Clutch Life
Re: Clutch Life
Post by MikeFish » Wed Jan 07, 2015 1:29 am
Has anyone experienced a proper clutch failure on one of these cars? I'm talking about the clutch slipping ie foot down in 5th at 30mph and revs rising but not going any faster?
This is what in used to when talking about worn clutches but it seems the majority here have been changed due to the pedal sticking down rather than a proper failure of the clutch. Stu mentioned above about a bit of slipping and I think that's the first time I've heard it mentioned on an RS4.
S4Player
Re: Clutch Life
Post by S4Player » Wed Jan 07, 2015 1:43 am
I completely destroyed a Sachs clutch. Crumbled into pieces lol
nij
Re: Clutch Life
Post by nij » Wed Jan 07, 2015 1:52 am
My original clutch was fried, that's why the flywheel was replaced as well. Didn't try the high gear foot down test as I was having trouble engaging gears, so I took it easy on my way to the dealer.
Mercedes E-Coupe 350CDi
stu
Re: Clutch Life
Post by stu » Wed Jan 07, 2015 2:19 am
MikeFish wrote:Has anyone experienced a proper clutch failure on one of these cars? I'm talking about the clutch slipping ie foot down in 5th at 30mph and revs rising but not going any faster?
With that faulty clutch, I couldn't get the thought out of my head that the car was feeling flat losing power around the 5-7k rev range. Audi had installed it. I thought the power problem was vacuum but Revolution sorted all that out for me (I did have a few solenoid issues). It was much improved still didnt feel right when used the way the car should be (ie not fannying around in traffic). I tried the high gear acceleration trick to see if I could see the rev counter wobble but nothing.
When the clutch actually failed it was same as Nij's: within about 100 miles it went from difficult 1st and second to the point where I couldn't change gear unless the engine was turned off.
RossDagley
Re: Clutch Life
Post by RossDagley » Wed Jan 07, 2015 10:43 am
RE slip, mine slips on anything close to a "launch" - just pulling away from a roundabout aggressively is sometimes enough. If I try an actual launch, I get the pedal stick issue too. Then the stench of clutch for about an hour ;)
Previously:
toyneg
Re: Clutch Life
Post by toyneg » Wed Jan 07, 2015 1:25 pm
RossDagley wrote:RE slip, mine slips on anything close to a "launch" - just pulling away from a roundabout aggressively is sometimes enough. If I try an actual launch, I get the pedal stick issue too. Then the stench of clutch for about an hour ;)
time for a new one I think Ross ;-) it has done well though eh?!
RossDagley
Re: Clutch Life
Post by RossDagley » Wed Jan 07, 2015 1:32 pm
Yeah - it certainly has done well. Been half way to the moon (literally!).
I do want to take it to MRC soon for replacement but don't know if the stock clutch is enough for me - I'd love some input on this if anyone has some experience?
Previously:
irishmike
Re: Clutch Life
Post by irishmike » Wed Jan 07, 2015 5:33 pm
Mine did about 60k, got sticky pedalitis and got progressively worse to the point I couldn't select gears at all.
Bit of slippage when flooring it.
New clutch in 5k now and all good :)
Iain_S4
Re: Clutch Life
Post by Iain_S4 » Wed Jan 07, 2015 6:04 pm
I sold mine at 123K, still with the original clutch although I had the feeling that a replacement was not far off.
Gavla
Re: Clutch Life
Post by Gavla » Wed Jan 07, 2015 7:04 pm
Mine failed entirely at around 31K after 4-5 months of the pedal being sticky and just living with it. I could not select any gears - luckily it was when I was just driving out the Garage. Had a new LOBA Stage 1 fitted.
RS4 (B7) Saloon Phantom Black, Black Optics, Tech Pack, KW Lowering Spring Kit, Stern Adjustable Arms, MRC Stage 2, Stage 1 Manifold, CAF, LOBA Stage 1 Clutch,
447ps/490nm (MRC), Scorpion Exhaust Non-Res Black Tips, Pre-cats gutted, Shadow Black Chrome Alloys, Viper Alarm, LED Interior lights, Tints
NJMAudiRS4
Re: Clutch Life
Post by NJMAudiRS4 » Wed Jan 07, 2015 8:23 pm
Still original at 75K, occasional sticky pedal when giving it some beans but no slippage. Can pull along in 6th at 30mph without any problems.
Audi RS4 Avant. MRC Stage 2 Manifold, caf, Map, JCWF Manifold back Exhaust with Sports Cats, H&R spacers, 449ps & 483nm
R1RS4
Re: Clutch Life
Post by R1RS4 » Wed Jan 07, 2015 8:27 pm
Gavla wrote:Mine failed entirely at around 31K after 4-5 months of the pedal being sticky and just living with it. I could not select any gears - luckily it was when I was just driving out the Garage. Had a new LOBA Stage 1 fitted.
What's the Loba stage 1 like to live with and how miles have you done with it?
cheeRS
RS4 B7 Avant,2007
Re: Clutch Life
Post by MikeFish » Wed Jan 07, 2015 8:43 pm
That's interesting then, the most common failure mode is the inability to select gears rather than slippage. I don't know much about clutch construction but would have thought a powerful car would suffer from the slippage issue but I guess whatever makes a clutch fail with slippage must be well engineered in the RS4 and the part of the clutch that when fails stops you sleceting gears is the weaker point.
lengster1
Re: Clutch Life
Post by lengster1 » Wed Jan 07, 2015 10:18 pm
45k when it would not select gear at high rpm,friction plate had split,suffered occasional sticking down issue aswell.
Gavla
Re: Clutch Life
Post by Gavla » Wed Jan 07, 2015 11:31 pm
cheeRS
It's different at first, stiffer, sharper biting point, although sometimes chatter if you like picking a high gear at low revs (although negligible now as its bed in). I've changed my driving style to suit - a bit like when you first upgrade the exhaust to a non-res and have to drive around that drone at 1,800 - 2000 RPM, you adapt and before long you forget how it was...
I personally like it, I've done around 6K miles so far so it's bed in well and is still is a sharp as when it was fitted.
:beerchug:
Users browsing this forum: Google Adsense [Bot] and 231 guests
