Controller for throttle stepper motor or whatever it uses, linked to throttle pot
Does sound like the doors are a little bit closed, quite literally
This is where you and many so-called VAG tuners are wrong. A 2.7 running different turbos, injectors and so on has about 45 parameters that need to be changed, otherwise the engine will not run properly.john_banks wrote:Pansies
Doesn't sound much different to the late Subaru ECUs in terms of the number of compensation maps, including intake, EGT, altitude etc.
I did simplify my descriptions to the basics of what is commonly adjusted - a lot of compensations simply don't need to be touched.
I have tuned about 150 VAG engines (80 S2-RS2-S4, some up to 550 crank HP, 30 1.8Ts including hybrid turbos and big injectors, 15 2.7Ts including RS4s and about 25 TDI engines up to 230 HP), so it's experience talking here... not trying to put you off though, all the tools that you need are out there and you just need money and time to get there...Knock control is not per cylinder on the Subaru yet, but most of the rest of it sounds similar. I've mapped about 80 engines, including one to over 200 BHP per litre which survived and is still running a year later in lesser tune, so I would happily take on another engine, especially something relatively unstressed.
Well, assuming you can find map descriptions, you'll have to learn german, and then you'll have to basically do this: decode the ECU. There's also program code disassembling involved if you want to be able to understand all the basics of the ECU and how it works, plus read and study dozens of formulae that describe each function thoroughly. Again, experience talking.I have no interest (nor the skill or time) to decode the ECU though, shame there aren't the tools for the end user to do it IMHO with all the map descriptions sorted. Stops it really being an enthusiast's project in the same way to me.
There's WB and EGT on the engine already, get a full licensed version of VAG-Com and you can get to all of it with no additional hardware if you don't mind being slightly restricted by sample rate when monitoring all this...I'd be very tempted to just hook up a wideband, charge and EGT probes, det cans, frig the fuel cut and dig my AVC-R out and play with some K04s. We'll see.
Getting 400 HP out of a 2.7 is a matter of bolting the proper turbos on, new fuel pump, injectors, exhaust (pre-cats and cats suck) and then spending a day on the dyno with a real-time emulator. BTDT several times, it's not very hard once you know how the ECU's logic functions work.It is a bit tricker than getting a new STi, reprogramming the ECU, fitting a bigger turbo, exhaust, fuel pump and injectors and getting 400 BHP relatively easily though. Or is it?
Well, from "our" (VAG tuners) standpoint, it has to remain mysterious so we don't lose our share. I think it's normal.It would be in the interests of established tuners to make it mysterious when it may not be so?
Because K03 software is readily available, cheaper, and well developed. Many tuners won't sell their K04 stuff without their fueling kit. If you proportionally scale the MAF housing to the injector flow rate, you can get away with using K03 software designed for stock injectors. Without any fuel tweeks, my fuel trims were within 5%.john_banks wrote:Thanks
Any links to the software you mentioned?
Why the K03 rather than K04 chip? When you mention the K03 chip this has the new MAF and injector calibration in it?
What size are the stock S4 injectors? The RS4? Fuel pressure on both?
Can you get full boost in every gear using the ECU's boost control?
It can be done very easily. A Zener Diode on the MAP sensor and an MBC in parallel with the N75 valve will let you play with the boost all you want. Combined cost is about $50. However, I would NOT attempt that without at least a chip.S2tuner wrote:Nope, it does even worse, it shuts the throttle off. This is why I don't think you can tweak it with a fuel cut defender and a boost controller, you'd need a throttle cut defender and many more things, which might end up being more expensive than what you'd initially think.
That's not a very bad idea but the issue is that the ECU won't have a clue as to what the real air flow is.... but as long as the fuel trims are ok and you're not overfuelling at idle/part throttle, I guess it's not too bad for a "hack" solution...Verrückt wrote:Because K03 software is readily available, cheaper, and well developed. Many tuners won't sell their K04 stuff without their fueling kit. If you proportionally scale the MAF housing to the injector flow rate, you can get away with using K03 software designed for stock injectors. Without any fuel tweeks, my fuel trims were within 5%.john_banks wrote:Thanks
As far as I've heard, the stock fuel pump is somewhat of a limiting factor, especially if it's slightly worn out....Stock fuel pressure is 4 bar. Stock S4 injectors flow 350 cc and RS4's flow 481 cc/min @ 60psi.
