Be aware!!! Scary stuff!!!
4.2 V8 32v FSI - 444 bhp
adsgreen
Re: Be aware!!! Scary stuff!!!
Post by adsgreen » Mon Sep 16, 2013 2:20 pm
Have you heard an Audi alarm?
Mine went off right outside and the first thing I said was "is that my phone?".
Post by Ian_C » Mon Sep 16, 2013 3:11 pm
Yeah its pathetic. Stood talking with an RS4 owner at Audis in the Park, they shut the bonnet and the alarm went off as the car was locked, however it was so quiet they didn't even realise!
matthew.lewis2
Post by matthew.lewis2 » Mon Sep 16, 2013 4:03 pm
Is alarm volume adjustable via VCDS?
UAE CARS
2009 Toyota Landcruiser - White -4.7 V8 VXR (SOLD)
2014 Mercedes ML500 - 4.7 V8 Twin Turbo (SOLD)
2008 Audi RS4 - Sprint Blue (SOLD)
2002 Range Rover 4.6 V8 HSE (SOLD)
2007 Golf R32 - Black (SOLD)
2005 Lincoln Navigator - White (SOLD)
UK Cars
2015 Landrover Defender 110 Heritage (SOLD)
2014 Audi RS4 - Sepang Blue (STOLEN)
2003 EP3 Civic Type R - K-Pro Remapped (SOLD)
2004 Golf GT TDi 140 - Superchipped to 189bhp (SOLD)
2003 Audi A2 1.4 Tdi
PetrolDave
Post by PetrolDave » Mon Sep 16, 2013 5:49 pm
neckarsulm wrote:For them to not be bothered about the alarm is scarey
Why should they be bothered about the alarm?
Audi "alarms" are ridiculously quiet which just adds to the problem that nobody takes any notice of car alarms anyway.
When the alarm went off on my A4 in 2004 it was so quiet, despite the car being on the drive right outside the front door, it wasn't even as loud as the microwave beeping in the kitchen.
PetrolDave
matthew.lewis2 wrote:Is alarm volume adjustable via vcds?
Nope.
MB2
Post by MB2 » Mon Sep 16, 2013 8:34 pm
I posted over on the B7 Forum, but if I owned a Keyless Gone Audi I would have an immobiliser with RFID tag spliced into the ODB wires so you had to present the tag for the connections to the ODB port to be made.
Graeme4130
Post by Graeme4130 » Mon Sep 16, 2013 9:01 pm
I'm still sceptical about the idea of this being a targetted crime, rather than an inside job of some description.
How, for example, would the thief/thieves have known this is a keyless go car without the dealer instructing them ? I believe KG cars are visually identical to non KG cars, even in that they still have the key dock in the dash
ollys
Post by ollys » Mon Sep 16, 2013 9:34 pm
Graeme4130 wrote:I'm still sceptical about the idea of this being a targetted crime, rather than an inside job of some description.
err don't keyless cars have some sort of button on the door handles - my old man's B8 A4 does - easy to spot when you know what to look for?
This is scandalous - whether or not an inside job - that it can be done at all let alone in 12 minutes. There must be a way of making the OBD port inactive...
Graeme4130
Post by Graeme4130 » Mon Sep 16, 2013 10:23 pm
Of course, yeah you might be right.
Post by Ian_C » Tue Sep 17, 2013 12:06 am
ollys wrote:There must be a way of making the OBD port inactive...
Simple one would be to position the port on the end of the dash facing the door so you cannot plug in unless the door is open. Think of the old school fuse boards - you take the passenger end cap off the dash - you cannot do this with the door shut. Audi could implement this change relatively easily on the production line.
MB2
Post by MB2 » Tue Sep 17, 2013 9:09 am
Great idea - probably thwarted by the requirement that the port must be located in the passenger compartment within reach of the driver's seat although it would not prevent the technician using the port from the drivers seat & I can't see the EU getting too angsty as the directive is really to reduce emissions so I think the passenger requirement (+ can't need tools to get to it) is just meant to make mechanic's lives a bit easier. It can already have a cover so it could have some trim over it so wouldn't have to see it each time you opened the door.
Graeme4130
Post by Graeme4130 » Tue Sep 17, 2013 11:58 am
Yeah, I agree. it'd certainly stop them accessing the port with a deadlocked door.
However, implementing it in production is not an easy job as you'd need to retool quite a few plastic mouldings, and that's before you start to look at any interference with cross members and airbag systems.
Post by Ian_C » Tue Sep 17, 2013 12:27 pm
You could design it with the ODB recessed deep enough that you could plug in and then close the door - hence you could drive the car plugged in
Or have a cap like aforementioned fuse cover that can only be removed to access the ODB when the door is open. Again you could close the door and drive the car with it plugged in
neckarsulm
Post by neckarsulm » Tue Sep 17, 2013 9:29 pm
So not all RS4s are keyless, live and learn.
To access live data you need the OBD scanner plugged in and the door shut.
TBH footwell isn't ideal but this seems to be the norm now on VAG
The best place for it is as on Mk4 Golf, just above centre console in dash smack in middle for easy access from either seat and no cables close to pedals/steering wheel.
However even better would be in a centre console storage bin like on a 911 (996 or 997) which locks with the central locking.
Soon I am sure OBD will be wireless and cars will come with a PIN which will be even more insecure!
Any B8 owner got VCDS? Can you turn ignition off, plug cable in and see if you can access modules such as Central Electrics, Central Locking etc
I am wondering it it stays live for a certain time period.
I coded a remote control for a Mk6 Golf today, realised I'd taken key out of the ignition to press the button on it but VCDS was still communicating with the car.
GC1978
Post by GC1978 » Wed Sep 18, 2013 11:42 am
Is it possible to fit a battery master switch with a relay and a secondary battery (say a 6amp small thing) so when you exit the car you can flip the switch - which disconnects the main battery but keeps the back up battery in line for things like clocks, tracker etc? This way if someone tried to start the car the small battery would not ever have enough power to crank the starter motor?
Either that or fit a master switch to the start motor solenoid!?!
Users browsing this forum: No registered users and 70 guests
