Which front brake pads?
R1RS4
Re: Which front brake pads?
Post by R1RS4 » Thu Sep 25, 2014 2:08 pm
RossDagley wrote:
R1RS4 wrote:
RossDagley wrote:Honestly if you can change a wheel you're practically there for fitting pads. It's 10-15 minutes per side maximum. You could do it yourself if you fancied a go. :) I guess worst case it's an hours labour to a garage.
Yellow stuff pads are about £200 for a complete set (8 pads.
http://www.camskill.co.uk/m31b0s3095p49 ... Brake_Pads_
"Should" be a 10-15 min job, but more and more we here about the corrosion build up under the spring steel end plates, which inturn stops the removal of the pads, as the cars are reaching the age they are this will become a regular thing.... Good luck and hope yours is a 10-15 min success CheeRS
This is true I suppose! Having changed my pads 4 times this year and giving the calipers a quick clean each time I do, I guess for me they pop out easily. But yep. totally agree - those end plates can pinch the pads and make the pad hard to remove (and then re-insert)
Yes the more maintenance you do and each time you change the pads your cleaning and checking so less chance of this happening, the longer you leave them the higher the risk, I would never use some of these aggressive wheel cleaners (containing any acidic chemicals) that say spray/brush on and then hose off, the cleaner get under the clips and corrodes away
My advice is if ever removing the pads yourself check under the steel end plates, if you cannot get the bottom screws out take the tops out bend the plate forward then clean out, protect and refit, then when bolted back in place take a punch and tap it back home job done, stealers probably just charge for fitting new calipers as I cannot see them doing this
RS4 B7 Avant,2007
denis.dasilva2
Post by denis.dasilva2 » Thu Sep 25, 2014 4:20 pm
RS04YOB wrote:
denis.dasilva2 wrote:Im using ceramic hawks!
Did you get the pads from the UK
Hey how u doing? No i got them from JHM at the same time i was replacing my stock rotors for theyre light weight and bigger rotors! And i leave close by so i took my car there and i did full brakes front and rear!
mattparr
Post by mattparr » Sat Sep 27, 2014 3:51 pm
I've just ordered a set of EBC Yellow Stuff pads - I'll let you know how I get on.
I think my driving is similar to yours, in terms of occasional "spirited" driving rather than plenty of track abuse - I might even get a new set of front discs to boot.... which reminds me, new topic required! :)
Matt
lengster1
Post by lengster1 » Sat Sep 27, 2014 5:58 pm
Allow more like an hour a side for pads,the calipers will most likely have corrosion starting under the stainless steel guide plate and be a bugger to get out,genuine pads are best I've found and I've tried ds2500 etc
RossDagley
Post by RossDagley » Sat Sep 27, 2014 10:55 pm
Best for what? Gentle road use? Maybe. Anything remotely spirited and I disagree completely. There are several much better pad options.
Previously:
lengster1
Post by lengster1 » Sun Sep 28, 2014 4:54 pm
Have you tried genuine pads? I'm not talking made in China pagid <beep> at £80 notes a pop? And no not gentle road driving I've tdi for that,I've found discs last about as long as a set of pads on OE,ds2500 with braided hoses and motul 600 fluid was no different in feel or performance so when back to original for next set,not a fan of ebc stuff over the years on other motors.
maars
Post by maars » Wed Oct 01, 2014 12:20 am
Decisions, decisions...I'm after a cheaper, and possibly better alternative to the OEM pads. With sensor wires.
Seems the consensus is to steer clear of Pagid. The EBC Yellow Stuff appear to be race pads (?). I don't track the car and don't plan to. The DS2500 and Ferodo premier pads seem good value for money?
Also, any recommended garages in SE London/Kent who could fit the pads would be really helpful.
Daytona RS4 Avant - black optics/decat downpipes/H-pipe/KW springs - featured on the 2012 Audi stand at the Goodwood FoS
coffey555
Post by coffey555 » Wed Oct 01, 2014 10:38 am
The standard OEM pads ARE Pagid, just a total different compound to the £80 crap you can find on ebay.
I made the mistake of buying a set when I changed my front discs and took them off again quickly afterwards for a set of genuine OEM ones.
The difference was night and day between the two, the cheap ones were borderline dangerous!
Generally, with brake pads, you get what you pay for.
The DS2500 pads get good reviews for the money though.
Misano Red RS4 B7 Avant
sar
Post by sar » Wed Oct 01, 2014 10:56 am
just a heads up the ds2500 are normally priced per axle, so you need to buy two sets. when i bought mine they were a touch over £300 for all 8 pads.
awesome pads though.
coffey555
Post by coffey555 » Wed Oct 01, 2014 11:06 am
Ah, so the same as OEM then.
I bet there have been a few annoyed people when they have opened the box to only find 4 pads!
Anyone tried Pagid Blues?
maars
Post by maars » Thu Oct 02, 2014 11:59 pm
Thanks for the tip sar. Considering the aim is to replace with something cheaper/better than OEM DS2500 would be a fail!
Sounds like Ferodo Premiers are the way to go. But where to buy them?
And who in the SE/London could fit them?
RossDagley
Post by RossDagley » Fri Oct 03, 2014 9:09 am
maars wrote:Thanks for the tip sar. Considering the aim is to replace with something cheaper/better than OEM DS2500 would be a fail!
http://www.ebay.co.uk/itm/FERODO-FRONT- ... 3370b33e93 :)
Previously:
maars
Post by maars » Sun Oct 05, 2014 11:28 pm
caldy
Post by caldy » Tue Oct 07, 2014 12:27 pm
maars wrote:Decisions, decisions...I'm after a cheaper, and possibly better alternative to the OEM pads. With sensor wires.
I can never understand why anyone driving a 150mph plus, 1750 kgs, high performance car would possibly wish to compromise braking performance by sourcing a cheaper ..........anything. It's your - and possibly other people's - lives at stake! Better, yes, but cheaper for the sake of it, no.
Might as well look for a set of Kingpin remoulds to finish the look.
RS4 B7 Phantom Black
SuprSi
Post by SuprSi » Tue Oct 07, 2014 12:36 pm
Exactly, brakes and tyres should be the highest priority on a high performance car.
Users browsing this forum: No registered users and 453 guests
