Stalled - and won't restart
CaptainLF
Re: Stalled - and won't restart
Post by CaptainLF » Fri May 08, 2015 12:43 am
Good Day,
I had the exact same symptoms, but I also had my MAF fail shortly after, so below is a summary of what my Shop did to solve both problems. My mechanic said that 4H0 951 253 2 Relays (Fuel Pump and Engine Sensor Circuits) was causing the failure for the car to turn over after an in-depth look at the codes the car was throwing and comparing to the wiring diagram.
I hope this helps
Audi RS4 WUARU78E87N904747 175,662km
0 280 142 431 1 Purge Valve
Labour 1 Smoke test complete intake system, diagnose and replace leaking EVAP purge valve
077 133 471 M 1 Mass Airflow Sensor
Labour 0.5 Remove and clean MAF. Confirm faulty via inconsistent output readings. Replace with new unit.
Labour 2.5 Remove wipers and cowl to diagnose/replace ECM and SAI relays. Test all other components on affected circuit.
Labour 0.5 Remove and clean dirty throttle body. Perform adaptation. Large amount of oil residue on backside of throttle plate. 90.00
Labour 1 Diagnose and cap off leaking vacuum solenoid behind trunk interior. Test signal from S button on dash and confirm proper electronic solenoid operation with smoke machine.
2007 B7 RS4 Daytona Grey, JHM Short Throw Shifter, Carbon Fibre Front Spoiler, OEM iPod Adapter, OEM Roof Racks and Ski Box, EUDM OEM RS4 Winter Rims with Nokian Hakkapeliitta R2 Tires, KW v3
geordie jay
Post by geordie jay » Fri May 08, 2015 7:34 am
this is good to know :thumbs:
R1RS4
Post by R1RS4 » Fri May 08, 2015 8:43 am
CaptainLF wrote:Good Day,
I had the exact same symptoms, but I also had my MAF fail shortly after, so below is a summary of what my shop did to solve both problems. My mechanic said that 4H0 951 253 2 Relays (Fuel Pump and Engine Sensor Circuits) was causing the failure for the car to turn over after an in-depth look at the codes the car was throwing and comparing to the wiring diagram.
I hope this helps
Hi there,
Was this a indie or stealer repair? as they have done a detailed repair
How was your car running leading up to it not starting? Rough?
What intake air system are you running?
And how's it running now?
Cheers :blackrs4: :biggrin3:
RS4 B7 Avant,2007
CaptainLF
Post by CaptainLF » Fri May 08, 2015 11:13 am
Hello,
It was an indie. The starting for me was totally intermittent and would happen very infrequently, the odd time it happened I was able to bump start the car. So when I took it into the Shop is was starting, but the car was running horribly as the MAF sensor wasn't working properly and the indie also found a small vacuum issue.
My intake is OEM and the car runs great now.
R1RS4
Post by R1RS4 » Fri May 08, 2015 12:13 pm
CaptainLF wrote:Hello,
It was an indie. The starting for me was totally intermittent and would happen very infrequently, the odd time it happened I was able to bump start the car. So when I took it into the shop is was starting, but the car was running horribly as the MAF sensor wasn't working properly and the indie also found a small vacuum issue.
They did a good job there and very thorough, good to hear it's running well now, interesting re the relays
RS4 B7 Avant,2007
PetrolDave
Post by PetrolDave » Sun May 10, 2015 11:23 am
R1RS4 wrote:Dave, He does not have Vcd's, so it was suggestions that might get him up and running in the interim
I'm well aware of that.
The point I was making is that without knowing the fault codes any suggestions are really just a "stab in the dark" as there are many possible causes for most engine related faults, which IMHO makes VCDS a "must have" accessory.
Without VCDS all you're doing is buying parts and swapping them in the vague hope that you might find the problem - and even if you do some faulty codes are "blocking" so even if you've replaced the faulty part the problem will still persist.
R1RS4
Post by R1RS4 » Sun May 10, 2015 12:38 pm
+1 100%
RS4 B7 Avant,2007
CaptainLF
Post by CaptainLF » Sun May 10, 2015 2:06 pm
When you finally find out what codes the car is throwing you can compare them to mine.
