Disconnect the o/s charge pressure sender
And unscrew the Air charge tube from the air filter box
Unclip the hard to get to hose beneath the tube
I unclipped the oil breather hose from the oil tank to aid access, as you will see next up whilst this improved the access the pipe was so brittle it snapped as soon as I tried to move it out the way
Remove the charge tube from the throttle body and remove, unscrew the air box lid, remove the air filter; remove the side screw securing the air box (not shown) [oh and I forgot to mention the vac pipe behind the air box to remove]
With some elbow grease pull the air box free of its lower grommets and you can access the vacuum pipe and remove it from the recirc valve
And lift the air box off; Top tip - put something in that exposed turbo hose, you dont want anything falling down there! I find 10p shopping bags ideal but a smelly old sock works just as well.