You should actually be fine with the normal S4 fuel pump.
Hmmm, yeah, hack mods, zener mods on the MAP sensors were very current on 5 cylinder 10 valve turbo engines, now are we talking 2.7 with ME7 for such hack mods? I'm LMAO, I know of no one who's successfully attempted zener mods on S2s/RS2s, nevermind newer cars like 2.7Ts with ME7 ECUs....It can be done very easily. A Zener Diode on the MAP sensor and an MBC in parallel with the N75 valve will let you play with the boost all you want. Combined cost is about $50. However, I would NOT attempt that without at least a chip.S2tuner wrote:Nope, it does even worse, it shuts the throttle off. This is why I don't think you can tweak it with a fuel cut defender and a boost controller, you'd need a throttle cut defender and many more things, which might end up being more expensive than what you'd initially think.
We have cars in the US putting down more than 400 whp with these "hack" mods and offering better driveability than off the shelf big turbo kits.S2tuner wrote:That's not a very bad idea but the issue is that the ECU won't have a clue as to what the real air flow is.... but as long as the fuel trims are ok and you're not overfuelling at idle/part throttle, I guess it's not too bad for a "hack" solution...Verrückt wrote:Because K03 software is readily available, cheaper, and well developed. Many tuners won't sell their K04 stuff without their fueling kit. If you proportionally scale the MAF housing to the injector flow rate, you can get away with using K03 software designed for stock injectors. Without any fuel tweeks, my fuel trims were within 5%.john_banks wrote:Thanks
You would have to have a chip, because MAP sensor limits are usually increased in all modified chips, on a stock chip you'd get nothing because the ECU is really far from being stupid. I find all these hack mods very risky and I wouldn't ever do something that could potentially lead to disabling failsafe functions of the ECU, although I do have some respect for the people who are pulling their hairs trying to find a way to hack these ECUs without actually getting to the chip....
Mihnea
No problem Mihnea. These types of discussions are good.S2tuner wrote:Hmmm, I can't say this isn't interesting, but one problem that you guys do have in the US, it's the lack of custom tuning, or real-time tuning. This to me is the answer to all these problems. You want more at a certain RPM level? You can have it if it's safe to have it.
Re: MAF: I think you are wrong. The ECU reads a 512*1 line with MAF sensor output voltage as x-axis and corresponding actual air flow in kilograms/hour. If you change the diameter of the MAF tube, you offset this reading so the ECU doesn't know the real air flow anymore.
Now, if the cars run fine, if there's no retarding nor any pinging and if the mixture at WOT is rich enough, I guess you guys can be pretty happy and I'd say it's cool for you. But for me, there's still nothing like custom, hands-on tuning where each parameter is adjusted as much as it is possible.
Cheers,
mihnea
The 2.7T has the best knock management system I've seen on any engine.john_banks wrote:When you adjust the MAF cross sectional area and the injector flow up by the same proportion on a typical Japanese ECU, all is fine with the fuelling, but you have a problem because you just advanced the ignition timing as the ECU sees lower load for the same boost pressure as before.
I have a workable setup planned with a 2 to 2.5 litre conversion, 25% bigger MAF cross sectional aread and 25% higher flowing injectors, with an S-AFC to trim it, zener diode for fuel cut, and manual boost controller - all to run a Legacy Turbo at 400 BHP on the cheap as a track toy. The ignition should not be too far advanced because the engine size has gone up in proportion to the injectors and MAF readings.
So would the ignition be too advanced on the Motronic by increasing both the injector flow and MAF cross sectional area in proportion?
No problem. I don't have much of the nitty gritty on there. Those two links are from a friend of mine who has a very similar setup. He ran 12.2@116 mph (3750 + lbs race weight) in the quarter mile.john_banks wrote:Verrückt, any links to the nitty gritty of all this on an S4 would be most interesting and welcomed! I am perusing your website presentlyThanks.
EDIT:john_banks wrote:Sorry, another thing, those fuel pressures are quite high, are the S4/RS4 regulators running fuel pressure relative to manifold pressure, or are they fixed at the noted pressure all the time? Just that 5 bar plus say 1.6 bar gives 6.6 bar fuel pressure? A bit higher than I'm used to on the Jap crap.
Users browsing this forum: No registered users and 105 guests
