Car Not Starting - Anyone Had This?
- CaptainLeadFoot
- 2nd Gear
Re: Car Not Starting - Anyone Had This?
i'm having similar issue, depending on what codes you get, it is possible the fuel pump or starter relays are on its way out. i had all the codes that is pointing to one source but i can't tell at the moment without a wiring diagram for fuel or starter, and audi workshop won't tell me so i'm going to have both changed and see what happens.
Finally got round to the VCDS scan this evening. The car has started fine since I had the issue on Wednesday; probably a dozen starts in that time.
I'm booked in at a local indy tomorrow to swap over the 2x relays, hopefully that sorts it. I've got the relays and one other job to do, so I'm taking the lazy option and letting someone else do them for me!
Dump of the scan below. There's an Engine Control Module fault common to many of the errors. I'm wondering if the MAF and engine mount codes are unrelated though - I guess I'll have to see if they're still there after the relays are swapped out.
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WUAZZZ8E37N905107 Mileage: 156380km-97170miles
Address 01: Engine Labels: 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 HW: 8E1 907 560
Component: 4.2L V8/4V FSI ª0080
Revision: --H15--- Serial number: XXXXXXXXXXXXXX
Coding: 010C0003180F0160
Shop #: WSC 66565 257 00032
VCID: 63C59308A2B5D53913D-8036
3 Faults Found:
001672 - ECM Power Relay Load Circuit
P0688 - 004 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 155148 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 14.0°C
Temperature: 16.0°C
Absolute Pres.: 990.0 mbar
Voltage: 0.000 V
000258 - Mass Air Flow Sensor (G70)
P0102 - 002 - Signal too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 156006 km
Time Indication: 0
Freeze Frame:
RPM: 178 /min
Load: 54.9 %
Speed: 0.0 km/h
Temperature: 14.0°C
Temperature: 17.0°C
Voltage: 0.000 V
005495 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 156254 km
Time Indication: 0
Freeze Frame:
RPM: 176 /min
Load: 47.4 %
Speed: 0.0 km/h
Temperature: 42.0°C
Temperature: 44.0°C
Voltage: 10.160 V
Readiness: 0000 1000
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
Component: ESP8 quattro H06 0150
Revision: 00000000 Serial number: 00000000000000
Coding: 0004533
Shop #: WSC 06335 000 00000
VCID: 2B553B288AE55D79EBD-807E
2 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 29
Time Indication: 0
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x0722
Hex Value: 0x0013
Hex Value: 0x858D
Hex Value: 0x0001
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 3
Reset counter: 29
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x6222
Hex Value: 0x0028
Hex Value: 0x018B
Hex Value: 0x0001
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 3233
Coding: 00000
Shop #: WSC 00000
VCID: 6DD1F53027719349B59-5122
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 11021
Shop #: WSC 65536
VCID: 3D7105703791C3C9459-4AE8
Address 11: Engine II Labels: 079-910-560-BNS2.lbl
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 155148 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 14.0°C
Temperature: 16.0°C
Voltage: 0.000 V
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H12 3730
Revision: 91H12373 Serial number: 0036M0G4V3CB
Coding: 0430712
VCID: 3B750B687A85CDF97BD-806E
Subsystem 1 - Serial number: 6332DRB4046C891AX
Subsystem 2 - Serial number: 6342DRB40445C5A0O
Subsystem 3 - Serial number: 6352ARB401A353DBS
Subsystem 4 - Serial number: 6362ARB401BBE52F%
Subsystem 5 - Serial number: 63729RB401E2CC89+
Subsystem 6 - Serial number: 63829RB401E2D134M
Address 16: Steering wheel Labels: 8E0-953-549-T.lbl
Part No: 8E0 953 549 T
Component: Lenksáulenmodul 0301
Coding: 04442
Shop #: WSC 37519
VCID: 44877094547BB2010A7-4B00
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 983 C HW: 8E0 920 983 C
Component: KOMBI+WFS 4 H14 0100
Revision: 0100 Serial number: 00000000000000
Coding: 0007418
Shop #: WSC 19633 000 1048576
VCID: 2F6D2F38BDFD2159C75-5122
2 Faults Found:
01304 - Radio
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0007418
2 Faults Found:
01304 - Radio
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760 A
Component: Sitzverstellung H01 0020
Coding: 00001
Shop #: WSC 06335
VCID: 326B264CFECF0CB1A8B-4AE8
1 Fault Found:
01794 - Control Module - Incorrect Chassis (VIN) Number
35-00 - -
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
Shop #: WSC 00000
VCID: 6BD5FB2819659D79ABD-5140
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CH
Component: Komfortgerát T3B 4135
Coding: 08171
Shop #: WSC 12345
VCID: 79F9D16063393FE9291-4B00
Subsystem 1 - Part No: 8E2959802E
Component: Tõrsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E2959801F
Component: Tõrsteuer.BF BRM 0606
Subsystem 3 - Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000019
