Power Close Tailgate?
5.0 V10 50v biturbo - 571 bhp
Trups
Trader (Expired)
Re: Power Close Tailgate?
Post by Trups » Tue Apr 30, 2013 7:26 pm
thanks. will go out in 10 to have a play
Trups
Trader (Expired)
Post by Trups » Tue Apr 30, 2013 8:07 pm
had a look. its 6d for electric tailgate, no options in adaptation and coding is blanked out.
The BCM on C6's are very old, I think my 04 polo has just as much coding options as this.
Was the superb long coding?
Trups
Gizmo68
Post by Gizmo68 » Tue Apr 30, 2013 8:23 pm
Sorry I meant 6D (fat fingers)
The Superb was in adaptations not the long coding, I will however scan it over the weekend to see if any of the long coding changed.
VCDS HEX+CAN owner - covers all VAG cars (PM me if you require VCDS coding in Kent)
Gizmo68
Post by Gizmo68 » Sat May 04, 2013 4:32 pm
Here is a screenshot of my MY11 (Dec 2010) Superb adaptation, you are looking for:
“Close rear lid” you are looking to activate both number (4)’s
(4)-Activation using rear lid remote unlocking switch - Tap function for closing
(4)-Activation using rear lid opening button in remote key - Tap function for closing
(The ‘Tap’ function enables the tailgate to open/close with one touch of the button, the ‘Touch’ function requires you to keep the button pressed)
My long coding did not change after I made the adaptation changes.
To summarise, from the factory my tailgate opened (fully) from the remote and the button inside the car, but to close it you had to press the button on the tailgate… it would not close any other way, now it also closes (fully) with the remote, the button inside the car and the button on the tailgate, this was done purely with VCDS coding… no hardware was added, despite Kufatec stating to several owners that it was not possible by coding alone.
HTH.
GC1978
Post by GC1978 » Wed May 08, 2013 8:36 pm
Little black box arrived.. will update when fitted! :bigwave:
RS6 London
Post by RS6 London » Wed May 15, 2013 7:51 pm
So forgive me for being thick but do I need to buy the €109 bit of kit or do some coding?
GC1978
Post by GC1978 » Wed May 15, 2013 10:05 pm
Box fitted today, took about an hour.
Hardest bit was finding somewhere for the box to go, in the end decided on putting it in the roof lining forward of the hatch.
Also, on both drive units the main screw holding in the motor / control units were no where near tight. One was about 4 turns slack!
So might be worth checking everything is tight. My tailgate now closes a lot quieter - almost silent.
As for the black box - does what it says on the tin - although I have still not fully figured it out.
I can get it to close by pressing the door unlock button on the key 4 times. Instrucitons say 2 presses??
Also, the main button in the door will close the hatch - hold up for 3 seconds and let go and it closes.
I assume thats correct?
GC1978
Post by GC1978 » Thu May 16, 2013 9:11 am
Figured it out - it takes about a second after the 2 presses for it to close - so you press twice and then wait a second and it closes. :bigwave:
gorwanvfr
Post by gorwanvfr » Fri May 17, 2013 1:56 pm
GC1978 wrote:Figured it out - it takes about a second after the 2 presses for it to close - so you press twice and then wait a second and it closes. :bigwave:
Glad it does what you wanted :beerchug:
RS6 C6 (Gone but not forgotten)
Golf R
Delorean DMC 12
Jaguar MK2
E-type
Gizmo68
Post by Gizmo68 » Sat May 18, 2013 1:10 pm
RS6 London wrote:So forgive me for being thick but do I need to buy the €109 bit of kit or do some coding?
The kit will certainly work, but a bit of coding may also work, until someone tries is out then none can be sure. (we were told by Kufatec the Superb could not be done by coding alone, this has since been proved wrong).
brn7y
Post by brn7y » Sat May 18, 2013 2:46 pm
Have you got VCDS, if not I can let you use mine to try and see if it can be coded.
Aberdeenshire.
gorwanvfr
Post by gorwanvfr » Wed May 22, 2013 9:35 am
Sorry to say coding will not work tried both my car and the wife's Q7. No way to code it
Golf R
Delorean DMC 12
Jaguar MK2
E-type
Users browsing this forum: No registered users and 92 guests
