2 din or not 2 din?
IanH755
Re: 2 din or not 2 din?
Post by IanH755 » Sun Apr 27, 2014 9:53 am
Had the same on mine, RCA filters are the way to go. It dropped the volume of whine 95% but if you listen very carefully you can 'just' about hear it at idle with the stereo muted. As soon as the cars moving or the stereo is playing music then you can't hear it anymore.
Post by MikeFish » Sun Apr 27, 2014 10:02 am
I tried everything to get rid of the alternator whine on mine including rewiring the amp and stereo and in the end the only thing that worked was an RCA filter.
Mr Footlong
Post by Mr Footlong » Sun Apr 27, 2014 10:53 am
Mike, was your whine there from the beginning or did you fit the MMI kit by any chance? Mine only started when I shoehorned in the harness gubbins in the centre console for the MMI and connected it. Doing my head in but if memory serves there is a bit of a loss of fidelity when using RCA filters non?
Current:
Gone:
Post by Shoppinit » Sun Apr 27, 2014 10:56 am
Definitely. The filters will affect your sound quality. You definitely should try to get rid of the whine through conventional means first.
Post by MikeFish » Sun Apr 27, 2014 11:08 am
I had a ground loop so sounded like alternator whine and only started when I fitted aftermarket amps using the original Bose wiring for the low level signals. The input to my processor was fine but the output introduced the noise.
AMGCoelho
Post by AMGCoelho » Sat May 03, 2014 12:55 am
tmg wrote:hey
so the Nav plus is the rns-d (just to answer the question for you)
t.
really helpful thank you tmg and ahoooooga too.
Drummerman
Post by Drummerman » Sat May 24, 2014 4:02 pm
I have a Dension Gateway 100 that was linked up to my RNS-D. Used it to play Apple Lossless from my ipod. For sale if anyone wants it. Also have the RNS-D and a 2005 RNS-E gathering dust. Give me a shout if anyone is interested.
Talleyman
Post by Talleyman » Sat May 24, 2014 9:20 pm
Drummerman, will the dension work with the rns-e? If so, how much you asking for them ?
Daytona RS6 C5 Avant
Drummerman
Post by Drummerman » Wed May 28, 2014 9:14 pm
Hi Talleyman, sorry for delay in replying, i just had to check I had all the bits. Unfortunately the Dension wont work with the rns-e. looking at the back of the old RNS-D and RNS-E, the plugs are totally different.
Talleyman
Post by Talleyman » Thu May 29, 2014 9:25 pm
Drummerman wrote:Hi Talleyman, sorry for delay in replying, i just had to check I had all the bits. Unfortunately the Dension wont work with the rns-e. looking at the back of the old RNS-D and RNS-E, the plugs are totally different.
No probs drummerman, cheers for checking!
Users browsing this forum: Google Adsense [Bot] and 199 guests
