Strange noise
5.0 V10 50v biturbo - 571 bhp
TomRS
Re: Strange noise
Post by TomRS » Tue Mar 01, 2016 4:15 pm
Audi-RS6-R wrote:@TomRS - hope so you are right...but the noise is getting louder when I turn on the A/C :/
There's more strain on the system with A/C compressor engaged as its now turning a compressor rather than just spinning the idler pulley... A/C pumps arent known for going bad but doesnt mean it isnt that.
Needs checking throughly
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten :smile_smoking:
2010 Nissan GT-R SVM 680R
Audi-RS6-R
Re: Strange noise
Post by Audi-RS6-R » Tue Mar 01, 2016 5:18 pm
Yeah - I see...it has to be checked part on part :(
Quattro_RS6
Re: Strange noise
Post by Quattro_RS6 » Wed Mar 02, 2016 10:09 am
If you want to be sure, just take your car to the workshop and dismantle the alternator belt, then you are able to turn all pulleys, alternator and AC compressor by hand and listen for bad bearings. I think you can reach the alternator from the underside of the engine, if not you need to dismantle the front end and pull it out in "service position".
General note:
AC compressor - can be dismantled without removing engine, but it's easily 15-20 hours of labour.
Alternator - same as above, but is easier to dismantle
PS pump - gearbox needs to be dismantled because the bolts holding the pump is located inside the bellhousing. Oilpump also needs to be removed to get access, as the PS pump sits above the oilpump.
Oilpump - can be removed from underside of car, without removing AC compressor, but is a 20h job. (Have just recently done this myself)
2013 Audi Q7 3.0 TDI - Family car
2008 Audi RS6 Avant V10 TFSI - Phantom black, ceramics, ACC, softclose, 21" MTM, MTM springs, MTM Cat back.
2003 VW Bora 1.9TDI Highline - Daily beater
1991 VW Golf cabriolet G60 & 1963 Ragtop T1 beetle, forever lasting project (started in 1998)
X 2007 Audi S8 V10 // 1998 Audi A6 2.5TDI Quattro // 2001 Audi RS4 MTM // 2000 Audi A6 2,7 BiTurbo Avant // 1996 Audi RS2 // 1991 Passat Syncro G60 Turbo
Audi-RS6-R
Re: Strange noise
Post by Audi-RS6-R » Wed Mar 02, 2016 10:20 am
Thank you Quattro_RS6 for all this information - I will keep it in mind... :roll:
TomRS
Re: Strange noise
Post by TomRS » Wed Mar 02, 2016 10:26 am
Quattro_RS6 wrote:If you want to be sure, just take your car to the workshop and dismantle the alternator belt, then you are able to turn all pulleys, alternator and AC compressor by hand and listen for bad bearings. I think you can reach the alternator from the underside of the engine, if not you need to dismantle the front end and pull it out in "service position".
General note:
Brutal... P/S pump can stay whining there's no way i'll be changing that any time soon!
Users browsing this forum: No registered users and 31 guests
