RS55 VAG's B7 RS4 Build Thread - carbon clean, forge oil cooler, plugs, filters etc
RS55 VAG
Re: RS55 VAG's B7 RS4 Build Thread
Post by RS55 VAG » Thu Dec 28, 2017 5:19 pm
Cleaned ports over the course of 2days, speak plugs replaced.. Not that they really needed doing, and relocated the non return valve under the manifold (black and white round attachment) to under the front engine cover.
They have a tenancy to fail over time and I really don't fancy removing the manifold again just for those little valve.
Also deliberately left out the port dividers for higher peak air flow and smoother idle. Didn't deflap the manifold though it requires special plugs to be press fitted in the head after removal of the linkage etc. Maybe a job for the future. ImageImageImageImageImageImageImage
RS55 VAG
Post by RS55 VAG » Thu Dec 28, 2017 5:22 pm
Complete!
Now for a test drive and no better co- pilot than my 83yr old nan!
Result of all the effort... Much smoother idle (not that it was in anyway bad before hand), faster rev range, more pronounced kick above 6k and approx 1sec faster 3k-8k 3rd gear test! So well worth the big effort for this job. ImageImageImage
dhali
Re: RS55 VAG's B7 RS4 Build Thread - carbon clean, fory6ge oil cooler, plugs, filters etc
Post by dhali » Thu Dec 28, 2017 6:36 pm
Nice write up and pics . Well done for for tackling those jobs yourself . More pics of relocation of that valve please if you have them ?
noidea
Re: RS55 VAG's B7 RS4 Build Thread - carbon clean, forge oil cooler, plugs, filters etc
Post by noidea » Thu Dec 28, 2017 7:00 pm
Well done for all the hard work, you must be really pleased with yourself
Sent from my Nexus 6P using Tapatalk
Fatneck73
Post by Fatneck73 » Thu Dec 28, 2017 7:33 pm
Cracking job
RS55 VAG
Post by RS55 VAG » Thu Dec 28, 2017 7:38 pm
Thanks guys.
Yep it's really rewarding doing the work myself. Firstly because it saves on labour costs, secondly because I know it's been done properly, thirdly because I enjoy doing it.
Loving the RS, it's just a complete different beast from the previous cars I have had (all VAG of course).
RS55 VAG
Post by RS55 VAG » Thu Dec 28, 2017 7:40 pm
dhali wrote:Nice write up and pics . Well done for for tackling those jobs yourself . More pics of relocation of that valve please if you have them ?
Hey thanks.
I don't have any photos at the moment. It basically involves getting approx
600mm of 4mm ID / 8mm OD vac hose and connecting to the small underside connection of the inlet manifold. Then connecting the valve once the manifold is in place. Then a cable tie to hold it on the front engine cover. Image
dhali
Post by dhali » Thu Dec 28, 2017 8:08 pm
Thanks .
Surrey Sam
Post by Surrey Sam » Thu Dec 28, 2017 9:31 pm
You had the seller remove Ceramics for a Steel setup?
RS55 VAG
Post by RS55 VAG » Thu Dec 28, 2017 9:46 pm
Surrey Sam wrote:You had the seller remove Ceramics for a Steel setup?
Haha I thought someone would be eagle eyed there!
It had ceramics but the seller then sold them seperately and exchanged them for a new set of steels plus cash his way. He knocked £1.5k off the asking price as a result.
I initially wanted to keep the ceramics however then I noticed they have a number of not so insignificant chips on the OD of the rotors and then I saw the replacement price from Audi £3.4k each!
Surrey Sam
Post by Surrey Sam » Thu Dec 28, 2017 9:56 pm
Ahhh, makes sense now. The ceramics are now fitted to a forum members car on here.
Welcome to the RS4 club and nice start to a ownership thread :thumbs:
birdiemachine
Post by birdiemachine » Fri Dec 29, 2017 2:01 am
Welcome aboard the forum buddy!!!
Car looks mint and well done on the diy brilliant work!!!
Covkiller
Post by Covkiller » Fri Dec 29, 2017 11:08 am
Well done on all the hard work, looks like you added 1 horse power. Well worth bringing your RS4 back to full fettle.
Great thread too, I'm subscribed :thumbs:
Turbo_scotty
Post by Turbo_scotty » Sat Dec 30, 2017 12:23 am
Numberplates almost match 😂😂 nice car btw good effort !!!
Imagef
RS55 VAG
Post by RS55 VAG » Sat Dec 30, 2017 12:25 am
Turbo_scotty wrote:Numberplates almost match ImageImage nice car btw good effort !!!
Imagef
Hahaha niiice
Return to “Readers' Rides”
