gt2 wrote:From where?
http://www.ebay.co.uk/sch/i.html?_trksi ... &_from=R40
so lets say roughly £50 for an oil cooler £50 for hoses, which leaves £700 for brackets and instructions
Radtec Radiators sell the exact same manufactures oil cooler, I guessed it was a 16 Row so £100ish all in.gt2 wrote:From where?
Just to be clear - Anodised fittings doesn't affect galvonic corrosion.sar wrote:i was just going to say don't forget about the custom engine block fittings that you cant buy off the shelf, these would add a significant one off development cost if you were trying to put your own kit together.
its the lines that are the weak link, there is nothing wrong with the oem cooler design or capacity its more than enough for a standard rs4 its even good enough for supercharged cars its the stupid cheap pipe and steel fittings used on the oem lines.
i am ordering the jhm cooler lines for mine, similar price to oem but top quality pipes and anodized fittings-http://jhmotorsports.com/shop/catalog/j ... -1754.html
Chaps, we sell various 15 row oil coolers that are "universal", for track cars and they do a job of cooling but to be honest weve waited a while for Forge to do a proper conversion for the RS4 as this is a special car and as you can see from the Forge post, this a proper upgrade replacement unit that this car deserves.forge wrote:Guys you are comparing apples to oranges here a little. Yes we could have put together a kit that uses the finest Chinese oil cooler, but we figured that an RS4 owner would want the best oil cooler we could use - which in this case is a Setrab Proline 19 row, retailing at £178 on its own. The braided lines are all dash 12 to match up with the oulets on the block, and yes unfortunately this means that the hose itself retails for about £30 per metre. Dash 12 hose ends are between £20 and £30 each of which there are four. There are a total of seven individually CNC'd components, of which one (the block outlet) took well over a week of R&D time to make the best flowing part we could in the minimal space allowed to us by Audi. Two of the parts had to be made from specially sourced nylon so that where it clips over the air con condensor, it doesnt scratch the paint off over time. Its this attention to detail that you would be missing from a slung together kit of ebay parts.
This is the best kit we could make, its not compromised by cost or design - it is what it is. It comes complete with full instructions, it will fit first time every time with no cutting or bending of other components, and doesnt have you scratching around in the garage for bolts because everything you need (bar oil) is in the box. It brings together tried and tested products from motorsport and combines them in a kit which means no more trips to Audi to replace your engine oil cooler every 5 years. All of our components carry a lifetime guarantee.
Youngben wrote:Some people are never happy. If you don't like it then your loss, simple. I know the English way is to moan but there are some right women on here. Had better support on the old M3 forum. If you put £800 worth of quality oil cooler before your engine and the possibility of if failing not long after your cooler has then there is something not quite right upstairs! When was the last time anyone priced up a new engine and replacement costs? Suddenly £800 for something that will only increase your engines life does not seem so expensive. If it still does then everyone has a local Audi dealer so on your way
Cool story bro, and respect to the achievement which is well out of my engineering capability, but....... The markup is your choice and the market will decide if it's fair, if not, the price will drop.forge wrote:Guys you are comparing apples to oranges here a little. Yes we could have put together a kit that uses the finest Chinese oil cooler, but we figured that an RS4 owner would want the best oil cooler we could use - which in this case is a Setrab Proline 19 row, retailing at £178 on its own. The braided lines are all dash 12 to match up with the oulets on the block, and yes unfortunately this means that the hose itself retails for about £30 per metre. Dash 12 hose ends are between £20 and £30 each of which there are four. There are a total of seven individually CNC'd components, of which one (the block outlet) took well over a week of R&D time to make the best flowing part we could in the minimal space allowed to us by Audi. Two of the parts had to be made from specially sourced nylon so that where it clips over the air con condensor, it doesnt scratch the paint off over time. Its this attention to detail that you would be missing from a slung together kit of ebay parts.
I would pay full price for the product for what it matters. Get over yourself mateRick_RS4 wrote:Youngben wrote:Some people are never happy. If you don't like it then your loss, simple. I know the English way is to moan but there are some right women on here. Had better support on the old M3 forum. If you put £800 worth of quality oil cooler before your engine and the possibility of if failing not long after your cooler has then there is something not quite right upstairs! When was the last time anyone priced up a new engine and replacement costs? Suddenly £800 for something that will only increase your engines life does not seem so expensive. If it still does then everyone has a local Audi dealer so on your way
yes butdid you get yours at cost lol
Users browsing this forum: highrise and 57 guests
