Ohlins Road & Track on my 2020 RS4
2.9 V6 24v TFSI - 444 bhp
rjwojcik
Re: Ohlins Road & Track on my 2020 RS4
Post by rjwojcik » Wed Jul 14, 2021 7:59 am
I've tried locating an Ohlins dealer in the UK, but all that I've tried appear to be offering motorcycle solutions. Which one's did you guys use?
2022 RS4 - Turbo Blue / Black
Gone: 2018 RS4 - Navarra Blue / Black, 2016 A6 BiTDI - Midnight Blue / Black, 2016 Golf GTD with a "lot" of toys, 2016 M3 CP - Mineral Grey / Black, 2009 135i - Le Mans Blue / Black
initiala4
Post by initiala4 » Thu Jul 15, 2021 9:15 am
Avantgarde wrote:
Sat Jul 03, 2021 10:51 am
Did you run their recommended 120N front and 140N rear springs?
Yes I am currently using their recommended springs - Front 120N / Rear 140N.
Car is on 9 clicks in front, and rear. Ride is much much better especially on uneven roads.
2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner intercooler / Radiator| Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm
initiala4
Post by initiala4 » Thu Jul 15, 2021 9:16 am
jnrdavo wrote:
Tue Jul 13, 2021 10:33 pm
Looking at the lic, isn't it lower than stock?
Can you PM me details of dealer and price? I'm in Austraia, and nobody really sells them here.
I've got a modified S5 v8 and a bit sick of the harshness of the KW v3's...
Sent from my SM-G985F using Tapatalk
My car is a non DRC system, and sits quite low from the factory in standard form.
The kit is purchased in Thailand, as I am located there.
initiala4
Post by initiala4 » Thu Jul 15, 2021 10:53 am
simundo777 wrote:
Tue Jul 13, 2021 11:47 am
Very interested in this kit, any more feedback?
I'd want to retain as much as comfort as possible (even improve it if thats possible).
Are the 100/120 more comfortable than their recommended rates?
120N/140N is their recommended spring rates.
It will improve the damping especially in uneven roads. In stock setup, the car will feel like its jumping all the time as if the car has some lowering springs. I see my daughter jigglying in the baby seat like a basketball while cruising @ 60km/ph.
By the way, my car is a NON DRC.
After I changed this, the jiggling is definitely removed.
As for handling, it is an improvement, over stock setup. Car is much more stable during cornering / change of direction. Plus you can adjust the firm / softness however you want!
I highly recommend this if you are looking for having a more comfortable ride, than stock shocks / springs.
nastro azzurro
Post by nastro azzurro » Thu Jul 15, 2021 10:04 pm
I don’t get the messing about.
DRC does it all 100 times better.
rjwojcik
Post by rjwojcik » Thu Jul 15, 2021 10:36 pm
Unless you don't have DRC that is.
simundo777
Post by simundo777 » Thu Jul 15, 2021 10:44 pm
And DRC is unreliable. Got fed up of constant problems on my B8 so wanted a non DRC car when looking for B9
Current: B9 RS4 Navarra Blue
Gone: B8 RS4 Nogaro Edition. BMW 1M. Cayman 981S. E90 M3. E46 M3 CS
RS4John
Post by RS4John » Fri Jul 16, 2021 11:57 am
I think it was DRC that took all the fun out of driving an RS4 for me - achieving handling perfection (which is what DRC delivered) detracted from the overall driving experience, it never felt even remotely close to being on the 'edge' of something terminal and for me that's what an RS should be like. I realise that's a bit perverse!
2020 F3 RSQ3 Std, 400PS, Daytona Grey/black Ara blue interior, Pano, C&S pack, Red calipers, HBA, TP monitoring, 5yr Warranty, Cete AVC, EBC Redstuffs
Gone, 2016 8U RSQ3 Performance
Gone, 2018 B9 RS4
Gone, 2015 8U RSQ3
nastro azzurro
Post by nastro azzurro » Fri Jul 16, 2021 3:27 pm
Never had an issue with my B8. Totally reliable!
simundo777
Post by simundo777 » Sat Jul 17, 2021 8:51 pm
You were one of the lucky ones then
nastro azzurro
Post by nastro azzurro » Sat Jul 17, 2021 9:10 pm
To be fair, there were more without problems than with.
Forums always highlight the issues.
Personally I only want a car that has the options that it’s been designed with.
Appreciate that they need to drop spec to sell cars. They’re in business after all.
Rusty Racer
Post by Rusty Racer » Sat Jul 17, 2021 9:12 pm
As a B8 owner, is it logical to assume less B9’s have DRC as standard? Seems most have standard suspension and DRC is a hard to find option on the early models?
2018 RS4 B9 Carbon Edition
2014 RS4 B8
Dariusauto
Post by Dariusauto » Thu Apr 21, 2022 7:54 pm
Hi, I own a 2021 RS4 with standard suspension on 20" wheels and I am fed up with my car jumping over road imperfections. I am considering the Ohlins Road & Track suspension and I wonder about the right spring rate. Seems Ohlins is recommending 120 N/mm front and 140N/mm rear - while you opted for 100/120.
My questions are - how did you come up choosing a different spring rate than recommended? How did you managed to order the different spring rate springs?
Would you say 100/120 is optimal or do you feel 120/140 would be fine too?
I am looking to make the ride more comfortable while retaining the original car height.
Located in Vilnius, Lithuania
Own: RS4 B9, BMW M4 F82, BMW M3 E46
Gone: BMW M2 F87, BMW M5 E39, Porsche 997.2 4S, Jaguar XKR,.....
Avantgarde
Post by Avantgarde » Fri Jul 08, 2022 10:37 am
I started out with 100/120 then went on to 80/100 (with high preload), then up to recommended 120/140. 120/140 is the best for the Ohlins in my opinion because the way Ohlins designed the front shock, there is very little travel of the piston before the bump stops come into play. They followed the original Audi bump stop position and this is the reason why the RS suspension is so bumpy. There’s just not enough travel. So the key to running Ohlins is keep close to the original ride height and use their recommended spring rate which seems higher than normal but is essential.
I moved on to H&R coilovers but found that these were insanely jiggly and uncontrolled, so I quickly got off them.
I am currently on the KW HAS kit and this is the best compromise currently. More comfortable than stock, still has a firm damping feel, and it allows more lowering than Ohlins. Upside is that it is the cheapest of all the three setups I tried, and arguably the best all rounder.
I have KW V4 on order and will report back with my findings.
Dariusauto
Post by Dariusauto » Sun Sep 29, 2024 3:05 pm
I offer Ohlins Road & Track for RS4/5 B9 for sale. Used on mine for daily driving around 10.000 km and took them off before selling my car. Spring rate is 100/120.
Condition is very close to new.
Let me know if interested
Located in Vilnius, Lithuania. I could organize shipping
Regards,
Darius
Users browsing this forum: No registered users and 123 guests
