A very poorly RS4
adsgreen
Re: A very poorly RS4
Post by adsgreen » Tue Aug 19, 2014 4:19 pm
JAMZONTOAST wrote:https://www.youtube.com/watch?v=uD8uoPnpxp8
There's a short video.
In short, it sounds like a rough diesel.
...Ignore the heavily worn 'S' button. Ha.
whoa that's rough.
is it lumpy and missing?
Worth checking the oil separator as this iirc is vacuum controlled and is responsible for catching blowby oil and returning to the sump. It's notoriously fragile and if fails will clog up with oil allowing a steady stream into the intake (not great) and also leak vacuum like nobody's business.
Timster
Post by Timster » Tue Aug 19, 2014 7:00 pm
Blimey that does sound rough and nothing like the normal chain noises.
(you sure somebody hasn't swapped your V8 for a Transit engine?)
Cecilthesausage
Post by Cecilthesausage » Tue Aug 19, 2014 7:25 pm
My pal will have a look at that for you mate... He's an Indy in Thornaby Ex Teesside Audi mechanic... Does all the work on my RS 4 and my old S3... Has done for the last 7 years... I'm currently offshore at the moment but if you drop me a message I'll give you his details.... Rob
Regy53
Post by Regy53 » Tue Aug 19, 2014 7:57 pm
sounds like a small end
TTS Charged RS4 plus all the goodies
JAMZONTOAST
Post by JAMZONTOAST » Tue Aug 19, 2014 8:08 pm
I was driving through South London when it happened. Someone might have while I had my back turned...
R1RS4
Post by R1RS4 » Tue Aug 19, 2014 8:52 pm
If you had stopped in South London you wouldn't have any noise, ie you would not have an engine. I am allowed to say this as I am originally from saf London
(We were so hard up years ago that one morning I awoke to find someone had broken into my mk1 cortina ...................and fitted a radio!
RS4 B7 Avant,2007
JAMZONTOAST
Post by JAMZONTOAST » Thu Aug 21, 2014 8:14 pm
Right, a sad update follows:
Had a guy come up from York to look at the car. Noise is coming from a piston. Have been told it's an engine out job, which will most likely require a rebuild. Quick estimate of the top of his head will be "*hopefully* under £10,000". Felt like vomiting right in his face! Haha.
He's going to give to me an accurate quote to take engine out, and give a fully diagnosis, then a final quote for parts and total labour.
Anyone have any previous experience? Does the estimate seem accurate? (don't want to type that number again!)
Going to have a look around and see if they can give me any other quotes.
Depressed. Reeeeallly depressed right now.
:thumbsdown:
KGRS4
Post by KGRS4 » Thu Aug 21, 2014 8:28 pm
JAMZONTOAST wrote:Right, a sad update follows:
:thumbsdown:
:shock: :shock: :shock: id be getting more than a few quotes first and im fairly sure pistons can be removed in place its just a lot more time consuming and harder, people always say "take the engine out" as its way easier to strip an engine. Its a catch 22 really, time wise would be quicker taking out the engine
Red B7 RS4 Saloon......That is all!!
adsgreen
Post by adsgreen » Thu Aug 21, 2014 8:34 pm
Can't even take the valve heads off in place as far as I can tell from elsawin.
10k is a fair whack. Taking the engine out whilst a pita in the right workshop with the right tools it should be that long.
I would say taking the rocker covers off as a start as that can be done in place.
Next a compression test - some failed would show up and easy and quick to do.
Also might be worth an endoscope into the cylinder of even just take the intake manifold off and peek in the combustion chamber.
Do you have a warning light on?
JAMZONTOAST
Post by JAMZONTOAST » Thu Aug 21, 2014 8:39 pm
He put Vagcom on and no timing or misfiring errors came up which I thought was strange considering hiw ruined it sounds. Only the couple that I have had before:
O2 sensor and starter motor relay fault. Both unrelated obviously.
Will definitely get other quotes. Will give Revolution a ring tomorrow for starters.
JAMZONTOAST
Post by JAMZONTOAST » Thu Aug 21, 2014 8:42 pm
And the suspected piston (or possible pistons) were at the back, closest to the timing chain.
S4WON
Post by S4WON » Thu Aug 21, 2014 8:52 pm
For that money try mrc,amd and grizz at unit20 aswell. Flatbed costs pale into insignificance here i think.
I feel for you. GL man
JAMZONTOAST
Post by JAMZONTOAST » Thu Aug 21, 2014 8:57 pm
S4WON wrote:For that money try mrc,amd and grizz at unit20 aswell. Flatbed costs pale into insignificance here i think.
Will do. Heard good things about Unit 20.
And cheers for the sympathy. Euromillions tomorrow, a little win would go down very nicely now. Ha
jaysrs4
Post by jaysrs4 » Thu Aug 21, 2014 8:59 pm
Fcuk a rebuild for that money. I'd be buying a second hand lump.
That's a nasty kick in the scrote.
R1RS4
Post by R1RS4 » Thu Aug 21, 2014 9:23 pm
Who would spend 10k on a repair? Someone on here a new engine fitted by Audi a couple of months back wasn't that 12.5k? He had most of the cost covered by Audi ?
RS4 B7 Avant,2007
Users browsing this forum: Google Adsense [Bot] and 372 guests
