes.....again!
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
KayGee
Post by KayGee » Thu Jan 13, 2005 1:30 pm
Stock to Stage 2. Full exhaust plus remap.
DavidT
Post by DavidT » Thu Jan 13, 2005 1:50 pm
You guys really spend too much money on tuning in Europe.
I've not spent anything in this area yet
Did you get my email Verruckt? ;-)
S2tuner
Trader (Expired)
Post by S2tuner » Thu Jan 13, 2005 1:52 pm
Totally agreed with Chris on this one, gutting the pre-cats works almost as good as doing expensive downpipes, and removing the cats is always an option too, but on 2000+ cars the ECU needs to be programmed so it accepts the no cat condition with no fault codes.
HTH,
Dippy
Post by Dippy » Thu Jan 13, 2005 1:58 pm
Verrückt wrote:You guys really spend too much money on tuning in Europe.
Remove the "on tuning" and your sentence is correct. Prices in Europe (and particularly the UK) have always been much higher for the same thing than in the US.
Exactly what is included in each tuning stage varies by supplier, however I think for a B5 S4 it should be roughly:
Stage I: Remap only (may include cat-back but the difference is negligible)
Stage II: Modifications to the 'breathing' i.e. free-flow cats, and corresponding remap (of course should include cat-back too).
Stage III: Uprated turbos, air intake and fuel injection.
Stage IV: Engine work (heads, cams, manifolds etc).
Typical prices for stage I are £500 to £1500 depending on which tuner and if you have a cat-back.
For stage II you are looking at another £1000 to £1500.
My advice is that if you have a stage I and then go back to the same tuner for stage II then your remap should be free.
Moktoya, you asked for advice on getting a new map. I suggest you take your car for some test runs and consider very carefully:
1) Do you feel ANY loss of acceleration up to the redline (remember how the stage I felt?)
2) Does the oil temp really rise a lot after driving around using a lot of high revs?
If the answer to either is yes, then your map is not taking full advantage of the exhaust system. You REALLY should have flat acceleration to the redline. Also part of the reason for adding fuel at the top end is for cooling - if the turbos get too hot it affects their efficiency. I'm sure that our resident gurus can expand on that...
2001 Silver S4 Avant
Verruckt
Post by Verruckt » Thu Jan 13, 2005 2:10 pm
Yes I did and I apologize for not replying yet. I just got back to Europe and have a lot of things to catch up on. Thanks. :D
-2001 Audi S4 biturbo (K16/K04 goodness @1.6 bar)
-2005 Golf V TDI PD
-1999 Jeep Cherokee Classic 4x4
www.NogaroBlue.com
DavidT
Post by DavidT » Thu Jan 13, 2005 11:15 pm
No worries. Let me know when you are ready :thumbs:
Apologies for hi-jacking the thread.
Nige_RS4
Post by Nige_RS4 » Fri Jan 14, 2005 10:15 am
HTH,
Mihnea / Veruckt,
Are there any DIY guides for gutting the pre-cats? Looked on AW and can only find basic stuff? Is there anything to watch out for when doing it i.e. will the O2 sensors needs relocating?
Cheers, Nige.
Mik
Post by Mik » Fri Jan 14, 2005 10:39 am
Interesting re gutting the cats, however would that not cause higher emissions - i.e. potential failed MOT etc.?
Mik
2014 Suzuka RS6
Verruckt
Post by Verruckt » Fri Jan 14, 2005 11:27 am
HTH,
Mihnea / Veruckt,
Cheers, Nige.
Yes, you will need to re-locate the secondary O2 sensor to just beyond the main catalyst otherwise you will cause a warmup catalyst efficiency code.
Otherwise, there isn't much of a procedure. Take the downpipe off and ream out the pre-cat material using a high speed drill of sorts and remove as much as you can. Here is a picture of the finished product.
Mik wrote:Interesting re gutting the cats, however would that not cause higher emissions - i.e. potential failed MOT etc.?
Mik
No, you will be fine. Gutting the pre-cats (main cats intact) only effects emissions slightly on cold starting. Once the car is warm (when emission measurements are taken), it will be the same as any normal S4.
Aftermarket downpipes are basically the same thing with the pre/warmup catalysts removed. This is where most of the power gains from downpipes come from.
-2005 Golf V TDI PD
www.NogaroBlue.com
S2tuner
Trader (Expired)
Post by S2tuner » Fri Jan 14, 2005 12:03 pm
Mik, what do you think the problem would be then with Milltek downpipes that have no precats at all, and only metal main cats, that from a cat standpoint, are less efficient to do their job??? No, you won't fail MOT!!! :)
Mik
Mik
Post by Mik » Fri Jan 14, 2005 12:08 pm
:D I take your point Mihnea.....just being careful I guess. I must admit I quite fancy doing this over spending 3k on a full Milltek system.
Mik
DavidT
Post by DavidT » Fri Jan 14, 2005 12:15 pm
At what point is a larger capacity exhaust system needed, if at all ?
S2tuner
Trader (Expired)
Post by S2tuner » Fri Jan 14, 2005 12:21 pm
A larger system is always better, and ANY engine does benefit from less backpressure in the exhaust, no matter what turbos you're running. I've just recently done an S4 with a complete RS4 engine, Milltek dual system with gutted precats and no cats. Well, honestly, I don't know of any other RS4 engine that breathes like that on 1.3Bar boost, the car is simply breath-taking. At 155mph, mash the loud pedal and you're doing 185 in a couple of seconds... :lol:
Nige_RS4
Post by Nige_RS4 » Fri Jan 14, 2005 3:00 pm
Is this difficult for a garage to do - I mean do you have to drill and tap a thread into the DP?
TIA.
moktoya
Post by moktoya » Sun Jan 16, 2005 7:28 am
Dippy,
Acceleration in the top end much improved after installing the Milltek cats, but it just doesnt feel linear all the way to redline...tapers off after 5.5k as i said. Engine gets hot after runs at high revs which i would have thot is very normal. OK, here in Asia outside temp hovers at 30 celsius + in summer, but this time of yr it's mid teens to low 20's. Sustained high speed/engine speed runs during winter my oil temps rise to 110 (but drops very quickly since i also have an aftermkt oil cooler installed.) Do u get cooler temps with yours after hard runs?
Also, lastly, do u think i should pay to upgrade my MTM programme to the sport cat stage? OR shld it be free? Thx
00 Imola B5 S4
