Quarter mile times
Re: Quarter mile times
Post by bam_bam » Fri Jun 13, 2014 7:34 pm
sakimano wrote: Just figured I'd save the usual forum douchebags some time and post their pea-brained responses for them.
...and that's won you loads of friends thus far.
These cars aren't built for drag strips or to go around corners. How's that for being pea-brained?
Any other tips? What has been some of the oddest things you've seen at the strip, Saki?
RIV
Post by RIV » Fri Jun 13, 2014 7:57 pm
More than one person turn up to watch him :jump:
sakimano
Post by sakimano » Fri Jun 13, 2014 7:58 pm
Fortunately I don't join forums to find friends.
I agree that they aren't built for the dragstrip OR for corners either. They're impressive autobahn stormers that can do loads of things well.
Seems the c5 guys can understand that the dragstrip (or other controlled acceleration testing like the app above) can offer invaluable benchmarking for your car.
weirdest thing I've seen? in person, an 18 year old kid in his mom's minivan running 21.something @ 60something MPH at a run what you brung night.
Or seeing an Audi R8 line up, stage too far forward, get told to back up to the staging beams by the track steward...then get all ready to run...and when the light turned green, he went ROCKETING off...backwards. He forgot to put it back in Drive.
as for tips, here's the consolidated OP from a thread we have on audirevolution.net of tips from various guys
sakimano wrote: When I first went to the dragstrip, I remember <beep> a whole bunch of things up. I went again the next week and corrected some of my mistakes, but made some new ones. By the third week I had a good routine down and had it somewhat sorted out. I had read far too many stories on the forums that made me scratch my head....people showing up with their cars overweight...wrong octane...billion degree heat...not shallow staging . All these things conspire against you.
Here's what I gathered from the forums/internet on how to make sure your dragstrip passes are the best you can get out of your car. You may never launch it like jaybquick/countvohn/cabracco85, but at least you can eliminate a whole ton of other variables, ensuring you post the best time possible for you and your car on that particular day.
If you have some other tips, add them up to the thread, and I'll continually edit the OP as we go along. Here are some lessons I learned from smarter people then me (I love copying smart people).
1. GET EVERYTHING OUT OF THE CAR - Heavy rubber winter mats...golf clubs...spare tire...tools...jack...EVERYTHING. Don't rice it up and pull your seats out, but just make sure you're not carrying any extra weight
2. ARRIVE with 1/8th of a tank of gas. If you need to drive 50 miles to the strip, make sure you leave your house with just over 1/4 tank.
3. BRING ICE - Specifically, a little cooler with an ice bag and a towel - when you first arrive, your car will be hot (because NOBODY lives near the dragstrip lol) so you'll want to put the bag of ice, wrapped in a towel, on the manifold to cool it down
4. ARRIVE 1 hr EARLY - if test and tune starts at 8pm, arrive at 7pm to let your car cool down. Give yourself an hour, bring your iPhone/Blackberry/iPad/Club magazine and kill an hour while you wait for it to open (and while your car cools down).
5. MAKE 2-3 RUNS AT A TIME - then cool the car down. I tend to go 2-3 times, and then let the car cool down for 20-40 minutes. Since Test and tune is usually dead at this time of the year you can pick and choose your spots.
6. BRING A PEN - you may need to fill out a driver card/waivers, and the safety inspection guys I've met are always grumpy if you don't have your own pen.
7. BRING A CAMERA THAT TAKES VIDEO - grab a point and shoot camera that takes video, and wedge it under your passenger side headrest (should hold nicely) so you can film your run. Try to get a view of the strip and the shifter. This way you can hear the engine...you can analyze your shifting etc. after you get home or even while you're waiting for the car to cool down between your 2-3 run segments. I found this not only helpful, but fun for later reviewing the footage.
8. FOLD YOUR MIRRORS IN- this probably does nothing but it makes you feel faster lol. It's a 91GL tip and I like it. Sorry RS4 guys...your ears will have to stick out the whole time as the mirrors don't fold.
9. BRING GAS - a 1 gallon jug of 93 (UK 98) octane gas just in case you run so low at the strip that you're getting close to empty. Having the car sputter on a run isn't good, with the gas sloshing around in there from the violent launch and shifts...and running out when you're in the boonies 20 miles from a good gas station also sucks. This happens to me every time...I run the car down real low, then have literally 20 miles before the nearest 94 octane station (we only have 91 and only one company sells 94). Just leave it in the 'paddock' with your cooler of ice and it should be safe. Dragstrips often have some shady characters though so keep an eye on it between runs.
