It seems to be around 2,000 rpm the drone is at its worst, well for me anyway.marc1 wrote:You can definitely work around drone with gear choice. Most aftermarket exhausts drone at a certain rpm.
That is easily sorted with another gear
yes 2k rpm with a non res drones a lot! you either have to go resonated or learn to drive in a higher gear to avoid it.Ellis wrote:It seems to be around 2,000 rpm the drone is at its worst, well for me anyway.marc1 wrote:You can definitely work around drone with gear choice. Most aftermarket exhausts drone at a certain rpm.
Be aware that the rev band where it drones is much larger in an Avant (because of the longer interior - right back to the rear bumper - acoustic resonances get excited at lower frequencies)- the drone is annoying from around 1200-2400rpm, which is the rev range I use when driving in town so it made the non-res totally unusable for me.toyneg wrote:yes 2k rpm with a non res drones a lot! you either have to go resonated or learn to drive in a higher gear to avoid it.Ellis wrote:It seems to be around 2,000 rpm the drone is at its worst, well for me anyway.marc1 wrote:You can definitely work around drone with gear choice. Most aftermarket exhausts drone at a certain rpm.
Users browsing this forum: Google Adsense [Bot], tupi154 and 250 guests
