New seal:
Old seal:
Thanks Ian. I take it the oil pump has to be removed to change the seal?IanH755 wrote: ↑Tue May 26, 2020 12:33 amHere's a bunch of Corroded coolant pipe pics so you've got an idea how bad it gets, the worst is under the bracket which is the usual failure point when the pipe fails. I've also included some Oil Pump pics too - https://imgur.com/a/atMZnwF
I'm starting to get the impression that it's the driving rather than the modifications that matters.
They do numerous different ones for different things. Check which is the correct one.
As far as I know the standard turbos can go up to about 800ps, before needing to go hybrids. Doug at MRC was expecting mine to be about that, but I "only" got 770ps, although a very strong 11xxNm.cammmy wrote: ↑Tue May 26, 2020 12:12 pmOne of the reasons I don't want to have the engine dropped (albeit a silly one) is that I said If I was having that done, I would look at turbo options since I was paying for all that labour anyway. How far can you go before you need a trans upgrade?
I don't really want to turn this into a project car as I want to rebuild the Lotus and upgrade the trans in that. My new turbo is 400bhp+ capable but I don't want to push that far on the stock trans and a 120k mile engine. I've also just bought a whole raft of parts for the Mini to turn that into a track capable daily.
Yes and no. It's bloody awkward with the engine in the car but doable - I had the turbos off for other work and even then I made something of a meal of putting the oil pump back in place and had to strip the water pump out to fix what I'd done wrong. I suspect the instruction to remove the LH turbo is because the hydraulic hard line has to be moved (ideally removed completely) in order to get the pump assembly off. There's a very shallow 12 point socket head bolt which holds a support bracket that the turbo oil drain lines obscure - even having seated a driver with a hammer tap I rounded it out.welwynnick wrote: ↑Tue May 26, 2020 11:38 amI take it the oil pump has to be removed to change the seal?
Does the LHS turbo have to be removed in order to remove the oil pump?
The reason for the torque and HP dying off over 5500rpm is that the OEM turbos aren't big enough to keep supplying the increased boost level demanded from a Stage 2 (or more) map at the top end of the revs. So basically the engines sucking in so much air at high revs that the OEM turbos just can't keep up with the demand requested by the stage 2 map so the boost pressure drops to stock levels, leading to the drop we see.
Users browsing this forum: No registered users and 31 guests
