Door is the same you just have to bolt out the window frame and swap in the saloons very easy to do.
I have to avant doors and already checked the B5's have the same setup.
Rs4 saloon rear doors
Re: Rs4 saloon rear doors
rwilsonrs4
neilparf wrote:I had a new rear door due to an altercation with a deer recently - the door is all metal...adsgreen wrote:Rs4 outer door shells are plastic - can't tap out
Mine are definitely plastic - had a new set on drivers side when got clipped by stupid driver.
You can tap them and push them in quite far and the flex easily.
Finally I have a car park ding that is (about to be fixed) through to the undercoat and you can see the plastic underneath.
Ditto. I even saw the Audi rings on the sticker and part number etc. on the bare door.sar wrote:very strange?, mine are 100% steel.
Ads - are they Audi exclusive or something for weight?????[/quote]
nope definately steel doors , they are flexible because they are large and thin, if yours were plastic how did it get a ding then as plastic is much more resileent to localised high pressure from something , whereas steel will only stretch a little before it wont return to its form ,thus a ding is made , get your magnet out i think
1/4 mile 12.01 secs 123.5mph
Users browsing this forum: Google Adsense [Bot], Squadr0n_ and 264 guests
