People with Revolution (Real) Carbon airboxes...
Youngben
Re: People with Revolution (Real) Carbon airboxes...
Post by Youngben » Sun Sep 08, 2013 1:08 am
Cecilthesausage wrote:They are just aesthetically pleasing to the eye... No real gains and by the sounds of things running problems....£500 odd quid.... No thanks...
you obviously haven't heard one! it brings a V8 to life! i would pay more for one! and its a 1 off so far that's why im asking the question not pointing the finger! it could just be luck of the draw i may just have a filter dosed in to much oil? £500 isnt exactly life changing these days
Youngben
Post by Youngben » Sun Sep 08, 2013 1:13 am
Firestarter wrote:Thanks for this Ben. I've only done around 1000 miles since fitting mine and no issues, however today as I left AmD and got on to M25 the EPC light came on. Car will only rev to just over 6k and feels sluggish. Got home and after I re started the car both EPC & Emission control light come on. I'm guessing this could be down to some further tweaking needed with the map that AmD have just done, but could it also be a MAF issue. Not had any issues with the CF air box prior to this? I'm taking the car back to AmD on Thursday so it can be rectified and will post the outcome of the problem
yours sounds more like limp mode mate! didn't get no emission control light so maybe a lambda for you?
Youngben
Post by Youngben » Sun Sep 08, 2013 1:14 am
scaghead wrote:So the dry filter is the way to go...I presume if you run a standard air box set up you don't get this problem from oiled filters as the filter is that much further away from the maf?..
the standard air filter would be a paper filter though no? so would not be oiled! but yeah the MAF is further from the air box on the standard setup
Firestarter
Post by Firestarter » Sun Sep 08, 2013 5:30 am
Cheers Ben. I thought that the car may be in "safe/limp mode" and funnily enough the Black loan RS4 I had for a couple of days had the exact same issue and drove and felt exactly the same as mine, however this was due to on-going work the car was having done and was waiting to have the re-map complete and was running the standard airbox....not sure if it had a K&N flat panel filter, but it had the exact same De-cat (no cats) down pipes and Milltek exhaust as mine. Felt sluggish, not pulling as hard in gears and only revving up to just over 6k :oops: I'll mention this thread when I tale the car back in to AmD as its a good point of reference should the cone filter be causing issues and affecting the MAF sensor :bash:
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
SVM 102mm decated zorst with Black Tips....ITS LOUD & HOT :-)
1050cc Asnu injectors,
SVM 80mm MAF intakes
K&N High Flow Filters
SVM Custom EcuTek map (Thanks John!!)
and a shitload of Carbon Fibre :-)
B7 RS4 (Mr T) - Gone but never forgotten and still in Surrey
scaghead
Post by scaghead » Sun Sep 08, 2013 6:30 am
Yes that's right fella..but some aftermarket filters are oiled, may have been the piper cross one funny enough...
Cecilthesausage
Post by Cecilthesausage » Sun Sep 08, 2013 6:36 am
What is difference in sound like Ben....?
Noyjatat
Post by Noyjatat » Sun Sep 08, 2013 6:38 am
It's considerable actually. Gives a throaty roar which is a only a little quieter than having an exhaust upgrade.
It really does make the car sound great under load.
scaghead
Post by scaghead » Sun Sep 08, 2013 6:42 am
Noyjatat wrote:It's considerable actually. Gives a throaty roar which is a only a little quieter than having an exhaust upgrade.
Plus 1..
Firestarter
Post by Firestarter » Sun Sep 08, 2013 7:56 am
Plus 2
induction ROARRRRRRRRRRRRRRRRRRRRRRRR :biggrin3:
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
adsgreen
Post by adsgreen » Sun Sep 08, 2013 8:18 am
Induction noise is great as its more controllable than exhaust. Proper stealth mod (from the outside).
Oem paper filters are disposable and non oiled.
MRC filter is a branded one (can't remember the make ITM?) and needs to be washed and oiled.
Just as easy to overdo the oil on that one tbh.
If the revolution one was a paper if be more inclined - oil filters are fine but messy and hassle.
RS04YOB
Post by RS04YOB » Sun Sep 08, 2013 9:45 am
Cecilthesausage wrote:running problems....
Enlighten us all about the running problem this would have been the first I have heard about this I know of another car with one fitted that has more than likely done about 15k with it fitted
Noyjatat
Post by Noyjatat » Sun Sep 08, 2013 10:14 am
Heard a lot about the power loss too but not really found anyone with any figures. As we all know the old rolling road can give considerable differences day to day with the same car. I imagine if a mod gives a small loss or gain say 5-6 bhp that could be lost due to temps that day. Most people buy this item to give them that lovely noise and as stated it is nice to look at. Gruppe M's quotes an average of 15 hp gain at the wheels. Anyone on here found theirs to give such a large bump?
Yanos
Post by Yanos » Sun Sep 08, 2013 10:20 am
Mine was running fine for about 1000 miles but then started getting a flat spot at 4-5k, ran diagnostics yesterday and got a Intake Manifold Flap Position Sensor 008224 error. Is this what you have Ben?
RS4 B7 Misano Red Saloon / Black Optics / Revolution - Pipercross Carbon air intake / Carbon Clean / Black Rings / Lepsons Black Chrome Alloys
nij
Post by nij » Sun Sep 08, 2013 2:01 pm
Plus 3
I prefer the noise of my Gruppe M to my non resonated Milltek.
I had my K&N cone filter cleaned and oiled a few months ago, which is a PITA. Had to leave it to stand for a week before re-fitting it to let the excess oil drain off the filter. It still worry me that the oil might damage the MAF sensor.
Mercedes E-Coupe 350CDi
toshers
Post by toshers » Sun Sep 08, 2013 2:18 pm
nij wrote:It still worry me that the oil might damage the MAF sensor.
I love the look of these but I had issues because of an oiled filter with the MAF on a previous M5. Once bitten twice shy.
Saying that I'd be very interested if a 3 stage dry filter is a possibility :rocker:
New RS6 PE ordered in Nogaro...it's a long wait!
2015 Suzuka Grey RS4
Users browsing this forum: Google Adsense [Bot] and 261 guests