Here is an example of the codes I was throwing after the car wouldn't start and I had to bump start it. Note this VCDS hit was taken before my MAF problem developed. The big takeaway from my mechanic were all the short to grounds.
Enjoy
Friday,08,August,2014,21:09:24:57902
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WUARU78E87N904747 License Plate: 89TO44
Mileage: 157160km-97654mi Repair Order: 07 AUG 14
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WUARU78E87N904747 Mileage: 157160km/97654miles
Address 01: Engine Labels: 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 A HW: 8E1 907 560
Component: 4.2L V8/4V FSI ª0060
Revision: 57H13--- Serial number: XXXXXXXXXXXXXX
Coding: 01040009180F0160
Shop #: WSC 03122 444 58724
VCID: 244DF9E8E739D13EDFF-8071
13 Faults Found:
001169 - Secondary Air Injection System: Bank 1
P0491 - 002 - Insufficient Flow - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 156009 km
Time Indication: 0
Freeze Frame:
RPM: 3546 /min
Load: 33.7 %
Speed: 28.0 km/h
Temperature: 27.0°C
Temperature: 24.0°C
Absolute Pres.: 970.0 mbar
Voltage: 12.827 V
012312 - Valve for Exhaust Flap 1 (N321)
P3018 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 157134 km
Time Indication: 0
Freeze Frame:
RPM: 219 /min
Load: 97.2 %
Speed: 0.0 km/h
Temperature: 30.0°C
Temperature: 32.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 10.668 V
001112 - Evap System Purge Control Valve (N80)
P0458 - 002 - Short to Ground - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 157134 km
Time Indication: 0
Freeze Frame:
RPM: 219 /min
Load: 97.2 %
Speed: 0.0 km/h
Temperature: 30.0°C
Temperature: 32.0°C
Voltage: 10.668 V
008201 - Intake Manifold Flap; Bank 1
P2009 - 002 - Short to Ground - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 157134 km
Time Indication: 0
Freeze Frame:
RPM: 219 /min
Load: 97.2 %
Speed: 0.0 km/h
Temperature: 30.0°C
Temperature: 32.0°C
Voltage: 10.668 V
004199 - Intake Air Switch-Over Valve (N335)
P1067 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 157134 km
Time Indication: 0
Freeze Frame:
RPM: 219 /min
Load: 97.2 %
Speed: 0.0 km/h
Temperature: 30.0°C
Temperature: 32.0°C
Voltage: 10.668 V
005173 - Secondary Air Pump Relay (J299)
P1435 - 002 - Short to Ground - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 157134 km
Time Indication: 0
Freeze Frame:
RPM: 219 /min
Load: 97.2 %
Speed: 0.0 km/h
Temperature: 30.0°C
Temperature: 32.0°C
Voltage: 10.668 V
005153 - Secondary Air Injection Solenoid Valve (N112)
P1421 - 002 - Short to Ground - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 157134 km
Time Indication: 0
Freeze Frame:
RPM: 219 /min
Load: 97.2 %
Speed: 0.0 km/h
Temperature: 30.0°C
Temperature: 32.0°C
Voltage: 10.668 V
005494 - Right Engine Mount Solenoid Valve (N145)
P1576 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 157134 km
Time Indication: 0
Freeze Frame:
RPM: 219 /min
Load: 97.2 %
Speed: 0.0 km/h
Temperature: 30.0°C
Temperature: 32.0°C
Voltage: 10.668 V
008853 - Fuel Pressure Regulator Valve (N276)
P2295 - 002 - Short to Ground - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 157134 km
Time Indication: 0
Freeze Frame:
RPM: 219 /min
Load: 97.2 %
Speed: 0.0 km/h
Temperature: 30.0°C
Temperature: 33.0°C
Voltage: 10.668 V
009217 - EVAP Leak Detection Pump Control Circuit
P2401 - 002 - Short to GND - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 157134 km
Time Indication: 0
Freeze Frame:
RPM: 1358 /min
Load: 42.3 %
Speed: 0.0 km/h
Temperature: 30.0°C
Temperature: 32.0°C
Voltage: 13.081 V
000049 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
P0031 - 002 - Short to Ground - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 157134 km
Time Indication: 0
Freeze Frame:
RPM: 764 /min
Load: 31.0 %
Speed: 5.0 km/h
Temperature: 36.0°C
Temperature: 33.0°C
Voltage: 13.589 V
