TD1 code
kmpowell
Re: TD1 code
Post by kmpowell » Tue Apr 17, 2018 7:18 am
bigbaz1974 wrote:
Wed Feb 21, 2018 11:11 am
Just got my car back from audi today it was getting a new shock absorber under warranty so all good. They then told me I have a TD1 code on the car which I wasn't aware of. So I'm reckoning any engine problems and my warranty will be void. What exactly is TD1 and is it possible to remove this.
Hmmmmmmm....
viewtopic.php?f=76&t=126208
:roll:
'15 B8 RS4 - SOLD
RS6chris!
Re: TD1 code
Post by RS6chris! » Tue Apr 17, 2018 4:51 pm
Lost count of how many “tuning company” sites I’ve been blocked from in FB who claim fantastic figures and as mentioned above “can’t be traced”!!
Soon as you challenge them they get all defensive and block you!!
Whoppers!!
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
Eddie555
Re: TD1 code
Post by Eddie555 » Tue Apr 17, 2018 5:52 pm
I just can’t believe how many non-believers there are. All of them should try tune their car, blow it up then have the tuner “return to factory cause won’t be traced” Then come back here crying and we believers can have a good old laugh out loud.
Current ride’s
Previous rides
Golfather
Re: TD1 code
Post by Golfather » Tue Apr 17, 2018 6:10 pm
You could always use another ecu... ;)
sasha320
Re: TD1 code
Post by sasha320 » Thu Jun 07, 2018 7:29 pm
Quick question: should a TD1 code be found, does it also log the date / time the modification was made? Or rather the date that the TD1 code got written to the ECU log?
Panamera ST Turbo, RS6 (C7), Cayenne Turbo S (958), RS4 (B8), ML63 (2010), 997.1 TT, 997 4S, ML63 (2008), CL55, CLK320, Toyota Corolla GTi 16v, Honda CRX, Passat V6
Re: TD1 code
Post by bam_bam » Thu Jun 07, 2018 8:01 pm
Does this work? Presumably you'd need to get this installed with factory support. Knowing what I know about file hashing, salted hashing (no not the food stuff) and hardware token encryption. Installing a new ECU would require access to private keys for initialisation, as parts of the ECU firmware run encrypted. I can't see an Audi stealer being entrusted with the private key end of the encryption used.
doodlebug
Re: TD1 code
Post by doodlebug » Thu Jun 07, 2018 8:14 pm
That and presumably the ECU has a serial number which matches the VIN. Hacking the serial number should be impossible as it should be stored in ROM.
skirs6
Re: TD1 code
Post by skirs6 » Thu Jun 07, 2018 9:34 pm
There is a real simple answer to all this. If you want to preserve your warranty don’t map the car. Please do not believe all this ball that tuners state claiming they can remove their map and Audi will never know.
Brooner
Re: TD1 code
Post by Brooner » Fri Jun 08, 2018 5:04 am
S4WON wrote:
Mon Apr 16, 2018 10:23 pm
kmpowell wrote:Modern Audi's have two flash counters. The 1st is partially accessible by tuners, but the 2nd is completely inaccessible/encrypted and increments at every use of an external device which alters/changes the state of the ECU. Audi keeps a record centrally of what the count number should be for each VIN (based on how many times it's been plugged into their systems), if the count displayed sits outside the number expected, then it goes into the first flash counter and looks for the TB1 and TD1 errors. When these are flagged warranties are usually rendered void.
The flash counters serve two different purposes, one counts, one analyses. There is also another bit of the algorithm that analyses 'hardware' modification (tuning boxes and unidentified hardware that’s been plugged into the ECU) which produces a TXD code that is then added to the detection algorithm. It’s simple maths which will then flag the appropriate error (TD1, TG1, TE1 and TB1).
Well said.
Every few months a new bunch of shills for “tuning company X” come on this site telling people they can “reset for free” or “do it via the OBD” or “install a james bond button”.
Next up they’ll be trying to convince you telepathy works, or maybe faith healing.
Facts are:
Tuning is great but you will void your warranty and you must tell your insurance.
If you are happy with both of those things, fill yer boots.
come on next you'll be telling us Homiopthy is just hippy nonsense :roll:
FinlandRS6C7
Re: TD1 code
Post by FinlandRS6C7 » Thu Nov 22, 2018 9:27 am
Well said.
Facts are:
My car is remapped and i have warrnity. BUT. there in Finland my frends makes wrc cars and other rally cars all over world. Most in Europe. 😊 he remapped my car and dyno stock and mapped. Then he gave me just simple obd plug and tell me. Is something weard happend. Turn of engine and put back on but not start and put this plug in obd shoket. That flash ecu and put stock map in to the car. And you can not see that car is been remapped.
doodlebug
Re: TD1 code
Post by doodlebug » Thu Nov 22, 2018 9:31 am
That’s not true. Just because you put the stock map on doesn’t mean the fact that the ECU has been flashed with a non-OEM map isn’t visible. It is and if you think otherwise you are naive in the extreme.
FinlandRS6C7
Re: TD1 code
Post by FinlandRS6C7 » Thu Nov 22, 2018 10:37 am
I can prove that to you. I can sen you video this. Code number etc in same that before car is never mapped. Ive seen this my own eyes.
And humen has been moon. But cant flash rs6 audi ecu. Yeah right. 👍🏻
Brooner
Re: TD1 code
Post by Brooner » Thu Nov 22, 2018 10:58 am
all academic if you don't have to clam any warranty repair
but if you do good luck with the theory that Audi wont see the map as the car will count the ECU flashes
and if it doesn't read the same as there records
you lose sir
FinlandRS6C7
Re: TD1 code
Post by FinlandRS6C7 » Thu Nov 22, 2018 2:02 pm
I know. But this is tested. WORKS. Sorry.
FinlandRS6C7
Re: TD1 code
Post by FinlandRS6C7 » Thu Nov 22, 2018 2:04 pm
And tested original tester what audi uses VAS
Users browsing this forum: No registered users and 144 guests