10. GO ON A COLD DAY- density altitude at or below zero is your friend. Dense air rich with oxygen lets you make power more readily than hot humid air, so skip the friday night drags in July, and try to get out there in early spring/late fall (as far as best times go...summer nights are still fun at the strip)
11. GO ON A COLD DAY PART II- the other beautiful thing about going on a cold spring/fall day is that a) it is not optimal for FWD/RWD cars traction wise, so the numbers will be down...and people just don't like the cold, so again the number of cars will be down. Perfect for you as staging in a 4.2 Audi is a heat soak nightmare.
12. SHALLOW STAGE- the staging setup is pretty alien if you've never been to the strip, but simply put it's a huge factor in your ET's success/failure. The staging lights on the top of the tree are illuminated when you cross the beams that run perpendicular to the direction of travel across the track a couple of inches across the ground. They are about 12" apart, and they won't start the tree (lights) until your front wheels are blocking both beams (both cars) . The Et clock doesn't start until the BACK of your front tire crosses and 'unblocks' the front staging beam. You can figure out that this means you're actually moving for about 10-12 inches BEFORE the clocks even start ticking if you 'shallow stage' or BARELY block the farthest staging beam with the leading edge of your front tire. At a test and tune day, this means a 0.2-0.4 second head start...and it also means that much shaved off your elapsed time vs. being 'deep staged' where you're at the point just before the back of your front tire unblocks the back beam. It seems like no big thing...but it's huge. It's the difference between 12.9 and 13.1 for B6/7 S4/RS4 so take great care to shallow stage. Google the term shallow stage and you'll get a better explanation with illustrations.
13. GO STRAIGHT!- this sounds funny, but its amazing how many people line up crooked, then need to correct on the track. Absurd waste of time...so make sure as you approach the staging beams you're going straight for at least 10-15 feet. Perfectly straight aimed down your desired line down the track. Watch primetime's videos to see...he pays good attention to this and makes minimal steering corrections, staying straight down the lane.
14. GO OFTEN! - going to the strip one time to see how you do is nice and all...but as I mentioned above, you'll rarely get the most out of your car doing it this way. You may show up on a terribly busy day, and end up getting only 2-3 passes in, never getting your technique for launching perfected. Plan to go 2-3 times in a month, and by the 2nd or 3rd time you'll feel a lot more comfortable with everything and will almost certainly run your fastest time vs. the first 1 or 2 trips. Unless you nail it first time out, then you're laughing and don't need to go back.
15. TURN OFF ESP/ASR - make sure your traction control is OFF. This will help the car get a little spin on the launch, and you will cruise out a bit better. If you spin with ESP on, the car hits the brakes and you will bog so bad it will feel like you broke the car. It takes a second for the car to re-engage power, so that run is screwed. If you do this on a day when there are 70 cars there, it may mean one of your 3 or 4 runs is toast...so DON'T!
B6/7 S4 is just a simple push of the ESP button and it's 'off' (it's not off, it's just de-sensitized). On an RS4, you need to hold it down for 4 seconds or so so that ESP light is solid. If it's flashing, it means you didn't hold it down long enough and you have only disengaged part of the system. I tried it with the RS4 with just a press of ESP (flashing) and it was ok, but on one run it stepped in and shut me down...so that's the end of that experiment lol. B8 S4 is like the RS4 in that you need to hold down for a while to get both stages off.
ANOTHER THING...you will likely be turning your car off in the staging lane if it's busy. Then you'll start it up to move up (the line moves in chunks every 3-4 minutes, so may as well not be idling/heat soaking while you wait. Nobody cares if there is a gap either so don't worry. Anyway, make sure after you re-start the car you turn off ESP again...I have done this before where I had it off, all ready to go, then had to wait for them to clean the track for a few minutes. When I was ready to go, I started the car, forgot about ESP and cut a 2.3 60 foot time lol.
16. GO WITH A FRIEND (WITH EXPERIENCE) - threads like this help, but going with someone with experience is invaluable as they can tell you how everything works.
17. ASK FOR HELP - whether it's the track officials, or other guys with cars, ask for help if you want to know something. Everyone there is a car nut like us, so they'll be happy to help you out. They'll probably appreciate you initiating contact because everytime I've been and ask someone, they always have 11 questions for me about my car (S4 or RS4...a crazy little AWD V8 powered car is something dragstrip guys seem to find intriguing)
Post by bam_bam » Fri Jun 13, 2014 8:06 pm
sakimano wrote: Fortunately I don't join forums to find friends.
