1 MAF sensor replaced and new silicone pipe fitted to replace an old boost pipe that had a tear = No Engine management light and MUCH BETTER drive
C5 RS6 can hear a rattle at 1200revs??
Re: C5 RS6 can hear a rattle at 1200revs??
Just a quick update:
That's good news! Glad to hear it.
Cheers mate
Also, that slight noise at 1200revs I'm told is the butterfly flap? Most Performance cars have them.
All petrol cars and most diesel cars have them in the throttle body but they don't really like make any noise you would be able to hear over a running engine. Maybe that person is on about the flap some cars (rs4 for example) have in the air box, but that's vacuum operated and I believe doesn't make any noise either.. And the '6 doesn't have one. I'm 99% sure it's the variable valve timing actuators.
Mine is very high mileage though so in my case I was thinking it could be the cam chain tensioners. (although these engines have cam belts, the two cams are linked with chains)
Everything's brilliant except now the revs seem to fluctuate after the boost pipe replacement and replacing 1 of the MAF sensors??
When you start it, it sometimes starts to automatically climb revs upto 1800.
Advised its maybe the wrong MAF sensors that's been replaced as there's 2? Or the throttle body will need cleaning??
Any input much appreciated.
Revs now seem fine after a good drive at higher revs
Engine management light has come back on again
and the revs have started fluctuating slightly although not as bad as before.
Any ideas guys??
Any ideas guys??
jp-berwick
- 2nd Gear
Voooom wrote:I'll still have to mention it to any potential buyers.
Iv dropped the price on it to £8899.
Honest bloke, can you pm me where in the uk you are please?
2011, Metallic Blue, B8 S4, with the sports diff and 6 speed box
