Oil leak continues
steve2003rs6
Re: Oil leak continues
Post by steve2003rs6 » Thu Aug 19, 2021 5:06 pm
Finally got the car up in the air.
And what a mess we found.
Near side leak seems to be the bottom of the turbo oil drain pipe. Recently had a gasket replaced at the top.
Offside. Oil filter and unions beneath covered in oil.
Also grease all over the place. Inner o/s cv leaking.
Rebooked at unit 20 for 2/9/21
Even with all of the above. Undertray clean and dry.
Never seen the underneath of the car in such a mess before.
Needs sorting.
Mɐʇʇ
Post by Mɐʇʇ » Thu Aug 19, 2021 5:11 pm
Good hit with a paraffin gun will clean it up nicely, I'm sure.
steve2003rs6
Post by steve2003rs6 » Thu Aug 19, 2021 5:23 pm
Thanks Matt. Gave it a really good spray down this afternoon. But it will be the same mess by the time I get back to u20.
I thought my luck was in when I got home. My wife said take all your clothes off. I quickly responded.
She then added. I will put them all in the washing machine and you can get in the bath.
What a letdown.
Mɐʇʇ
Post by Mɐʇʇ » Thu Aug 19, 2021 5:59 pm
Does the oil filter just need a tweak, or is it the unions leaking?
steve2003rs6
Post by steve2003rs6 » Thu Aug 19, 2021 7:18 pm
Not sure Matt. Spoke to grizz. Apparently there is a nut behind the filter that can come loose.
The filter itself is tight.
Don’t want to disturb anything. As this was all done during the full service I had performed.
As was the turbo oil drain pipe if this is the leak.
At the moment this is where the oil is accumulating.
The camshaft covers are still clean and dry.
But I am far from proficient in diagnosing the exact problem. Mainly because there is very little room you can get at.
I have to rely on the experts.
Lander91
Post by Lander91 » Fri Aug 20, 2021 8:54 am
My 2.cents to add. The rear cam seal on the oil filter side (driver for me) was leaking. This leaked down onto the exhaust manifold, but thence onto the oil filter. Sounds like there's a bunch of other things leaking with your ride, but it's worth having a look back there to see if it's contributing. Not too hard to replace.
steve2003rs6
Post by steve2003rs6 » Fri Aug 20, 2021 9:36 am
Hi lander. Many thanks for your comments.
When I had the car serviced the car was very clean on the offside (driver’s side) where the filter is located.
So I will have to wait and see what they find at Neston.
Just having a run of bad luck lately.
steve2003rs6
Post by steve2003rs6 » Fri Aug 20, 2021 2:21 pm
Bad luck continues. Jumped in the car and the rear view mirror has packed up.
Anyone fancy fitting the mirror John replacement glass for me for some beer tokens.
Or know of anyone with the skills that can do it.
Post by Shoppinit » Fri Aug 20, 2021 2:24 pm
Why don’t you send it to Mirror John?
Post by Shoppinit » Fri Aug 20, 2021 2:25 pm
Looks like your car is no longer Christine.
steve2003rs6
Post by steve2003rs6 » Fri Aug 20, 2021 2:39 pm
Will talk to mirror John re glass.
Just sent mirrorjohn a PM
Mirror sent to John for repair 23/8/21
Oil leak update. Spoke to grizz this morning.
1) cv boot. Going to replace all of them. F?ck it.
At least I will then know they are original parts.
2) oil leaks. Asked if there was any benefit to remove the engine to cure the leaks. Grizz says no. They can get at everything that may leak without removing the engine.
So hopefully 2/9/21 visit will be the end of it.
1 leak near side
1 leak offside but I am no expert.
Fell out with Christine. She doesn’t love me anymore.
Mɐʇʇ
Post by Mɐʇʇ » Fri Aug 20, 2021 3:23 pm
She does love you. She's just testing that you love her properly.
steve2003rs6
Post by steve2003rs6 » Fri Aug 20, 2021 3:33 pm
Ha ha. Ok. Will drive her into a brick wall and see if she repairs herself.
Mɐʇʇ
Post by Mɐʇʇ » Fri Aug 20, 2021 3:46 pm
The image in my head was, I think, the same scene - where she drives up that alleyway into the wall to kill someone.
And my username on pistonheads is Arnold Cunningham. :)
steve2003rs6
Post by steve2003rs6 » Fri Aug 20, 2021 4:19 pm
Hi Matt. I was flipping through the tv channels last night.
You guessed it. Christine was just coming on. So a bit of nostalgia and I watched it again.
Love that film. Ben says the book is even better.
The scene where 4 lads smash it to pieces with sledgehammers and it puts itself back together is awesome.
Needless to say they all end up dead.
Music is pretty good too.
Users browsing this forum: srichards and 104 guests