It shows.
...and oddest thing at the strip?
neilparf
Post by neilparf » Mon Jun 16, 2014 4:16 pm
sakimano wrote:...douchebags...
Only one douchebag on here... starters for 10...
Gone but never forgotten:
Mr Footlong
Post by Mr Footlong » Mon Jun 16, 2014 5:21 pm
Sorry (not sorry) but the evil in me hopes that everyone that thinks it is a good idea to rape these old barges up and down the strip, blows their boxes on the strip. As for setting up Launch Control for one of these vanilla-chocolate gearboxes, please go right ahead, do a few hundred runs for me thanks and let me know how the old dog ZF Slushbox holds up.
This post isn't not in keeping with forum spirit but Dragstip runs are BEYOND a yawnathon for anoraks and/or simpletons imo. GO batter your car on a track where things such as the Steering Wheel can also be used to great effect, or a safe private runway like I do (lol), far more entertaining than rinse & repeat in a straight line and at least my box will die doing something far more entertaining.....
As for folding mirrors in etc, HOW THE HELL does that help with the "real world performance" Sakimano waffles on about all the time? I have clearly been doing it wrong. I must fold in my mirrors, tape up all the shutlines on my car and remove excess seating/coins down the back seat while I am at it.....
Current:
Gone:
Post by Shoppinit » Mon Jun 16, 2014 5:24 pm
Lol'd
Mr Footlong
Post by Mr Footlong » Mon Jun 16, 2014 5:28 pm
Sorry, I forgot, always, ALWAYS have a really good big harsh dump before you drag, people.
Current:
Gone:
sakimano
Post by sakimano » Mon Jun 16, 2014 5:41 pm
Folding the mirrors was a joke. A local member used to do it. Note the 'lol'.
As for 'fun', we are talking about benchmarking acceleration performance here, not developing a new pastime. So talking about using the sterring wheel shows you're not reading the thread.
If you did read the thread, why...THE FUK...would you EVER turn the steering wheel when benchmarking acceleration performance?
To test your new suspension settings do you go in a straight line?
To test your new brakes do you park it in the garage and wash the car?
When you measure the piece of wood you need to cut for a new shelf, do you use a decibel meter?
How this concept of appropriately testing/benchmarking modifications is so lost on so many people is beyond me. Your post was funny longfoot, but unfortunately useless. RTFS!
Mr Footlong
Post by Mr Footlong » Mon Jun 16, 2014 5:45 pm
When a post is longer than Sarah Jessica Parker's face, I switch off.
Current:
Gone:
Post by bam_bam » Mon Jun 16, 2014 5:53 pm
Mr Footlong wrote:...have a really good big harsh dump before you drag, people.
This is either a really odd ritual or an incredibly insightful thing to do just before you dress up in drag...
neilparf
Post by neilparf » Mon Jun 16, 2014 7:03 pm
Rules should never be broken.
corbett
Post by corbett » Sat Jun 21, 2014 4:03 am
rickster147 wrote:I'm guessing about 13.5 quarter at 125mph
Yaaaaaaa, no. Sorry man I hate to sound like a dick but 125 isn't gunna happen. To put it this way, the highest trapping c5 rs6 according to drag times trapped 127 and he was on nitrous. Most of these cars on stock turbos trap anywhere from 114-116ish. I do think your ET might be better than you expect if you can get out of the hole well.
Please report back on how it goes and good luck!
VARSITY
Post by VARSITY » Mon Jul 07, 2014 9:15 am
When down, feeling low, need a laugh, look at SAKIMANO posts.
You will see life in a different perspective!
Never argue with an idiot, they will drag you down to their level and beat you with experience.
rickster147
Post by rickster147 » Mon Jul 14, 2014 11:21 am
Now now children!
If I want to take my car to strip to see what it will do then I will
2-3 runs isn't going to hurt it much and if it breaks then so be it I will fix it
And I don't think it would make a good track car like u said these cars are a good all rounder and motorway cruiser!!
Rs4 b7 In avus silver with b14 Bilstein coilovers, centre resonator delete with x pipe and piggie cats gutted
Headlights detangoed trups led kit drl reverse and numberplate kit
Previous audi
rs6 c5 - mrc stage 2 remap-itg filters-forge dumpers-center decat with miltek kw coilovers- h and r
I call her the growler lol
Users browsing this forum: No registered users and 240 guests
