SOLD Genuine C7 RS6 20x9.5j et21 wheels NO TYRES
Adam L
Re: Genuine C7 RS6 20x9.5j et21 wheels with tyres
Post by Adam L » Thu Jan 12, 2017 3:28 pm
I can have the tyres removed, as I can understand the sizes are not suitable for an C7 RS6 or B8 RS4.
Pm me if you're interested :thumb:
Post by chunky79 » Thu Jan 12, 2017 9:22 pm
Adam L wrote:I can have the tyres removed, as I can understand the sizes are not suitable for an C7 RS6 or B8 RS4.
If I was after some other wheels I'd have asked if these were available without the tyres. Selling wheel/tyre combo is hard cause people have their favourite tyre brand.
Good luck with the sale.
akademiks
Post by akademiks » Fri Jan 13, 2017 12:16 am
Good luck with the sale buddy, IMO these are the best wheels available for C6/C7 RS6.
Best regards
Peter
Markp
Post by Markp » Fri Jan 13, 2017 5:11 pm
akademiks wrote:Good luck with the sale buddy, IMO these are the best wheels available for C6/C7 RS6.
Best regards
Peter
+1
Adam L
Post by Adam L » Sat Jan 14, 2017 12:29 pm
£1600 without tyres. I can post them in a pallet but will require full address for a fully insured service.
Adam L
Post by Adam L » Sun Jan 22, 2017 3:46 pm
Gave these a wash yesterday and they come up fantastic with the carbon collective protection on them!
RS04YOB
Post by RS04YOB » Sun Jan 22, 2017 7:17 pm
It's ashame they wont go on a B7 RS4 is there too much offset could it be machined down??
MartayMcFly
Post by MartayMcFly » Mon Jan 23, 2017 2:32 am
I have a set of 275 Pirellis in the shed that would fit these perfectly for a C7 RS6 as they're the oem option. Even come with the sound deadening foam in them.
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
2015 8V RS3 Stage 3 - sold
2017 Alfa Giulia Quadrifoglio
Adam L
Post by Adam L » Mon Jan 23, 2017 8:31 am
I was always under the impression that the B7 had far more forgiving arches than the B5. I can't see why they wouldn't fit, they just won't be sunk in the arches like the original wheels are.
FaisalJ
Post by FaisalJ » Mon Jan 23, 2017 9:08 am
I reckon you'd get them on a B7, using 255/30/20 tyres (or narrower).
You may have to roll front arches, and remove an arch-liner screw in each of the rear arches, and you may not be able to run a silly-low ride height.
The offset is equivalent to OEM wheels with 8mm spacers. However, these are 0.5" wider (and 1" bigger of course) than OEM B7 wheels. Still manageable I reckon.
I think they'd look great on a B7.
2007 RS4 B7 Avant
DeanoC
Post by DeanoC » Mon Jan 23, 2017 11:29 am
It's 11mm further out on a B8 with the extra .5". Not sure of that would be too much after a quick measure at the weekend
MartayMcFly
Post by MartayMcFly » Mon Jan 23, 2017 12:34 pm
B7s aren't great with concave wheels, the caliper is a lot chunkier than you might expect. And while I'm sure they'd fit the rear fine to clear up front I think the offset is just too low for the width, so would rub on any (advisable) tyre.
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
Adam L
Post by Adam L » Mon Jan 23, 2017 1:02 pm
I have taken screen shots of the oem wheel fitment against these wheels on a B7. Forgive me if I've got the tyre specs wrong for the B7 as I don't know what they are.
FaisalJ
Post by FaisalJ » Mon Jan 23, 2017 7:44 pm
Valid point regarding the caliper clearance.
I did at one point measure up and post a quick drawing on the forum showing the dimensions that need to be measured to ensure clearance. Can't search for it on my phone though, keep getting an error.
I'll have a look later on. If the seller is obliging, it's possible to check by lying a flat rule across the back of the wheel, measuring out from the middle of the wheel and marking that point, then measuring perpendicular to one of the spokes and comparing to the measurement I have for the required clearance (once I can find the post!)
AdamL - OEM B7 specs you entered are correct.
2007 RS4 B7 Avant
RS04YOB
Post by RS04YOB » Mon Jan 23, 2017 9:42 pm
So the only thing could be the issue is caliper clearance it seems.
