Knocking suspension when cold
4.2 V8 32v FSI - 444 bhp
lengster1
Re: Knocking suspension when cold
Post by lengster1 » Mon Dec 30, 2013 10:22 pm
Good luck mucka my b7 went in 4 times,it then went to York once!! Mine only goes to York now,hope they have more sucsess with yours bud.Hopefully they've bought the gen 2 set up and don't ust try and fill you full of sh%te and insulting excuses time n time again.I cant believe this DRC issue is rumbling on still.
Markmyatt7
Post by Markmyatt7 » Mon Dec 30, 2013 10:25 pm
lengster1 wrote:Good luck mucka my b7 went in 4 times,it then went to York once!! Mine only goes to York now,hope they have more sucsess with yours bud.Hopefully they've bought the gen 2 set up and don't ust try and fill you full of sh%te and insulting excuses time n time again.I cant believe this DRC issue is rumbling on still.
Moving to York in March. Heard good things about York Audi.
Current Car: 2014 Nissan Quashqai 4WD (it's not my fault)
Previous Cars: 2006 B7 RS4 - Phantom Black
2010 BMW 123d Coupe M Sport
2004 Honda Civic Type R
2002 VW Golf 2.8l V6 4 Motion
lengster1
Post by lengster1 » Tue Dec 31, 2013 12:06 am
Superb service,one of the service guys is an enthusiast and they have a very knowledgable RS tech.They answer the phone and return calls when they say they will :beerchug: :biggrin3: Your car will be in good hands.
AMB
Post by AMB » Sun Jan 05, 2014 7:59 pm
Mine used to on occasion; it would be less severe if I put it in Dynamic.
Car went into stealer for nothing special and when got it back, hey presto - no knock! DRC fettle? I'm not entirely sure....
AMB
Former owner of RivBlue_B8
pcroxford
Post by pcroxford » Sat Jan 11, 2014 6:20 pm
Had same problem with mine at 2500 miles. Just been back to Audi and first they performed a software update...didn't work. Then they replaced the o/s/f shock. Seems better, but still not convinced it is fully fixed...maybe something i'll have to live with?
Graeme4130
Post by Graeme4130 » Sat Jan 11, 2014 7:36 pm
pcroxford wrote:Had same problem with mine at 2500 miles. Just been back to Audi and first they performed a software update...didn't work. Then they replaced the o/s/f shock. Seems better, but still not convinced it is fully fixed...maybe something i'll have to live with?
If all RS4's knocked, then it's reasonable to assume its 'the norm'
However, several don't, mine included, so it must be a fault. Throw it back at the dealer, tell them how dusgusted you are, and make them fix it
Dubel
Post by Dubel » Sat Jan 11, 2014 9:39 pm
Thought I would give a bit of insight,
Mine knocked from the day I picked it up, it took Audi 4 weeks to identify the fault and apparently repair it. I know they did a lot of diagnosis for Audi UK on my car as all the tech updates and advice from Audi UK did not fix the fault. They now have said that central valve for the DRC had failed, hence why the pressure kept dropping.
I just picked it up again on Friday although it is better but I'm still getting a metallic bang from the drivers front on the larger bumps.
Its going back in again, I'll let you know the outcome..
Current
2014 RS4 (B8)
Pre loves
2013 RS4 (B8)
2011 S5 Cab
2007 RS4 Metallic Silver
2002 Audi S3 (new house)
2003 Porsche 996 C4S
2003 Z4 3.0 Cab
1993 Porsche 968 Cab
1989 Renault 5GT
jpcartel
Post by jpcartel » Wed Feb 05, 2014 3:05 pm
My 2011 RS5 has the same noise - tends to be more so going over bumps rather than through holes if that makes sense..
It doesn't seem to happen when in Dynamic setting, mainly just in Comfort mode.
Manchester Audi have advised they think it needs re-gassing although their machine is broken and they don't know when it will be fixed... They have referred me to Warrington Audi who have booked it in for Friday the 14th. They say they need the car for a full day of diagnostics and to try to re-gas...
Once I get it back I'll give an update.
To be honest I haven't had the car long and it has only recently started. I plan to put either H&R springs or KW coilovers on it soon but want to ensure all dampers & DRC system is 100% right while under warranty before I start meddling with it as we all know they'll wash their hands of it as soon as they get a sniff of any after market parts...
2011 RS5 - Daytona Grey
Sports Pack, Sports Exhaust, B+O, Nappa, Black Optics, Tech Hi, Home jobby (garage door thingy) and whatever else its got..
smudge
Post by smudge » Sat Feb 22, 2014 12:09 am
Hey guys, any updates on this? I took mine into the dealers back in Oct (I have DRC & 20's) & they couldn't find anything specific. My Master Tech is a good guy, he calls me personally & chats through all sorts of things, but this he could diagnose at the time, but he tells me he hasn't given up....... There are a couple of things that I want looking at so I'll get mine booked in, but if anyone else has been advised of a valve failure, or something else, I'd be keen to here.
Ta
Al.
It's all torque talk.
D8vil
Post by D8vil » Sun Feb 23, 2014 12:50 pm
Hi
I just thought I would feed some info back
Hull Audi have re charged the DRC and it's still the same
Andy @ autotechnica had a friend at audi HQ and there are aware of the issue but the information being fed to the dealers is the noise is a quirk in the suspension and no real fault !!
Mine will keep going back until they fix it, how can the B8 have a knock and the B7 be mint !!!
D8vil
Post by D8vil » Sun Mar 09, 2014 6:31 pm
We'll mine is going back to Hull audi for 1 week to see if Audi uk can sort it
But on the plus side I'm getting a v10 r8 as a lone car
jpcartel
Post by jpcartel » Wed Mar 12, 2014 1:37 pm
I've also posted a similar issue in the RS5 section under 'DRC knocking'
I have an ongoing issue with knocking from front suspension - the car has just come back to me after 2 weeks at Manchester Audi and the problem is still there. They're as baffled as I am as they have now replaced the following:
O/S/F shock, O/S/F lower rear wishbone, O/S/F top mount, both actuators and recharged the system.
Now no one seems sure what the problem could be so have asked me to bring it back again tomorrow (for the 3rd time...)
I have also noticed that the N/S is now higher than the O/S - I can get 3 fingers between wheel and arch on N/S and only 2 on O/S since its come back to me which I've asked them to look in to further...
They are insisting the best they can give me as a courtesy car is an A4 2.0 TDi which I grumbled about last time so have asked them to take it up with Audi UK to give me a more suitable loan car when it goes back in.
Starting to get a bit frustrated now..
Warthog
Post by Warthog » Mon Mar 17, 2014 4:59 pm
Ive done 600 miles in mine over the last fortnight and its done it from day one.
It sounds like its coming from the rear.
It is worse when cold.
It seems to be worse in comfort than dynamic.
I can't tell if its when the shock is compressed or during extension.
As a side note, i find the dynamic setting for the suspension makes the ride so rough that I can't imagine when i would ever use it.
Is that everyone else's experience or is that part of the problem I have?
RIV
Post by RIV » Mon Mar 17, 2014 5:16 pm
I use my car in dynamic 90% of the time, mine makes a slight noise in comfort from the front offside, it's doesn't worry me as the car handles well, I will get them to check the pressures when it gets serviced
carsarecool
Post by carsarecool » Tue Mar 18, 2014 11:18 am
Mine makes noise when cold but seems to handle fine so I am not bothered.
Users browsing this forum: Google [Bot] and 63 guests
