My Carbon Buildup
KGRS4
Re: My Carbon Buildup
Post by KGRS4 » Fri Aug 22, 2014 7:10 am
Lukes3 what tools and solvents did you use to get into the valves to give them a good clean? and do you have a list of seals and gaskets you bought/replaced. Thanks
Red B7 RS4 Saloon......That is all!!
KGRS4
Post by KGRS4 » Fri Aug 22, 2014 8:11 am
Lukes3
Post by Lukes3 » Fri Aug 22, 2014 8:43 am
Sorry havnt got partnumbers.
But i used autosmart g101 cleaner an brake cleaner. Small flat head to get big hard bits off an then socked it in the g101 an scrubed it with bottle brushes an tooth brush lol
Ranger Rico
Post by Ranger Rico » Fri Aug 22, 2014 10:30 am
Cerec1 wrote:
coffey555 wrote:I had my one done last month, you will certainly notice the difference. The car pulls harder at higher rpm.
Who did your carbon clean? Cost?
coffey got his done at Star performance in Fife, im gonna book mine in when i get my arse in gear, im sure im a few ponys down at the moment.
harding
Post by harding » Fri Aug 22, 2014 6:22 pm
bhprs4 wrote:You only need to remove the inlet manifold. It’s not that hard, just a few bolts at the back that are a bit fiddly and require a small ratchet tool. Also check the vac lines and one way valve under the manifold for any damage/leaks.
Im not that handy but i will forward this to my friend and make him do it :beerchug:
Audi RS4 Avant
[2014]: blacked out wheels & grill: center res delete : flaps open
[2015]: brembo & yellowstuff : michelin pss : h&r spacers
[2016]: sachs performance clutch : decoked : led there be light : black window trim
[2017]: stertman stage 1 : black headlights & clear corner mod : gruppe m air intake : gutted resonators
adsgreen
Post by adsgreen » Fri Aug 22, 2014 7:04 pm
It's not likely to be oil directly - people have installed catch cans and found nothing.
It could be valve stem seals and be interesting to see the difference between the B7 and B8 versions.
End of the day, combustion is never perfect so you will always get some element of carbon soot. Along with the other compounds this will stick to the intake valves.
coffey555
Post by coffey555 » Fri Aug 22, 2014 7:08 pm
Star Performance in Fife, was about £700ish I think. Closer than MRC for me. Had it done at 123,000 so was due one although it was idling issues that prompted me to finally get around to doing it.
Apparently they have seen a few S6 V10's with carbon build up so bad that it causes erratic idling as well so not just a B7 problem.
Certainly feels quicker, will do some 3rd gear tests to see what times the old bus can do.
Misano Red RS4 B7 Avant
Dal
Post by Dal » Sat Aug 23, 2014 9:55 pm
Collected the car this morning and have put a tank of fuel through her so far...All I can say is WOW..the difference is unbelievable, my car must have been massively down on power as it goes better than it ever has, it pulls so much better especially top end of the rev range, the noise from the engine sounds completely different..well worth getting done..
B8 RS4 in the fastest colour :smile_smoking:
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 335 guests
