D2500 pad deal
5.0 V10 50v biturbo - 571 bhp
pule333
Re: D2500 pad deal
Post by pule333 » Tue Dec 27, 2016 7:30 am
rs6_sid wrote:just front or rears ? ill speak to him as soon as i can and report back , not sure what he's working over the festive period but he's normally very good cheers guys
If you can ask about both that would be great :)
Front: FCP1664H
Rear: FCP1665H
RS4 B7 aka Vinnie
IanH755
Re: D2500 pad deal
Post by IanH755 » Tue Dec 27, 2016 12:14 pm
longman h wrote:
IanH755 wrote:Just a suggestion but the AP Racing 390mm 2 piece discs (rotor & bell) are the same price as OEM (£800) initially, £200 cheaper when replacing just the rotor next time (£600 for the rotors) & 1000% better performance than OEM!
Ian, where's the best place to get the bells for the AP 390mm kit from please mate?
Here's who I used and they arrived the next day! -
Hi Ian
The discs are £294.80 each and the bells are £99.70 each both prices include VAT.
Kind regards
Ewen MacRae
Clark Motorsport Ltd
Aquherton Business Unit
Kintore, Inverurie
Aberdeenshire
AB51 0XH
01330 860999 (Office)
01330 860111 (Fax)
ewen@clarkmotorsport.co.uk
http://www.clarkmotorsport.co.uk
You need these part numbers -
2x CP8080Z240 - Bells
1x CP8080Z24CG12 - Right Disc
1x CP8080Z25CG12 - Left Disc
The bells need fitting to the discs (all parts supplied) and you need a 6NM Torque wrench & an E12 Star Socket (maybe E10) but its very simple and only takes about 15 minutes per disc.
longman h
Re: D2500 pad deal
Post by longman h » Tue Dec 27, 2016 12:35 pm
Hi Ian
Kind regards
Ewen MacRae
Kintore, Inverurie
Aberdeenshire
AB51 0XH
01330 860111 (Fax)
Absolutely awesome mate, thanks.
Now this is going slightly off topic but are the 390mm rotors that Grizz supplies much different to these?
I think Supersi has also mentioned some Loba 390mm discs are different/better? Thoughts?
Daytona Grey C6 RS6 Avant
Ebony Black C5 RS6 Plus - Gone
IanH755
Re: D2500 pad deal
Post by IanH755 » Tue Dec 27, 2016 11:58 pm
All would be better than OEM, after that they're all very similar as they all use AP discs -
The Vagbremtechnic ones Grizz fitted are AP Racing replacements for the OEM Nissan GTR rotors with a slightly different Bell to the RS6 AP one (prettier). The GTR discs are also 34mm not the RS6's 36mm but the material, cooling properties etc are still the same between the GTR and RS6 AP discs, although the thicker RS6 specific ones may last longer. The £1200 "J-Hook" version is the right price as the special grooves are expensive but the Grooved version (£1270) is just the stock AP disc and should be £800 for the rotors and bells. Someones making a lot of money there.
The LOBA ones are a custom design made by AP Racing specifically for LOBA in GTR sizes (390x34mm again) and are/were extremely expensive (£1700+) for an OEM sized replacement disc setup. However they should be miles better than OEM but how much better they are than AP Racing's own 390mm I don't know TBH as no-one ever posted a review - viewtopic.php?f=47&t=95775
My own personal experience of the £800 RS6 AP discs (390x36mm) was that they are around 5kg per side lighter, vastly better cooled, much harder wearing and could cope with most track-days no problem so I'd expect the other 2 of the above discs to do the same.
longman h
Re: D2500 pad deal
Post by longman h » Wed Dec 28, 2016 12:02 am
IanH755 wrote:All would be better than OEM, after that they're all very similar as they all use AP discs -
Amazing, informative response Ian (as always), cheers.
adamfraser
Re: D2500 pad deal
Post by adamfraser » Wed Dec 28, 2016 1:03 pm
Ian, do you know if AP do discs for the rear as well?
IanH755
Re: D2500 pad deal
Post by IanH755 » Wed Dec 28, 2016 5:17 pm
Yes they do, just checked the prices and they are the same as the fronts, even though it's a smaller disc (£800 - £600 rotors and £200 bells) and it's a proper 2 piece design just like the fronts. TomRS had a set on his C6 with DS2500 pads and seemed happy with them -
CLICKY
RH Rotor - CP8080Z26CG12
LH Rotor - CP8080Z27CG12
LH/RH Bell - CP8080Z260
adamfraser
Re: D2500 pad deal
Post by adamfraser » Wed Dec 28, 2016 6:24 pm
Ideal, cheers for the link.
Will see what I can come up with.
rs6_sid
Re: D2500 pad deal
Post by rs6_sid » Thu Dec 29, 2016 2:31 am
Quick on Ian you might know the answer , can you code out the pad warning on the c6 like earlier models or do you need to make a little home made loom when running the ds2500
c6 rs6 avant- mrc stage 2 -current
bmw e61 m5 saloon
s3 8p stage 2
vw bora tdi hybrid turbo
IanH755
Re: D2500 pad deal
Post by IanH755 » Thu Dec 29, 2016 3:30 am
I made a little "loom" by cutting the plug off my old pads and shorting the wires together. There are 3 places you can do this, near the pad, inside the arch liner at the top or near the bulkhead but obviously the one nearest the plug is the easiest to get to.
JDL
Re: D2500 pad deal
Post by JDL » Sun Jan 01, 2017 8:34 pm
Guys if you need any Ferodo DS2500 pads, please e-mail us or send PM.
We offer best prices for forum members
http://www.jdl-brakes.com
Users browsing this forum: No registered users and 58 guests
