Little Features
Re: Little Features
With number 4, leave the lights on auto but double flick the stork so that it turns HBA off but leaves the lights on high beam. A bit of a pain but better than HBA.
2015 RS4- Nogari Blue, with buckets and Milltek
Ariel Atom 4 with carbon Wings
. But a little bit scary.
- Surrey Sam
Re: Little Features
Some good stuff there, particularly the mirror drainage. I'll certainly be trying that one out, as water running down the door after towel drying the car, is another annoying little thing.geoffdunk wrote:You can also adjust the boot raise height with the button if you park in a reg tight spot, giving you a raise height of what ever you want form just open to fully raised.
AC sync is an old feature, used to be hold the Auto buttons on previous Audi's, been using this one for years.
Auto lights off will stop the coming home and welcome lights working.
Wing mirrors have a clean position, pull them the opposite way and there is a notch, they look odd but they drain and the backs are facing up for easier cleaning, the point of the notched setting is to help the drain when being flooded by water.
Mirror switch in left position (UK) when selecting reverse will dip the left mirror to the rear wheel to monitor the curb, if you have memory seats you can tweak the dipped position from the default to a custom location, again if you park in tight spot you can tweak for a hazard that you want to keep an eye on.
There are few other little items, I'll post a few more when I remember them.
Another point I forgot, as I use the double sided boot cover instead - The standard boot floor can be flipped it over to have a recessed floor which is wipe clean. Good for liquid items which have a risk of spillage or muddy things, this saves you from messing up the carpet side to the boot floor.
Re: Little Features
OMG the passenger mirror one. I have always left if on the middle incase I knock it etc lol.
Hold button lock/unlock for Windows going up and down. If people don't know that one. Probably do
Nice one cheers
Nice one cheers
Re: Little Features
Also does sunroof if fitted, can be turned on and off in MMI. Its designed to let heat out a hot car rapidly.Mr spoonz wrote:OMG the passenger mirror one. I have always left if on the middle incase I knock it etc lol.
Nice one cheers
MY2015 Audi RS4 Avant quattro, Panther Black Crystal, Black leather, Black inlays, 20" V-Spoke wheels
Re: Little Features
My friends passat closes the windows and sunroof if it rains. Does ours do that?geoffdunk wrote:Also does sunroof if fitted, can be turned on and off in MMI. Its designed to let heat out a hot car rapidly.Mr spoonz wrote:OMG the passenger mirror one. I have always left if on the middle incase I knock it etc lol.
Nice one cheers
It has auto rain sensors so don't see why not.
Who wants to try and get there car soaked lol
Re: Little Features
You can imitate rain with a watering can or spray onto the sensor on the windscreen without risking getting your interior wet.Mr spoonz wrote:My friends passat closes the windows and sunroof if it rains. Does ours do that?geoffdunk wrote:Also does sunroof if fitted, can be turned on and off in MMI. Its designed to let heat out a hot car rapidly.Mr spoonz wrote:OMG the passenger mirror one. I have always left if on the middle incase I knock it etc lol.
Nice one cheers
Re: Little Features
Audi don't support or fit this feature, VW only. Fingers crossed they change that.
Re: Little Features
I was joking.... LoLMikeFish wrote:You can imitate rain with a watering can or spray onto the sensor on the windscreen without risking getting your interior wet.Mr spoonz wrote:My friends passat closes the windows and sunroof if it rains. Does ours do that?geoffdunk wrote: Also does sunroof if fitted, can be turned on and off in MMI. Its designed to let heat out a hot car rapidly.
- Surrey Sam
Re: Little Features
Found another today. Cars with advanced key can utilse the door handle sensor to initiate comfort close. Just do a long touch like you would, using the key fob - about 2 seconds.
Handy for when you've got out and left the sunroof/window open and can't be bothered to dive into bags or pockets to get the key.
Re: Little Features
Discovered by accident a couple of weeks ago on my C7 and may be applicable to the B8 too. Can you lift the wipers off the windscreen in their normal position? I know the 8V and C7 wipers need to be put into the service position to lift them without bashing the bonnet to either change the blades or when washing the car. To do this you have to do through the MMI menu to do it bit I discovered that if you turn the engine off then flick the windscreen stalk down to the single wipe position it will put the wipers in the service position.
Re: Little Features
If you set total opening through the MMi it'll open all the windows as well during a continuous hold of the touch pad. I used to use it in the summer to let the heat out before getting in to burn my ass.Surrey Sam wrote: ↑Mon Mar 13, 2017 7:51 pmFound another today. Cars with advanced key can utilse the door handle sensor to initiate comfort close. Just do a long touch like you would, using the key fob - about 2 seconds.
Current ride’s
Previous rides
Previous rides
Re: Little Features
Can lift the wipers enough to get a cloth under themMikeFish wrote: ↑Mon Mar 13, 2017 8:13 pmDiscovered by accident a couple of weeks ago on my C7 and may be applicable to the B8 too. Can you lift the wipers off the windscreen in their normal position? I know the 8V and C7 wipers need to be put into the service position to lift them without bashing the bonnet to either change the blades or when washing the car. To do this you have to do through the MMI menu to do it bit I discovered that if you turn the engine off then flick the windscreen stalk down to the single wipe position it will put the wipers in the service position.
but otherwise have to put them in service position to give the glass a good polish or change blades.
Re: Little Features
So my little tip is useful then! (Said the bishop to the actress).Outtlaw wrote: ↑Tue Mar 14, 2017 9:31 amCan lift the wipers enough to get a cloth under themMikeFish wrote: ↑Mon Mar 13, 2017 8:13 pmDiscovered by accident a couple of weeks ago on my C7 and may be applicable to the B8 too. Can you lift the wipers off the windscreen in their normal position? I know the 8V and C7 wipers need to be put into the service position to lift them without bashing the bonnet to either change the blades or when washing the car. To do this you have to do through the MMI menu to do it bit I discovered that if you turn the engine off then flick the windscreen stalk down to the single wipe position it will put the wipers in the service position.
Re: Little Features
Ahh the "flicking the stalk"
yes Mike, good tip
- Surrey Sam
Re: Little Features
Thanks Mike, that little wiper tip works a treat. As does Geoffdunk's one about folding the mirrors the other way to drain them of water. All came in handy this afternoon when giving the car a clean.
Eddie, that comfort opening doesn't work from the door handle, Closing does, but opening doesn't?
Users browsing this forum: Quinten and 137 guests
