K W Springs fitted.
5.0 V10 50v biturbo - 571 bhp
RS6chris!
Re: K W Springs fitted.
Post by RS6chris! » Thu Dec 26, 2013 7:03 pm
Ride is better IMO...defo more composed when pushing on...defo less roll...although my spring are set very low.
A defo mod for any one who likes to "press on".
Car felt very composed on motorway coming back from Unit 20...as opposed to OEM.
Looks are a no brainer for me too...
Gunna try spacers back on this week too...see how she sits.
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
classba
Post by classba » Thu Dec 26, 2013 8:33 pm
sixspeed wrote:Is the ride just more compliant or actually softer? Being more compliant sounds good if it doesn't result in more body roll, or a reduction in composure when pushing on.
Must admit I removed the front plate the other day and naturally just looks more aggressive as a result, so lowering it is higher on my agenda now to complete the look.
Looks lovely there though Chris. Shame you're not closer, would pinch a ride!
Six... lets put it this way. The car drives more planted and sure round corners with the springs and absorbs the bumps better than OEM. The steering is more precise turning in quicker even round tight corners or out of give way junctions. Sat in a stock car not long ago and it felt wobbly with body roll in comparison. The DRC works so well that even with my 22" on Dynamic ride, it handles like a dream without any crash and bang ( NO fillings missing ) :biggrin3:
sixspeed
Post by sixspeed » Fri Dec 27, 2013 5:44 pm
Sounds good! I'm always sceptical about spring upgrades and peoples perceived handling improvements when you read similar forum posts, hence trying to be more specific. Must get around to doing some more to my RS in 2014 though and this is a logical next step (along with a stage 2 MRC map!).
2009 Sepang Blue C6 RS6 Saloon - H&S exhaust with de-cat and Vabric valves - Stage Two MRC next!
2007 Alpine White BMW Z4M Coupe - trackday toy with lots of mods!
classba
Post by classba » Fri Dec 27, 2013 6:43 pm
sixspeed wrote:Sounds good! I'm always sceptical about spring upgrades and peoples perceived handling improvements when you read similar forum posts, hence trying to be more specific. Must get around to doing some more to my RS in 2014 though and this is a logical next step (along with a stage 2 MRC map!).
Six, give me till end of Jan and you're welcome to come round for a ride in mine.
sixspeed
Post by sixspeed » Sat Dec 28, 2013 8:19 pm
May take you up on that!
RS6chris!
Post by RS6chris! » Sun Dec 29, 2013 4:44 pm
Update guys
8mm spacers fitted today(no photos yet)
All seems well...
Slight rub over undulating surfaces from rears, NSR seems worst?
Thinks it catching wheel arch liner?
Il see how it settles, may have to raise rear slightly?
Also removed front wheel arch liner screws.
Il try and post pics tommorow.
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
classba
Post by classba » Sun Dec 29, 2013 5:50 pm
Chris, if the rears are rubbing without any passengers then you must raise it especially yours aren't settled yet which can drop another 5mm. I personally dislike using spacers and especially fitting them to a 2 ton+ car with over 700 bhp.
RS6chris!
Post by RS6chris! » Sun Dec 29, 2013 5:57 pm
I thought it looked "weedy" on OEM wheels dropped?...they were well inside arches.
Spacers have sorted this...however it I can find an aftermarket wheel that does that job happy days.
I believe it's quite simple to adjust these springs?...got the tools to do it in box with them.
Specialist or DIY?
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
RS6chris!
Post by RS6chris! » Sun Dec 29, 2013 6:00 pm
Or plan B?
I'm due new tyres any time maybe next 500 miles?
I'm running Dunlop Sport max OEM spec.
Any tyres with a smaller side wall that might mitigate against rubbing that anyone's aware off?
What tyres are you guys with dropped cars running?
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
classba
Post by classba » Sun Dec 29, 2013 6:23 pm
Pirelli Nero tyres, custom wheels ( ADV.1) or ones that are proven.
sixspeed
Post by sixspeed » Tue Dec 31, 2013 12:42 am
Easy to adjust the springs as you say Chris, but the suspension geometry will be put out of alignment if you do, so would be worth having another alignment done if you do make changes (assuming you've had one done already).
sixspeed
Post by sixspeed » Tue Dec 31, 2013 12:44 am
classba wrote:Pirelli Nero tyres, custom wheels ( ADV.1) or ones that are proven.
ADV.1 wheels are f*ckme gorgeous but very expensive for what they are.
RS6chris!
Post by RS6chris! » Tue Dec 31, 2013 12:51 am
It's only the NSR that's rubbing today?
Worse as said when I had kids in?
Car looks level at rear?...do t know if NSR is set lower?
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
classba
Post by classba » Tue Dec 31, 2013 11:43 am
RS6chris! wrote:It's only the NSR that's rubbing today?
Easy to check if both sides are level. Measure the distance between the top and bottom spring platform adjuster cups. The very max is 40mm ( check the manual ).
Users browsing this forum: Google [Bot] and 99 guests
