Pinking....
audi_do_dat_den
Re: Pinking....
Post by audi_do_dat_den » Wed Sep 16, 2015 3:37 pm
JCviggen wrote:When you're making a post, at the bottom next to "options" there is an "upload attachments" tab :)
The CSV would be fine.
Thank you mate! For some reason im being prevented from uploading .csv or .xlsx files.....
I must be a proper ludite... :-D
audi_do_dat_den
Re: Pinking....
Post by audi_do_dat_den » Wed Sep 16, 2015 3:43 pm
Group 3 MAF.pdf
(49.3 KiB) Downloaded 247 times
Group 20 Cyl Retardation.pdf
(47.73 KiB) Downloaded 258 times
Group 31 Lambda .pdf
(47.44 KiB) Downloaded 236 times
Well, folks, heres the PDF's which uploaded ok.... dunno what im doing wrong but hopefully these will work.
Thanks in advance!
Chargedrs4
Re: Pinking....
Post by Chargedrs4 » Wed Sep 16, 2015 5:44 pm
what is your short term and long term fuel trim?
should be address 32 or 33
one and only street twin turbo rs4 b7 in the world with 640 plus awhp and 520 awtorque at 11.7 psi
800 plus bhp
audi_do_dat_den
Re: Pinking....
Post by audi_do_dat_den » Wed Sep 16, 2015 6:07 pm
Chargedrs4 wrote:what is your short term and long term fuel trim?
Ill run another log and gather that data asap mate.
Really appreciate the assistance.
JCviggen
Re: Pinking....
Post by JCviggen » Wed Sep 16, 2015 8:22 pm
981 Cayman GTS Gray/Orange.
My youtube
Chargedrs4
Re: Pinking....
Post by Chargedrs4 » Thu Sep 17, 2015 5:06 pm
any updates on this ? your fueling looks fine,maf readings are a bit low but that could be from timing pull
800 plus bhp
ravashanks
Re: Pinking....
Post by ravashanks » Thu Sep 24, 2015 4:27 am
Ok folks. Here're my logs for both banks for a 3rd gear pull from about 1500-2000 to redline. ambient temps were about 30-32 deg at the time of the pull, which is about the average temp on any given day in SG. Don't think i logged mass air flow though.
Please have a look and let me know if you see anything amiss. Much appreciated!!
Bank 1 Log.pdf
(26.07 KiB) Downloaded 211 times
Bank 2 Log.pdf
(24.23 KiB) Downloaded 202 times
JCviggen
Re: Pinking....
Post by JCviggen » Thu Sep 24, 2015 6:48 am
It's difficult to understand as both banks are behaving well fuel wise. It's not running lean and as both banks are the same here the lambda sensors themselves must be fine. Would be interesting to see MAF but it's probably going to be similar to the other one - a bit lower than usual.
Are you running OEM spark plugs?
My youtube
ravashanks
Re: Pinking....
Post by ravashanks » Thu Sep 24, 2015 3:01 pm
Well i've not switched to aftermarket spark plugs, so I'm guessing that my mechs have been using OE spark plugs all this while. I am running Okada coilpacks though. I should probably change them back to OE ones and switch out the plugs for a new set of OEs just to check if it makes any difference.
BTW, as per a few other threads that i dug through, was it ever concluded which was the OE rated plugs for RS4? Was it the NGK or the Bosch, and would somebody be kind enough to give me the part number for the correct OE plugs?
ravashanks
Re: Pinking....
Post by ravashanks » Sat Nov 21, 2015 1:20 am
An update on this...
Changed spark plugs and OE coilpacks... Still pinging.
Changed crank and camshaft sensors... Still pinging.
But FINALLY! Changed fuel injectors and... No, still pinging.
So i've given up. I just leave it in Sport mode now and the exhaust is loud enough to drown out the pinging so i pretend it's not there.
Chargedrs4
Re: Pinking....
Post by Chargedrs4 » Sat Nov 21, 2015 2:54 pm
you did do a full carbon clean right?and still on stock oem tune?
log some fuel pressure low side and high side
block 103 and block 140
800 plus bhp
Re: Pinking....
Post by Shoppinit » Sat Nov 21, 2015 6:32 pm
Weird that you are getting pinking in low load conditions. Are your tumbler flaps working OK? Maybe poor turbulence causing issues?
Ignition is being pulled on all cylinders pretty much equally, yet the lambdas all look OK. Have you had the lambda sensors double checked? Maybe a tuner could do this?
Is the car standard?
SuprSi
Re: Pinking....
Post by SuprSi » Sat Nov 21, 2015 10:40 pm
ravashanks wrote:So i've given up. I just leave it in Sport mode now and the exhaust is loud enough to drown out the pinging so i pretend it's not there.
While I can't offer you any help above what these fine Gents have already given you, I will say don't leave it as it is or the engine won't last very long. Once ping/knock is audible it can be quite damaging. It's an incredibly high spike in cylinder pressure that wreck the pistons and shell bearings. Luckily these engines are built very very strong so you should be ok once it's sorted.
JCviggen
Re: Pinking....
Post by JCviggen » Sun Nov 22, 2015 7:45 am
ravashanks wrote: So i've given up. I just leave it in Sport mode now and the exhaust is loud enough to drown out the pinging so i pretend it's not there.
Makes no sense. Your car is performing poorly, doubt you're cracking 350 bhp with this much timing pull.
If you can't find what's wrong, take it to an expert.
My youtube
ArthurPE
Re: Pinking....
Post by ArthurPE » Sun Nov 22, 2015 8:01 pm
It will happen with ANY engine if the torque it produces is not sufficient for the load
Even with timing, ignition and fueling optimally adjusted
You need more power/torque, a few ways to get it
Increase displacement
Increase compression ratio
Or
Increase rpm since power is proportional to engine speed (and torque)
Every mechanical system has an operating range and limitations
Users browsing this forum: No registered users and 154 guests
