rear o/s brake binding
ahoooga
Re: rear o/s brake binding
Post by ahoooga » Tue Jul 29, 2014 10:05 pm
I'm in Birmingham if you want to use mine
hedgebog
Post by hedgebog » Thu Jul 31, 2014 9:35 pm
Sorry for the delay,I've been working away.that would be great if you are sure.could you pm me a contact number so I can give you a call.
Thanks Paul.
ahoooga
Post by ahoooga » Fri Aug 01, 2014 7:52 pm
Just a thought , the brake disc isn't warped is it ?
hedgebog
Post by hedgebog » Sat Aug 02, 2014 12:04 pm
I don't think so they are all fairly new.I cant feel anything through the pedal although last night when rolling up to a junction i touched the brakes to stop and i got the feeling and the noise when the abs is working.that was very strange as i was only rolling at say 5mph.
hedgebog
Post by hedgebog » Mon Aug 11, 2014 4:42 pm
I've just noticed a mistake in my original post its actually the esp light that is on with the abs light.not the epc doh!!.I took the car up to the garage earlier and the following code came up 00285-abs wheel speed sensor,front right(G45) 30_00-open or short to plus.
Its going back later in the week for him to investigate further.This is the same sensor i replaced a few weeks ago.
Paul.
ahoooga
Post by ahoooga » Tue Aug 12, 2014 1:31 am
Could do with shoppinit seeing this to say if a new ABS wheel sensor has to be coded into the car with Vagcom or not , as I don't know, or if there's a set procedure regarding clearing the fault/error first then changing the sensor
Post by Shoppinit » Tue Aug 12, 2014 8:25 am
Doesn't have to be coded, but if you've swapped out a sensor that's being reported as being bad, and it's still being flagged then it points to ABS controller.
hedgebog
Post by hedgebog » Tue Aug 12, 2014 4:01 pm
Oh right,i dont like the sound of that.I'm sure i've read a thread about replacing one of those and having them repaired but can't seem to find it.The garage is going to double check the sensor etc.Is there any way of checking if the module is faulty?.
Thanks Paul.
hedgebog
Post by hedgebog » Wed Aug 27, 2014 8:48 pm
Just a quick update,I sent the control module away to bba reman who tested it and found a fault.I got it put back on the car today and have just been a 30 odd mile run around and it seems to have done the trick.Hopefully that should be it on the problem front for a while.Thanks for the help and advice.
Cheers Paul.
Users browsing this forum: Bing [Bot] and 173 guests
