Ceramic brakes....
2.9 V6 24v TFSI - 444 bhp
vestax32
Re: Ceramic brakes....
Post by vestax32 » Fri Sep 07, 2018 6:55 am
535dboy wrote:Just to throw a different perspective in to the equation I have friends with 911 turbo Ss and Lambo Performante which have ceramics as standard and they have put steels on their car ....
I’m guessing the ceramics on those types of car may be more ‘race’ focused, so less usable on the road, or other reasons?
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
66 Sapphire BMW F80 M3.
18 Mythos Black RS4
14 Daytona Grey RS6
08 Monza Silver RS6 Avant
07 Phantom Black RS4 Avant
Loads of BM's inc. 4 x M's
vestax32
Post by vestax32 » Fri Sep 07, 2018 6:57 am
andyg72 wrote:
vestax32 wrote:
andyg72 wrote:Ceramics are a dream to live with as daily or more 100k life span is easy if there looked after
Smooth braking no judder ever always there no matter how hot
I’m now on 400mm steels I miss the ceramics to the point I’m looking for some more
Andy, when you say ‘looked after’, what exactly do you mean?
As in if you spend a lot of time on track it will take it toll
Ah I see, I may do a couple of trackdays a year, if that, so certainly won’t be abused!
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
andyg72
Post by andyg72 » Fri Sep 07, 2018 7:02 am
vestax32 wrote:
andyg72 wrote:
vestax32 wrote: Andy, when you say ‘looked after’, what exactly do you mean?
Had mine 4 years covered 30 k in my time with 80k on clock I did a few track days spa & ring twice
Looked like new when I swapped the car
I’d would have them again with out worry
Post by MikeFish » Fri Sep 07, 2018 7:34 am
I heard the porsche guys swap them if they do track days as they cost so much to replace if worn or damaged.
andyg72
Post by andyg72 » Fri Sep 07, 2018 7:38 am
MikeFish wrote:I heard the porsche guys swap them if they do track days as they cost so much to replace if worn or damaged.
Very true mike I know a couple of guys done just this
PieterZ
Post by PieterZ » Fri Sep 07, 2018 7:50 am
vestax32 wrote:
Fri Sep 07, 2018 6:53 am
PieterZ wrote:I have them on mine.
They're front only.
They don't squeek, braking is unreal.
Calipers are different, so is the software. (Brakes by itself more from time to time in the rain to keep them dry)
Rears are steel and calipers are also painted grey.
Downside is the high replacing cost. But for the rest... Dang.
The lower weight is a bonus too.
Under what circumstances would they need to be replaced though?
It is my daily, they don't last forever.
All black B9 RS4
vestax32
Post by vestax32 » Fri Sep 07, 2018 7:55 am
Makes sense...
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
vestax32
andyg72 wrote:
vestax32 wrote:
andyg72 wrote: As in if you spend a lot of time on track it will take it toll
I’m definitely being swayed in favour. Not to mention pub bragging rights 🤣🤣
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
Graeme4130
Post by Graeme4130 » Fri Sep 07, 2018 11:20 pm
I had ceramics on my last b8, but didn’t spec them on my B9 mainly due to budget
You won’t notice the difference on a day to day basis until you start to push on. They don’t offer any better braking performance on the road as it’s unlikely you’ll get the steels hot enough for them to fade much (the track is a different game), but where you will notice the difference is where the unsprung weight allows the tyre to track bumps and shittier surfaces better and the car feels like it’ll turn in better at higher speeds due to less rotational weight and gyroscopically reduces mass
I had two b8’s and the first was on steels and the second on ceramics, so I had a good comparison
My ceramic shod car got chopped in for my B9 on something like 58k miles, and other than a couple of expensive pad changes, the discs were barely showing any sign of wear
The only thing to be mindful of is the increased chance of damaging them. A stone caught in the caliper can score them or a sloppy wheel change can chip the edges
Iirc, replacement front discs from the dealer were £6,400/pr parts only, and you have to change pads at the same time, so you’d be looking at a £7k+ bill
Had I been feeling as flush as I was when I bought my second b8, I’d have specced them in a heartbeat
vestax32
Post by vestax32 » Fri Sep 07, 2018 11:24 pm
graeme4130 wrote:I had ceramics on my last b8, but didn’t spec them on my B9 mainly due to budget
Graeme, this is exactly the sort of info I was after. So the pad changes are more expensive than with standard steels?
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
andyg72
Post by andyg72 » Sat Sep 08, 2018 6:39 am
To give you an idea
I brought pads only for £360 direct from Audi £120 for wear sensor if you need it
Fitted myself
Ask Audi to supply & fit your looking at around £600 mark
Not sure what the steel cost is to compare
vestax32
Post by vestax32 » Sat Sep 08, 2018 7:17 am
To give you an idea
Fitted myself
Steels around £420 fitted. Life wise, obviously dependent on how they’re used, but how many miles to a set of pads, roughly same as steels?
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
andyg72
Post by andyg72 » Sat Sep 08, 2018 8:10 am
vestax32 wrote:
andyg72 wrote:
vestax32 wrote: Graeme, this is exactly the sort of info I was after. So the pad changes are more expensive than with standard steels?
To give you an idea
Fitted myself
Mine was on 50k when I brought it they pads were replaced at 46k
I put new pads in around 75k
vestax32
Post by vestax32 » Sat Sep 08, 2018 8:20 am
andyg72 wrote:
vestax32 wrote:
andyg72 wrote: To give you an idea
Fitted myself
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
Graeme4130
Post by Graeme4130 » Sat Sep 08, 2018 2:21 pm
I think I did a couple of sets of pads in 56k