000055 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0037 - 002 - Short to Ground - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 157134 km
Time Indication: 0
Freeze Frame:
RPM: 1342 /min
Load: 51.4 %
Speed: 51.0 km/h
Temperature: 43.0°C
Temperature: 33.0°C
Voltage: 13.589 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 157167 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 62.0°C
Temperature: 60.0°C
Voltage: 11.811 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
Component: ESP8 quattro H06 0150
Revision: 00000000 Serial number: 00000000000000
Coding: 0004533
Shop #: WSC 06335 000 00000
VCID: 2B5F12D48AE71E461E5-807E
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 3233
Coding: 00000
Shop #: WSC 00000
VCID: 6DDBDCCC2773D076401-5106
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul USA 0907
Coding: 01023
Shop #: WSC 65536
VCID: 3D7B2C8C379380F6B01-4AF8
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 H HW:
Component: SDAR SIRIUS
Revision: Serial number: AUZ4Z7F0011536
Shop #: WSC 00000 000 00000
VCID: 2E591BC0BAF56B6E39B-515C
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Address 11: Engine II Labels: 079-910-560-BNS2.lbl
6 Faults Found:
005137 - Secondary Air Injection System; Bank 2
P1411 - 002 - Insufficient Flow - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 156009 km
Time Indication: 0
Freeze Frame:
RPM: 3550 /min
Load: 33.7 %
Speed: 28.0 km/h
Temperature: 27.0°C
Temperature: 24.0°C
Voltage: 12.700 V
008224 - Intake Manifold Flap Position Sensor (Bank 2)
P2020 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 157049 km
Time Indication: 0
Freeze Frame:
RPM: 2459 /min
Load: 36.5 %
Speed: 32.0 km/h
Temperature: 84.0°C
Temperature: 21.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.716 V
005490 - Left Engine Mount Solenoid Valve (N144)
P1572 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 157134 km
Time Indication: 0
Freeze Frame:
RPM: 217 /min
Load: 97.2 %
Speed: 0.0 km/h
Temperature: 29.0°C
Temperature: 32.0°C
Voltage: 10.668 V
004764 - Fuel Pressure Regulator Valve; Bank 2 (N276)
P129C - 002 - Short to Ground - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 157134 km
Time Indication: 0
Freeze Frame:
RPM: 220 /min
Load: 97.2 %
Speed: 0.0 km/h
Temperature: 30.0°C
Temperature: 33.0°C
Voltage: 10.668 V
000081 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit
P0051 - 002 - Short to Ground - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 157134 km
Time Indication: 0
Freeze Frame:
RPM: 751 /min
Load: 30.2 %
Speed: 4.0 km/h
Temperature: 36.0°C
Temperature: 33.0°C
Voltage: 13.462 V
000087 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
P0057 - 002 - Short to Ground - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 157134 km
Time Indication: 0
Freeze Frame:
RPM: 1325 /min
Load: 56.1 %
Speed: 51.0 km/h
Temperature: 43.0°C
Temperature: 33.0°C
Voltage: 13.589 V
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H12 3840
Revision: 91H12384 Serial number: 0036N0G0L6G5
Coding: 0432607
VCID: 3C7D21887F8989FE87F-8069
Subsystem 1 - Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 002 0070
Subsystem 2 - Serial number: 3HM3B
Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332DRB404214529Aÿ†63
Subsystem 5 - Serial number: 14529Aÿ†6342DRB40424CC19Sÿ†63
Subsystem 6 - Serial number: 4CC19Sÿ†6352ARB401D57B68Xÿ†63
Subsystem 7 - Serial number: 57B68Xÿ†6362ARB401D40A93Nÿ†63
Subsystem 8 - Serial number: 40A93Nÿ†63729RB401D9A57D+ÿ†63
Subsystem 9 - Serial number: 9A57D+ÿ†63829RB401D9A5D4$ÿ
Subsystem 10 - Serial number: 9A5D4$ÿ
Address 16: Steering wheel Labels: 8E0-953-549-T.lbl
Part No: 8E0 953 549 T
Component: Lenksáulenmodul 0301
Coding: 04441
Shop #: WSC 06335
VCID: 448D59685479F13EFFF-4ADE
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 982 R HW: 8E0 920 982 R
Component: KOMBI+WFS 4 H14 0100
Revision: 0100 Serial number: 00000000000000
Coding: 0023268
Shop #: WSC 12345 999 83976
