Oil Leak drip drip
5.0 V10 50v biturbo - 571 bhp
55chev
Re: Oil Leak drip drip
Post by 55chev » Wed Nov 30, 2016 8:56 pm
IanH755 wrote:It's "easier" to do the job with engine out but it can be done with the engine still fitted and costs about 1/2 as much too.
I had a quick look at elsawin for the Official procedure, did you do any of the following? -
Drain Engine Oil
Remove LH Wheel
Remove LH drive shaft
Drain Power Steering Oil
Remove Radiator (bottom)
All of those are extra bits Elsawin says you MUST do to be able to do the job :D
drained oil
removed both wheels
removed radiator
coolant housing and front of oil pump not the complete oil pump manifold! if i had not found the source of the leak i would of removed the complete
oil manifold.
This wasnt a part failure as there just wasnt a seal there at all.so either from factory,or someone did a coolant pump and did not put the seal in.
Also ive never worked on this type of car before so there was a fair amount of sussing out time involved for me,didnt realize how much goes into these cars,no wonder there £100,000 grand new...
IanH755
Post by IanH755 » Wed Nov 30, 2016 10:08 pm
I had to LOL at the "Remove LH Driveshaft" as when I looked at 'why' it needed to be done there was no reason other than "maybe" extra access.
55chev
Post by 55chev » Wed Nov 30, 2016 10:37 pm
Vieussuex*
Post by Vieussuex* » Fri Dec 02, 2016 2:57 am
Unfortunately for 55chev his o ring was completely missing but is this oil leak issue in our rs6's avoidable?
I know additives are not everyone's cup of tea and I don't particularly like using them but on my old stage 3 b5 s4 I used Liquimoly Oil Resealer for approx 2-3 years each 10k service.
The idea is the additives don't thicken the oil but keep seals supple so the don't dry out and crack.
Liquimoly is a fairly reputable Brand and I never had any issues using the product don't see why there would be any problem using it on our cars either?
Current:-
2009 C6 RS6 Avant - Stock
Previous:-
2001 B5 S4 Avant - Stg 3
2001 S3 8L - Stg 1
1999 Golf VR6 -Stock
2004 Evo 8MR - Stg 2
2007 VW Polo Gti 9N3 - Stg 1
2006 VW Polo Gti 9N3 - Stg 2
2000 DC2 Type R
IanH755
Post by IanH755 » Fri Dec 02, 2016 10:28 am
Our cars are all now getting to the age where, with the ridiculous heat generated in our engines, seals are starting to fail so anything which can prevent that would be good however I've not personally used Liquimoly so can't say how good it is.
don0301
Post by don0301 » Fri Dec 02, 2016 5:18 pm
I mentioned this before
I had to put in 1 litre of oil in the first 2 weeks of ownership (2.5 years ago). My car had "misting" around the oil seal (as described by audi to avoid an insurance claim!)
I then discovered Forte seal conditioner.
I did some research, including calling Forte's research dept.
Forte explained to me that the additive is chemically inert to the oil and engine but basically re-conditions any rubber it comes into contact with.
I put in 2 at each oil service (depends on amount of oil in engine) and for the last 2 years my car has basically lost hardly any oil.
1 tiny top up I can remember in the 2 years
Forte seal conditioner is trade only to buy (in the UK anyway) but you can buy it on ebay
Works for me
Ferrari 296 GTB
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Belmont SRi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
1st car Datsun 120 FII Lime green....yeah :shock:
55chev
Post by 55chev » Fri Dec 02, 2016 7:44 pm
Help needed
need this race track oil seal,which is not in the audi main dealer listing that i went to in Harold wood,they said you have to buy the complete oil pump unit lol,any ideas where i can get this? bottom of picture
RS6-T28RPH
Post by RS6-T28RPH » Sat Dec 03, 2016 1:34 pm
I'm sorry to say that I had the same problem with the race track shaped seal, couldn't get one so had to part with £2500 for a whole new oil/water pump assembly from TPS. If you can find the racetrack seal it would be an epic save! My 2008 C6 has done 123k miles and things like the oil catch can return pipe and these oil pump seals were brittle or failed :-(
Esben Business IT Solutions - http://www.esben.co.uk
Esben Remapping - http://remap.esben.co.uk
2015 BMW X6 M50d (wife-transport, not allowed to touch :cry: )
2008 RS6 Avant Phantom Black - MRC Stage2 (ecu, tcu & 2nd cat bypass) 730 PS/1017 nm
2006 BMW 535d Pre-LCI - Stage 1 (340bhp)
2003 VW Polo 1.4Tdi (3pot shitbox) tuning project, was 73bhp, now 120bhp, aiming for 160bhp before it goes bang! (put in the bin)
55chev
Post by 55chev » Sat Dec 03, 2016 7:44 pm
I think ive found a way round this Rs6 T28rph,ill get back to ya with results soon.
RS6-T28RPH
Post by RS6-T28RPH » Sun Dec 04, 2016 5:59 pm
Let me know! Have still got my old assembly so would be good to have a spare! especially at 2.5k for a new one!
Cheers,
Rich
55chev
Post by 55chev » Wed Dec 07, 2016 8:16 pm
UPDATE
My first initial diagnosis was incorrect,i first thought there was an o ring missing on the coolant pump shaft,but this turned out to not be the case,i noticed that there was a void in the oil pump housing and also a machining relief in the housing which got me thinking,if a seal was supposed to be in the groove on the shaft it would be void because there is a void in the casting,so my conclusion was it wasn't supposed to have one there,then i realized why they also had put in a relief in the housing,ITS A FAIL SAFE,so if either of the seals fail it wont pressurize the front coolant pump seal and force oil into the coolant system,so as either seal fails it just fills the void then works its way out through the relief and basically drops oil onto the floor. so here are some pics for anyone who has oil dripping from this area,will know what there getting into,im just awaiting the o ring for reassembly of the car,ill let ya know how it goes,i ordered a EPDM 3.53mm o ring 105mm I.D to get around the race track seal not available part from audi,RS6-T28RPH :)
Here is the machining relief bellow.
Here is the casting void.which goes nowhere.
Here is the seal and o ring on the coolant pump shaft which seals off the oil
from the oil pump.i ordered a new coolant pump,@£350 bucks :( The coolant pump is driven via a hex driven shaft from within the oil pump.
Coolant pump fitted in housing,you can see the machining relief clearly which you cant see when fitted in the car.
Measured race track shapped o ring,2.95mm then oil pump housing machined o ring depth,which was 2.90mm,whiich means o ring has almost no crush,which is due to age and heat,.o.5mm is about .004" thou, ive ordered a new o ring with a .015"- .020" thou crush with a 70 shaw,in EPDM.
55chev
Post by 55chev » Wed Dec 07, 2016 11:49 pm
don0301 wrote:I mentioned this before
Works for me
ordered some up,gonna try it :)
Farravi
Post by Farravi » Sun Dec 11, 2016 10:18 am
55chev - are you an engineer or mechanic?
dhali
Post by dhali » Sun Dec 11, 2016 1:05 pm
Good work going on here .
don0301
Post by don0301 » Sun Dec 11, 2016 2:16 pm
Works for me
Just be aware that the first application can take up to 500 miles for it to work. I noticed after about 300 miles. Good Luck, and great stuff your posts.
Ferrari 296 GTB
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