VCID: 2959C12080194F69191-807C
Subsystem 1 - Part No: 8E0 941 329 A
Component: AFS-Modul links H03 0020
Subsystem 2 - Part No: 8E0 941 329 A
Component: AFS-Modul rechtsH03 0020
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 25
Time Indication: 0
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 20
Time Indication: 0
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0022523
Shop #: WSC 02197 785 00200
VCID: 2A5B3E2C861F447110B-5140
1 Fault Found:
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 40
Time Indication: 0
Freeze Frame:
(no units): 54.0
Voltage: 13.60 V
(no units): 61.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 E HW: 8E0 919 283 E
Component: Parkhilfe 8-Kan H06 0010
Revision: 00H06000 Serial number: 00067802130630
Coding: 0000114
VCID: 326B264CAECF0CB1A8B-5140
1 Fault Found:
01629 - Sensor for Parking-Aid; Front Left (G255)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 4
Reset counter: 167
Time Indication: 0
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P1 862 335 A HW: 8P1 862 335
Component: FSE_256x BT H44 0660
Revision: 00000000 Serial number: 00000005591726
Coding: 0011822
Shop #: WSC 37519 067 17962
VCID: 35611D505FA11B898D9-5140
3 Faults Found:
02503 - Output Wire to Radio
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 225
Time Indication: 15
01523 - Microphone for Telephone (R38)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 225
Time Indication: 15
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 254
Reset counter: 185
Time Indication: 15
End-------------------------(Elapsed Time: 07:44)--------------------------
Address 01: DTCs cleared
67 69 75 76 77
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 155148 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 14.0°C
Temperature: 16.0°C
Voltage: 0.000 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 156006 km
Time Indication: 0
Freeze Frame:
RPM: 178 /min
Load: 54.9 %
Speed: 0.0 km/h
Temperature: 14.0°C
Temperature: 17.0°C
Voltage: 0.000 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 156254 km
Time Indication: 0
Freeze Frame:
RPM: 176 /min
Load: 47.4 %
Speed: 0.0 km/h
Temperature: 42.0°C
Temperature: 44.0°C
Voltage: 10.160 V
Coding: 0004533
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 29
Time Indication: 0
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x0722
Hex Value: 0x0013
Hex Value: 0x858D
Hex Value: 0x0001
18265 - Load Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 29
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x6222
Hex Value: 0x0028
Hex Value: 0x018B
Hex Value: 0x0001
Coding: 00000
Shop #: WSC 00000
Coding: 11021
Shop #: WSC 65536
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 155148 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 14.0°C
Temperature: 16.0°C
Voltage: 0.000 V
Coding: 0430712
Coding: 04442
Shop #: WSC 37519
1 Fault Found:
01304 - Radio
Coding: 0007418
2 Faults Found:
01304 - Radio
Coding: 0007418
2 Faults Found:
01304 - Radio
Coding: 00001
Shop #: WSC 06335
1 Fault Found:
35-00 - -
Coding: 00001
Shop #: WSC 00000
Coding: 08171
Shop #: WSC 12345
Coding: 0000019
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 25
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 20
Time Indication: 0
Coding: 0022523
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 40
Time Indication: 0
Freeze Frame:
(no units): 54.0
Voltage: 13.60 V
(no units): 61.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0000114
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 167
Time Indication: 0
Coding: 0011822
3 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 225
Time Indication: 15
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 225
Time Indication: 15
01304 - Radio
Freeze Frame:
Fault Priority: 6
Reset counter: 185
Time Indication: 15
2007 RS4 B7 Avant
Did you have a flat battery? Low / flat batteries can throw all kinds of errors and some of those faults have the voltage shown as 0v.
Nope...
2007 RS4 B7 Avant
Just to come full circle on this, in case someone else has the same symptoms and comes across this thread...
Not had an issue since the relays under the ECU were swapped out. Part numbers earlier in the thread.
Thanks for the help guys.
I was just thinking about this; without the forum and Vagcom, I bet a lot of people with this kind of issue would go to a dealer. Who knows how much they'd charge and what parts they'd start swapping out!
2007 RS4 B7 Avant
Had the hot start problem for first time yesterday, sometimes in past the car has struggled when hot as in cranking over for a couple of seconds and splutter into life but no fail. Opened bonnet, cooled down for a bit an it started... Ill look out some relays soon i think, always something!
Thanks for posting relay Pt. numbers.
D
D
Users browsing this forum: No registered users and 1183 guests