VCID: 3D7B2C8C679380F6B01-5122
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023268
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 00000
VCID: F1E340BCBB4BB496E49-4ADE
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 P HW: 8E0 035 192 P
Component: RNS-E US H73 0260
Revision: 01S Serial number: AUZBZ7F2497178
Coding: 0309637
Shop #: WSC 02197 785 00200
VCID: 316300BCABCB7496249-5140
2 Faults Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 3
Reset counter: 126
Time Indication: 0
Date: 2014.05.28
Time: 14:32:37
Freeze Frame:
Mileage: 655350 km
Count: 808
Clock: 20:41
00857 - CD Changer Unit (R41)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 45
Time Indication: 0
Date: 2014.05.28
Time: 14:33:17
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CG
Component: Komfortgerát T7B 4135
Coding: 11880
Shop #: WSC 06335
VCID: 78F5FD98583165DEA37-4ADE
Subsystem 1 - Part No: 8E1959801G
Component: Tõrsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E1959802G
Component: Tõrsteuer.BF BRM 0706
Subsystem 3 - Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000019
VCID: 2953E8DC801B0C56EC9-807C
Subsystem 1 - Part No: 8E0 941 329 A
Component: AFS-Modul links H03 0020
Subsystem 2 - Part No: 8E0 941 329 A
Component: AFS-Modul rechtsH04 0020
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0309637
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 126
Time Indication: 0
Date: 2014.05.28
Time: 14:32:37
Freeze Frame:
Mileage: 655350 km
Count: 808
Clock: 20:41
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 45
Time Indication: 0
Date: 2014.05.28
Time: 14:33:17
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0042725
VCID: 2A5117D0861D074EE53-5122
1 Fault Found:
01521 - Sensor for Tire Pressure
002 - Lower Limit Exceeded - MIL ON
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
(no units): 0.0
Voltage: 11.90 V
(no units): 19.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 D HW: 8E0 919 283 D
Component: Parkhilfe 4-Kan H06 0010
Revision: 00H06000 Serial number: 00067802030631
Coding: 0000304
VCID: 316300BCABCB7496249-5122
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 J HW: 8P0 862 335 J
Component: FSE_255x BT H26 0290
Revision: 00000000 Serial number: 00000005013346
Coding: 0011877
End ---------------------------------------------------------------------
Johnners733
Post by Johnners733 » Mon May 11, 2015 7:21 pm
So, car back from York Audi today.
The non-starting fault was traced to a defective fuel pump and so it's had a new one fitted at a cost of £433.92 inc VAT and labour (the part being £263)
While it was in there the helpful workshop people advised all four suspension arm bushes at the front were 'deteriorated' and advising immediate replacement. Bit the bullet and had it done - basically a grand's worth (inc the VAT and labour).
Feel a bit aggrieved as I bought the car privately and it's only done 70k miles with a continuous main dealer history and having just been serviced at Bradford Audi at 68k miles. Vendor said it had had a clean bill of health from them and showed me the dealer paperwork. I may follow up with them to see whether they'd advised anything but I'm not sure to what end - I have no comeback from the vendor.
Anyhow, on the upside they have been through the rest of the car and say it's all fine so hopefully that'll be the last huge expense for this year...
John
audi_do_dat_den
Post by audi_do_dat_den » Mon May 11, 2015 7:35 pm
Thats great that its back in action, albeit a small fortune for stuff that you cant really see....
I do like using Audi main dealers for servicing work, just for that official stamp in the book. However, i hate the pointless 'health check' advisory notes they always feedback.... theyre irritating and unhelpful.
Glad youre finally sorted mate. :thumbs:
Users browsing this forum: No registered users and 135 guests
