Comment taken (some criticism)
Zeebuilder
Re: Comment taken (some criticism)
Post by Zeebuilder » Tue Jan 19, 2016 3:25 pm
I smell <beep>!
Eddie555
Post by Eddie555 » Tue Jan 19, 2016 3:55 pm
Zeebuilder wrote:I smell <beep>!
And in Dubai that'll be Camel <beep>!!!! Cause in the UK we got a special kinda BULL <beep>.
Current ride’s
Previous rides
Audiifan
Post by Audiifan » Tue Jan 19, 2016 4:08 pm
MikeFish wrote:If you are lucky and nothing goes wrong, a 3 year old 50km car RS will cost a lot (tyres, petrol, brakes, servicing etc) . If you are unlucky and things go wrong it will cost a large fortune. This is not a cheap car to run.
If you are worried about running costs then look elsewhere or take the risk. Anyone that tells you it is cheap to run is lying.
Thanks you are helpful as always, it's 50.000 km not 50:) I think buying used car from a dealer more safer than buying from a stranger
W8PMC wrote:
Audiifan wrote:"I currently have a 2009 Audi RS6. Standard 580 BHP. Warranty runs out in about 5 months. Have recently put new tyres, discs and pads all round at the cost of £3,000.
I am aware that if I have an issue with oil seals/turbo seals, its gonna cost me a pretty penny to fix the RS6 as with the RS6's its often an engine out job, which is costly.
I am thinking of getting a 2013 BMW M5 and wanted to ask about the COST OF OWNERSHIP. A good friend over here in Dubai who runs a service centre for BMW, Audi and Porsche has said that the M5 is considerably cheaper to run servicing and mechanics wise. Its also easier to work on than the Audi, which often means dropping the engine to fix small oil leaks. (I already had the turbo seal done once)
Things I love about the RS6:
- The way it looks
- The interior is the best in class, by far.
- The size of it for the kids and the luggage space
- Its rapid
Things I like about the M5:
- I love the matt Silver with the Silverstone Leather interior. Looks nice in this colour
- The apparently lower maintenance costs
- I already have a BMW E30 M3 and therefore like the BMW's already
- Its also rapid
What you recon? Any thoughts, suggestions, recommendations, advice on cost of ownership compared to the RS6.
And comment follows:
"Audi runs out of warranty and will cost a fortune to maintain
The M5 is a better drivers car, has warranty and cheaper to run."
So ppl who buy brand new car maybe they are safe with warranty, but in my case I am buying used 3 years old 2013 car.
I'd not say their's any difference in reliability or running cost between the C7 RS6 & F10 M5. Both cars could have issues & the bills to repair would no doubt be similar.
Not owned a C7 RS6 but have owned a few RS's & they all had issues ranging from the well documented DRC failures on the B7 RS4 & 2 new transmissions on my C5 RS6. That said i also had a failed transmission in my E60 M5 & my 1st F10 M5 was rejected after 7 months due to what i later found out to be contaminants in the fuel rail causing the injectors to get blocked under WOT, this was later found to be a bad batch. The replacement has been rock solid & now has been significantly enhanced performance wise & still not a single issue (hope that statement doesn't bite me).
They're both big, heavy fast cars so consumables such as pads/discs/tyres are going to take a hammering on the road & be crucified on track. I've gone through 2 sets of rear pads, one set of front pads, one set of tyres all round & my front discs will need replacing very soon. That said i've attended many track days so personally i think that's exceptional usage rates over 21k miles. I DON'T get main dealers to replace consumables so the costs are not high, full set of rear pads are £100 supply & fit with front pads closer to £300 (£800 for Pagid RS29) & tyres are around £1k for a full set of MPSS.
Perhaps in Dubai due to different maintenance cost structures & vastly different conditions, the M5 may be cheaper to maintain (i doubt it though), but that's certainly not the case in the UK.
Thanks for very informative post
MartayMcFly
Post by MartayMcFly » Tue Jan 19, 2016 6:38 pm
If you have to start this many threads, ask this many questions and use this many forums (I presume you're not just doing this on rs246, but on some bimmer equivalent and probably merc too?) then maybe you should realise that none of these cars are logically justifiable and probably aren't for you. If you wanted an RS6 you'd order one, same goes for an M5. If you're looking for someone to hold your hand and make the decision for you then you're an idiot. If you're buying a car based on how easy it is for someone else to repair then that's maybe worse, and even more reason these cars are likely not right for you.
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
2015 8V RS3 Stage 3 - sold
2017 Alfa Giulia Quadrifoglio
Eddie555
Post by Eddie555 » Tue Jan 19, 2016 7:06 pm
I think I speak for the majority of us here on RS246. We all buy our cars without the slightest thought on how much it will cost us to run/maintain. We buy our RS/S Audi's because we want to experience ownership of a beast. We don't care if it has a start/stop button or what maintenance cost will be when it does 50000km. Basically we just want to drive the son biatch.
So to end Audiifan!! If you want the same as us on this forum go buy one if not please stop asking stupid question cause you are coming across as a bit of a numpty.
Current ride’s
Previous rides
doodlebug
Post by doodlebug » Tue Jan 19, 2016 7:11 pm
Cockwomble covers it I think.
Buy the car or don't buy the car. Either way stop with the inane queries.
RS6chris!
Post by RS6chris! » Tue Jan 19, 2016 8:42 pm
Eddie555 wrote:I think I speak for the majority of us here on RS246. We all buy our cars without the slightest thought on how much it will cost us to run/maintain. We buy our RS/S Audi's because we want to experience ownership of a beast. We don't care if it has a start/stop button or what maintenance cost will be when it does 50000km. Basically we just want to drive the son biatch.
Took the words from my mouth!! Exactly my mindset!
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
Post by MikeFish » Tue Jan 19, 2016 8:43 pm
Eddie555 wrote: We don't care if it has a start/stop button
I care... :biggrin2:
Eddie555
Post by Eddie555 » Tue Jan 19, 2016 8:47 pm
Is waiting for your new car starting to send you a bit funny in the head?? Lol
Current ride’s
Previous rides
Post by MikeFish » Tue Jan 19, 2016 8:50 pm
Yep. Going googoo.
Eddie555
Post by Eddie555 » Tue Jan 19, 2016 8:57 pm
MikeFish wrote:Yep. Going googoo.
Well can I suggest you email your dealer to make sure they leave the protective seat covers on your car. I can just imagine you having a premature ejaculation moment on delivery day. You wouldn't want to ruin those nice alcantara seats.
Current ride’s
Previous rides
superlightr
Post by superlightr » Tue Jan 19, 2016 9:05 pm
hahaha :jump_clap:
bobededog
Post by bobededog » Tue Jan 19, 2016 9:19 pm
I knew that was a cut and paste.
Ref post no.4 on this thread.
You guys a being very patient.
He's a Space Cadet
Zeebuilder
Post by Zeebuilder » Tue Jan 19, 2016 9:43 pm
He is only 8! No bad car knowledge for a school kid!
Post by MikeFish » Tue Jan 19, 2016 10:12 pm
bobededog wrote:I knew that was a cut and paste.
He's a Space Cadet
I knew too, he put it in speech marks and said it was from another forum.
Oops, I just came on my Alcantara.
