Does the light come up on yours? I haven’t found it in the manual either.Dannyboy123 wrote: ↑Fri Oct 01, 2021 12:50 pmMy 2021 rs4 doesn't have this light in the manual. On the my audi app under literature, which manual do you have?
Blue engine light when you turn on vehicle
RSphwoarrr
Re: Blue engine light when you turn on vehicle
RSphwoarrr
Managed to find reference in the owners manual to the blue light. Top sections states not too strain the engine until normal operating temp has been reached ( which if define as 90-100 deg) however bottom section seems to imply that full performance can be reached once the blue light turns off. Appears somewhat contradictory… curious how anyone else interprets this…?
Dannyboy123
- 1st Gear
I've not seen the light before. Looks like it's just a warning to ensure you warm the engine up correctly. Good idea and must be an update in software.RSphwoarrr wrote: ↑Fri Oct 01, 2021 1:41 pmManaged to find reference in the owners manual to the blue light. Top sections states not too strain the engine until normal operating temp has been reached ( which if define as 90-100 deg) however bottom section seems to imply that full performance can be reached once the blue light turns off. Appears somewhat contradictory… curious how anyone else interprets this…?
Avantgarde
- 2nd Gear
I’ve never seen this blue indicator before on my 2020 RS4.
This is a recent change and is in my June 2021 build.
Sadly that build misses the memory seats and tyre pressure monitor display. Which are really missed.
I have a 2020 model no blue light, memory seats or tyre pressure display!
