No mine is the non performance on air.
Active Suspension Control - RS6 C7 2017 on Stock Air
- Asian Panda
- 2nd Gear
Re: Active Suspension Control - RS6 C7 2017 on Stock Air
2016 RS6 C7.5 Sepang Blue
Where did you buy the Miltek Module ?
RS6 Performace C7
Honda NSX 2017
Ford Licensed Shelby 1966 350GTH Replica......in build.....
Porsche Cayman GT4 Agate Grey...Wrapped Matte Blue, sold
RS4 B7, 2007, 20" HRE P40's + MRC mods
Bentley Continental GT Titan 600hp, sold
L200 Barbarian, sold
Honda NSX 2017
- Asian Panda
- 2nd Gear
One of the local performance garages got it for me. Most likely direct from milltek.
Your car looks great by the way and nice wheels. Thanks for all the info so far, appreciatte itAsian Panda wrote: ↑Thu Jun 11, 2020 4:06 pmCT PE?
Yes that is my car.
Currently fitted with 20mm spacer front 25mm spacer rear, lowered 15mm front and 10mm rear in dynamic mode.
Had 20mm all round and I am thinking of going back to that. I need to be careful with the rear as I find driving with anything lower than 20-25mm and it rubs, hence why I'm thinking of fitting the 20mm back into the rear. Roads in Northern Ireland are crap!!!
Ps driveway is not level.
RS6 Performace C7
Honda NSX 2017
Honda NSX 2017
Do you have any pics showing car from front end and rear with 20mm spacers on ?Asian Panda wrote: ↑Thu Jun 11, 2020 4:06 pmCT PE?
Yes that is my car.
RS6 Performace C7
Honda NSX 2017
Honda NSX 2017
- Asian Panda
- 2nd Gear
These would be the only ones I have with the 20mm all round.
You may have to zoom in to see things.
Thanks, it's taken some time to get here. Up to Blackline performance tomorrow for maxton front splitter and 034 Motorsport rear anti roll bar. Suspension is too soft.
I did have some stick on front canards, look well but fell off
so decided to leave them off.
I think after this I'm done. Wife will kill me!!!
What size rims/tyres you running?Asian Panda wrote: ↑Thu Jun 11, 2020 5:59 pmThese would be the only ones I have with the 20mm all round.
I did have some stick on front canards, look well but fell offso decided to leave them off.
I think after this I'm done. Wife will kill me!!!![]()
RS6 Performace C7
Honda NSX 2017
Honda NSX 2017
- Asian Panda
- 2nd Gear
9x21 - standard 21" tyres 285x35 I think, all round. These were originally on my 2016 SQ5 except for the tryes.
285, ok so probably 285/30/21 same as mine then thanksAsian Panda wrote: ↑Fri Jun 12, 2020 11:15 am9x21 - standard 21" tyres 285x35 I think, all round. These were originally on my 2016 SQ5 except for the tryes.
RS6 Performace C7
Honda NSX 2017
Honda NSX 2017
HiAsian Panda wrote: ↑Fri Jun 12, 2020 11:15 am9x21 - standard 21" tyres 285x35 I think, all round. These were originally on my 2016 SQ5 except for the tryes.
Have you ever had any issues with the lowering module as in it getting stuck down in show mode and will not raise again ?
RS6 Performace C7
Honda NSX 2017
Honda NSX 2017
- Asian Panda
- 2nd Gear
[/quote]
Hi
[/quote]
Sorry only seeing this now.
I think it did once on me, but took a while to possibly work out why. When I had it in show mode and then wanted it back to normal, I initially had my door open and was standing a bit away from the car...
1. I believe that all doors need to be closed.
2. It would appear that the Bluetooth may be a bit sensitive (worked that one out when I was walking around the car looking for signs of movement, until I got closer to the module).
Think the lesson is the module is in the boot surrounded by a plastic cover, wires and a steel shell, so the Bluetooth I think can be a bit dodgy. Otherwise I've had no issues. Haven't had it in show mode for a while now as I can't be arsed with it
How have you got on since your post?
Hi
[/quote]
Hi - sorry for the old post awaken - was the kit completely plug and play - or did you need to change a cable in one loom?
Users browsing this forum: No registered users and 413 guests
