£90 off eBay mate, very handy, clips straight on charges the phone and links up perfectly, you can also press the button on the cradle and voice control it.andyg72 wrote:hi may i ask what you payed for the i phone 5 cradle ? i was thinking of taking mine out and replacing with a cradle less center dash till i read you post
thanks andy
Newbie making a introduction
birdiemachine
Re: Newbie making a introduction
1. Don't snap the drill bit off in the disc and wear safety glasses.
2. It looked gay on the R32 and probably wears your bulbs out quicker! Having said that I also had the coming home light function switched on........
3. Check with a RossTech cable and see what error codes are showing. Think it is module 76.
4. Yes, for jump starting. Don't leave a spanner across the terminals unless you are called Walter White.
5. XL tyres have stiffer sidewalls so require different pressure I think.
Half leather/cloth buckets are cool, grips you better than leather as well. Might mate that bought my R32 puts the seat back to get in and out as it has the cloth buckets.
The R32 is much harder to get out of than the RS4. I think the distance from the seat to the sill is larger. I don't bother putting the seat back in the Audi, I grab the A pillar on the way in and the grab handle and roof bar on the way out.
Gets some odd looks half hopping out but it is worth it to keep the seats looking like new.
Might have to put comforts back in when I start getting creaky.
Misano Red RS4 B7 Avant
The beams won't come on when you unlock it, but if you have the Coming Home feature the rear lights and front fogs will come on. To see if you have this feature look to the left of the headlight switch, there is a little pop out switch for the DRLs and to the left of that there is another pop out switch for the coming home feature (if you have it).birdiemachine wrote:All sorted now lads. The iPhone 5 cradle just clipped on and I am in business.
Going to load up two sd cards with my music.
I have some more noob questions if someone could answer them I would be most grateful :
1. When drilling out the holes in the discs is their anything to be careful about?
2. I have vcds, is it possible to make the car have the beams on when you unlock it?
3. The front parking sensors don't seem to activate or do anything but the rears do? Is there anything I am missing here in terms of turning them "on" and if not, has anyone any ideas on where to start in trouble shooting?
4. The battery is in the boot, is the compartment in the engine bay marked with a battery symbol a point for jump starting?
5. I was checking the tire pressures and there are pressures for 235/35 19 and another set for 235/35 XL, what are the differences?
Sorry for all the daft questions and thanks for looking.
Front parking sensors should come on with the rear ones. You can adjust the tone and volume using VCDS so it's possible a previous owner turned it down (not sure if you can also turn off completely).
Yes, the battery cover point under the bonnet is for jump starting.
birdiemachine
Cheers Mike. The front parking sensors are working fine I just hadn't got close enough to anything lol. New owner so am getting used to the size of it atm.MikeFish wrote:The beams won't come on when you unlock it, but if you have the Coming Home feature the rear lights and front fogs will come on. To see if you have this feature look to the left of the headlight switch, there is a little pop out switch for the DRLs and to the left of that there is another pop out switch for the coming home feature (if you have it).birdiemachine wrote:All sorted now lads. The iPhone 5 cradle just clipped on and I am in business.
Unfortunately no coming home light feature.
Is it possible to dim the brightness of the instrument cluster?
Went out to buy eggs and butter for the morning there, came back 1.5 hours later
- Surrey Sam
Yeah, random long drives and half a tank of petrol disappearing does happen and quite normal behaviour...I hopebirdiemachine wrote: Unfortunately no coming home light feature.
You can also dim/brighten the binnacle display by pressing the + & - buttons when lit up at night time. You can also through VCDS adjust whether you want the scales and needles permanently lit or lit up with certain criteria.
I'm pretty sure there is dimmer for the instrument cluster. Can't remember exactly where. I'll take a look in the morning.
You can probably retrofit the coming home light feature if you really wanted it (not looked inot it but surprised if you couldn't).
Edit: Damn Sam beat me to it!
birdiemachine
Ok so another odd question, when I drive up to something in "forward" gears so to speak the front parking sensors don't activate, if I stop, flick it into reverse and move a couple of inches back, then edge forward in first they then work,
Is this normal?
Is this normal?
yes that is normal, you can just activate them though yourself by pressing the button on the dash rather than having to select reversebirdiemachine wrote:Ok so another odd question, when I drive up to something in "forward" gears so to speak the front parking sensors don't activate, if I stop, flick it into reverse and move a couple of inches back, then edge forward in first they then work,
Is this normal?
bluenosewrx
Wait till you discover the curry hooks in the boot!!!!!!
- PetrolDave
Yes, otherwise the front parking sensors would be on a lot of the time when you're in a queue of traffic - which would be seriously annoying if you live/drive in town a lot!birdiemachine wrote:Ok so another odd question, when I drive up to something in "forward" gears so to speak the front parking sensors don't activate, if I stop, flick it into reverse and move a couple of inches back, then edge forward in first they then work,
Is this normal?
birdiemachine
Real lol there. Was one of the first things I noticed!!! Curry hooks much better than cargo net.bluenosewrx wrote:Wait till you discover the curry hooks in the boot!!!!!!
birdiemachine
Never thought of it like that, thanks fellas.PetrolDave wrote:Yes, otherwise the front parking sensors would be on a lot of the time when you're in a queue of traffic - which would be seriously annoying if you live/drive in town a lot!birdiemachine wrote:Ok so another odd question, when I drive up to something in "forward" gears so to speak the front parking sensors don't activate, if I stop, flick it into reverse and move a couple of inches back, then edge forward in first they then work,
Is this normal?
Yu don't need to move back to turn them on, as soon as you select reverse or hit the dash switch you should hear the beep and they should turn on. Once on they will stay on until you press the dash button or drive over a certain speed (can't recall the exact speed but it's something like 5mph).
birdiemachine
More morning time noob questions....
1. I take it the b7 rs4 doesn't have locking nuts as standard?
2. The wheel nut covers, can you get these from audi the paint is peeling off a few of mine.
3. How much would the latest sat nav disc set me back?
Users browsing this forum: No registered users and 227 guests
